How to reset and calibrate your VSC computer - The Easy way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Dec 30, 2016.
  1. Mar 12, 2017 at 5:16 PM
    #61
    skkzhg
    skkzhg Well-Known Member
    Stephen
    North Georgia
    10-4. Thanks. Getting ready for new tires and want to avoid any issue.
  2. Mar 12, 2017 at 5:41 PM
    #62
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You won't know till you do it
  3. Mar 12, 2017 at 5:50 PM
    #63
    skkzhg
    Stephen
    North Georgia
    Hmmm... so sounds like the safest easiest route is to just reset it after the new tires. Are there any consequences to resetting it if it doesn't need to be?
  4. Mar 12, 2017 at 6:12 PM
    #64
    OZ-T
    Peter North
    British Columbia
  5. Mar 12, 2017 at 7:03 PM
    #65
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    I couldn't tell you bro, as I've yet to flash mine.. I have that first-time-phobia, lol... I'm now running a 285-70R17 with a 2.5" and it's only locked up once on me... So one more time, and it's reset-time.... Should work.
    I'll say if you had to get an alignment done, do the reset... That's just me tho...
  6. Mar 19, 2017 at 4:37 PM
    #66
    TxTacoEd
    TxTacoEd Member
    Eddie
    Texas
    2011 Tacoma TRD 4x4
    In progress...
    Had this issue after I got it aligned after i lifted it. Did this and it worked. Thanks a lot!!
  7. Mar 20, 2017 at 9:32 PM
    #67
    Longshoreman
    Longshoreman Well-Known Member
    CA.
    2013 Tacoma off road & tow package
    Toytec coilovers Fabtech uca's Dakars and 5100's in the back.
    I had zero problems resetting mine. Thanks Crom for an excellent write up!
  8. Apr 2, 2017 at 3:45 PM
    #68
    DNasty777
    DNasty777 HEATMISER
    Dave
    Rochester, NY
    '16MGMDCLBTRDS4X4
    Just swinging by to thank OP and confirm that this works on Turd Gens as well!
    Johnny DemonT and Grand dude like this.
  9. Apr 3, 2017 at 2:17 PM
    #69
    dwick37
    dwick37 Member
    SLC Utah
    2015 TRD Sport 2021 TRD PRO 4Runner (Wife's)
    Sub'd
  10. Apr 8, 2017 at 8:53 PM
    #70
    Rsamani
    Rsamani Well-Known Member
    Socal
    14 DBSB O/R 4x4
    not a lot
    Dammit, my slip indicator light just turned on after alignment.
    Will have to do this tomorrow. Hope this works on mine.
    Update: worked like a charm! Another happy member
    thank you Crom!
  11. Apr 28, 2017 at 8:44 AM
    #71
    el_turks
    el_turks Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    I been dealing with VSC issues since my lift 18 months ago. The system kicks in when at an incline and making a slight turn. Now i know how to fix it. Thank you!!
  12. May 12, 2017 at 4:52 AM
    #72
    rwilche1
    rwilche1 Active Member
    Russ
    GA
    16' TRD OR 4X4 DCSB
    Did this on my 3rd gen and had succes for about a week... now brake light, ABS light and VSC are coming on.. intermittently I may add. I put my lift on and had it aligned before the process. At first u don't suceed?
  13. May 26, 2017 at 6:13 PM
    #73
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Unbelievable! I've had my lifted Tacoma for 7 years. I always assumed that the VSC and the associated beeping/breaking when going around curves was related to tire rubbing and tripping sensors. I am literary psyched to try this tomorrow!!!
    ETA: DONE! I can't wait to take this baby on the road. I have one downhill curve where it kicks in every time. Thanks again guys. I can't believe I didn't know this for 7 years :)
  14. May 27, 2017 at 8:44 AM
    #74
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    Enjoy the new silence of taking those stubborn curbs....
  15. May 28, 2017 at 1:12 PM
    #75
    N/Es06
    N/Es06 Well-Known Member
    06 icons inchworm rotrex
    This sounds awesome, I had no idea. I've got another question related with vsc. I bought an 06 6 spd with an inchoworm transfer case. The t-case allows me to be in 2wd lo range, 4wd lo range, 4hi and 2hi. The front hubs are now on there own seperate switch that allows me to engage or disengage in any gear range. So if I'm in 4lo going up a hill and i need to turn sharp I can unlock the hubs to avoid binding while staying in lo. I also have the ability to turn on my rear locker independently. When I am in 2wd I can also activate my front hubs, at least the light comes on indicating that they are. My question, or concern, is this. When i am in 2wd and i engage my front hubs, the (vsc) light comes on. No abs, no truck with squigly lines or any other lights, only the letters (VSC). Theoretically this means i should be able to have a little fun in the dirt. How much stress would I be putting on my front hubs? What speed would determine too fast? 2wd, vsc light on, front hubs enguged light on WTF? I suppose this question is more about front hub stress and top speed for the hubs themselves. But I'm also curiouse to know what the lone vsc light is actually indicating.
  16. May 30, 2017 at 5:54 PM
    #76
    N/Es06
    Has anyone ever only done step 1 without doing step 2? If so what happens?
  17. Jun 15, 2017 at 10:42 PM
    #77
    N/Es06
    I did this. Didn't notice much change, and today I went to down shift while going around a curve on the freeway when my vsc kicked in. I was NOT acting like a jack ass. It seamed like it was my front driver only...or mostly and I was turning left (driver). What did I do wrong? Could this be an alignment issue or something with the steering? Just asking cuz I recently noticed that my truck turns sharper passenger than driver. My front passenger rubbed on the frame and lower control arm just below the frame while the driver side had an inch of clearance between the tire and frame.
    I take this curve the same everyday and this is the only time it's done it. I did the reclaibration last week.
  18. Jun 15, 2017 at 11:51 PM
    #78
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    I've had an issue where it feels like the outside tire on a curve wants to pull the steering back to straight. It is almost like it pulses with the rotation of just that tire. I was convinced it was a bearing going bad, but It doesn't do it on every turn, and happens turning in both directions.
    N/Es06 likes this.
  19. Jun 17, 2017 at 7:48 AM
    #79
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    I cant get mine to clear.the abs light flashes but the slip light never does.
  20. Jun 17, 2017 at 10:15 AM
    #80
    Train
    Train Loco with a motive
    Train
    N46°24'54" W81°01'48"
    2013 -Tacoma access cab 4x4
    Chop chop chop weld
    A1 first try
    Thanks
