How to reset and calibrate your VSC computer - The Easy way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Dec 30, 2016.
  1. Apr 5, 2024 at 8:18 PM
    #381
    trwtaco
    trwtaco Member
    Tim
    ‘15 TRD Crew
    Thank you
  2. Apr 18, 2024 at 5:07 PM
    #382
    Fuzzy222
    Fuzzy222 Member
    This is one of these times if it's not broke don't fix it, I've had my Tacoma for a yr now with no codes or VDC lite stay on,the guy I bought it from did a front end alignment and 2" lift, I though he maybe he didn't reset the VSC so I tried it, level floor, wheel straight, lights flashed and it look good. Went I started the truck again the VSC came on and stayed on, could not get it off, got my buddys scanner and removed it. All good until I drove 50 ft and it's back on. What's to do next?
  3. Apr 19, 2024 at 2:45 AM
    #383
    trwtaco
    trwtaco Member
    Tim
    ‘15 TRD Crew
    I’m having the same issue.
  4. Apr 19, 2024 at 10:10 AM
    #384
    Fuzzy222
    Fuzzy222 Member
    I forgot to do the last step,just plug the wire into the holes and turn the key on,both the abs and VSC lights will flash really fast,wait 5 seconds and turn the key off,pull the jumper wire out and your done.
  5. Apr 19, 2024 at 5:13 PM
    #385
    Tschumacher
    Tschumacher Member
    2020 Tacoma TRD Sport & 2016 4runner
    Hey, someone knows how to do it on a 2020 Tacoma or did it work for someone? I’m checking the OBD2 and in the 4th starting from the passenger side it doesn’t have any cables coming in so it won’t short it. Still I plug in my scanner and it works fine. I’m wondering if I should short different pin positions as the original post.
  6. Apr 19, 2024 at 6:53 PM
    #386
    Fuzzy222
    Fuzzy222 Member
    I'm not sure about the gen 3 like yours but I'm guessing it's the same process,there's a few videos you can watch also,I wouldn't recommend poking wires in different port holes, you may end up doing damage that could cost a lot to get fixed. Watch the video 3 or 4 times just to be certain it's done right. Good luck.
  7. Apr 19, 2024 at 6:55 PM
    #387
    Tschumacher
    Tschumacher Member
    Thanks. I kept researching and I see my OBD2 sensor has pins 4 and 12 unoccupied. It’s setted up different idk why and supposedly does not have TC or TS
  8. May 2, 2024 at 5:13 PM
    #388
    MATRIXHASU
    MATRIXHASU New Member
    Eddie
    '23 tacoma trd
    Lift
    Hey y'all I saw a '20 and '23 on here has this been confirmed successfully?
  9. Jun 20, 2024 at 3:32 PM
    #389
    3rdGenZuela
    3rdGenZuela New Member
    2023 Toyota Tacoma TRD Sport 4x4
    6in RC lift
    Hey so I have a 2023 trd sport 4x4 on a 6inch lift and 22x12. (I know it’s not liked but I’m young) anyways, the shop that installed the lift mounted my abs harness incorrectly and my abs kept coming on intermittently. I replaced the harness and the light won’t go away.. how do reset this? What can I do? I have no issues with my brakes or coming to a stop.
  10. Jun 20, 2024 at 4:48 PM
    #390
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Have you reset/cleared the codes from the computer?
    If you don’t have one, I highly recommend the Blue Driver OBD2 reader, in the interim you can go to most any auto parts store to get the codes read, some will clear the temporary codes others won’t. :notsure:
    If you drive in long enough (like 50+ miles) it might self clear, but that’s a maybe.
    BlueDriver Bluetooth Pro OBDII Scan Tool for iPhone & Android https://www.amazon.com/dp/B00652G4TS
  11. Jul 18, 2024 at 11:09 AM
    #391
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    thanks for the follow up, I just did a level lift and got an alignment and am about to do this after stumbling on this stickey after coming here to look for something else. I was wondering why the slip control dash light came on
  12. Dec 25, 2024 at 6:26 AM
    #392
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Curious why you would have to use different location?
  13. Dec 25, 2024 at 6:46 AM
    #393
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Just to verify this is 4/12 slots?
  14. May 2, 2025 at 3:08 PM
    #394
    s2kvscbr
    s2kvscbr Member
    '11 DCSB TRD SPORT
    What happens if it doesn't flash at all the 2nd time?
    2011 Tacoma TRD sport 2wd
  15. May 29, 2025 at 9:56 PM
    #395
    Orozcod
    Orozcod New Member
    Daniel
    2013 Tacoma V6 4x4 4.0
    Hello Crom is this the same procedure for a 2013 Tacoma 4x4 v6?
  16. May 30, 2025 at 6:32 AM
    #396
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Works for my 14
    Norton and Orozcod[QUOTED] like this.
