How to Reset Check Engine Light???
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaGRG, Apr 7, 2010.
  1. Apr 7, 2010 at 8:55 AM
    TacomaGRG
    TacomaGRG [OP] Well-Known Member
    Greg
    Danvers, MA
    09 SR5
    Westin Stainless Bull Bar Flowmaster 50 Dual Exhaust 17" FJ Cruiser Wheels Socks Devil Horn 3rd Brake Light Cover STK Pro Rack Carriage Works Black Billet Grille w/Devil Horns Stubby Antenna Avid Rocker Guards Rear Leaf TSB Rear Bilstein 5100s Front Bilstein 5100s @ 1.75 AFE Air Filter
    A friend of mine has a first gen with over 150k miles on it and is trying get get a inspection sticker without putting in the over $2000. in work the truck needs. Do any of you guys know how to rest the check engine light? I heard that if you disconnect the battery for a while it can work but any other suggestions would be much appreciated.
  2. Apr 7, 2010 at 9:19 AM
    98tacoma27
    Ben
    Not Beech Creek
    Disconnect battery or using a scan tool
    That will not gaurantee the CEL will not illuminate after the first two trips however.
  3. Apr 7, 2010 at 9:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    I think you can pull the EFI fuse also. That would save him from resetting his radio presets.
  4. Apr 7, 2010 at 9:52 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Fix it the right way.
    If it's a serious problem, then even if you reset it, it will most likely come on immediately. Some things take a while to register so you could probably go a few miles without it popping back on, but the inspection people most likely know all the tricks, so I wouldn't waste the time.
    But yeah if you get a scan tool (I bought one for my computer at scantool.net), you can manually reset the light. I HAVE done it once on a minor code that never came back, though...
  5. Apr 7, 2010 at 11:26 AM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Thanks for the info. He thinks its the catalytic converter and will probably cost more than the truck is worth.
  6. Apr 7, 2010 at 11:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    I take it it's code P0420
  7. Apr 7, 2010 at 4:03 PM
    sachou
    Sam
    o2 simulator. Google it. Costs about $100.
