How to reuse factory fog light harness?
Discussion in 'Lighting' started by Tim 2011 DC, Mar 8, 2012.
  1. Mar 8, 2012 at 8:19 AM
    Tim 2011 DC
    Tim 2011 DC [OP] Member
    Virginia
    2011 Double Cab 4X4
    My electrical knowledge is limited.
    I am getting a front plate bumper so will be loosing my factory fog lights. I would like to use the wiring harness and switch that is already installed to wire new lights.
    I plan on doing the "Anytime Foglight Mod" to make these work whenever, but what should I be looking for in terms of the type of light? I was thinking of LED's as they draw less power, but again, my electrical knowledge is limited.
  2. Mar 15, 2012 at 10:57 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I don't know the wattage of the factory fogs, but you could always use the factory harness to trigger an aftermarket light setup instead of directly powering them. That would allow you to run whatever you want and still use the factory switch.
  3. Mar 15, 2012 at 11:08 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    X2 ^^
  4. Mar 15, 2012 at 11:18 PM
    joes06tacoma
    Joe
    Central Coast, CA
  5. Mar 15, 2012 at 11:38 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    OEM lamps are standard 45w H10 lamp.
