How to rewire third brake light?
Discussion in 'Tonneau Covers, Caps and Shells' started by Ccrames2018, Sep 19, 2019.
  1. Sep 19, 2019 at 11:19 AM
    Ccrames2018
    Ccrames2018 [OP] Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    Has anyone rewired a 3rd brake light on a used shell? I'm trying to decide how I want to do it and I'm thinking I'll just tap into the driver's side brake wire and the two wire pieces that are left, and use those friction fit connectors so I can remove the shell and tail lights still. Does this sound like it would work?
    I'll post pics once I can.
  2. Sep 19, 2019 at 5:02 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I bought my shell used. I bought the leer wiring harness to make the install easier. For the 3rd brake light it's just tapped into the driver's brake light.
    Ccrames2018[OP] likes this.
  3. Sep 19, 2019 at 5:04 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
  4. Sep 19, 2019 at 5:06 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Need an extra fused hot wire from the battery for the cap light.
  5. Sep 19, 2019 at 5:08 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
  6. Sep 19, 2019 at 11:38 PM
    HawkShot99
    Kingston, NY
    This is true. I didnt bring that up as he only asked about brakes.
  7. Sep 20, 2019 at 12:36 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Yeah I don't have the inside light, just the brake light. I just tested the wires to see which ones to tap into and soldered some connectors on between the shell and bed so I can take the shell off if I need to. Still trying to figure out the best way to keep the wires out of the way though
  8. Sep 20, 2019 at 11:42 AM
    HawkShot99
    Kingston, NY
    Have the wires hang down out of the shell slightly. Pull the tail light and have the connection back behind there.
  9. Oct 2, 2019 at 7:03 AM
    flyby
    flyby Well-Known Member
    Ohio
    14 DCSB 4x4
    I used an e-trailer.com plug & play wiring harness so I didn't have to tap into the factory wiring and it could be easily removed later.
    https://www.tacomaworld.com/threads/help-with-wiring-on-a-new-to-me-leer-shell.569853/#post-19144132
    I also bought some three-pin quick disconnect plugs, I was ran the wiring through a small gap in the bed (with a couple layers of heat-shrink tubing in this spot for rub protection) so I didn't have to drill, and installed those disconnect plugs in the bed.
    With the cap removed I'd have a 6" wire dongle at the top of the bed rail.
    I'll ship you a quick-disconnect plug and the other half of my taillight harness if you want to cover the cost of shipping. I didn't wire my dome light, so I'm not sure if there's constant power at the taillight or not.
    https://tinyurl.com/y53ednhq
    https://tinyurl.com/y5ez4btk
  10. Oct 2, 2019 at 7:34 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    My ARE came with one of those cheap AA battery powered lights which the cover fell off of after maybe two years. I've had one of those blue, free with any purchase Harbor Freight LED lights in the back now for years. Put the hook side of some sticky backed Velcro on the light and stick it to the carpet. I used a small hole punch to put holes in the Velcro where the screws are so I can change the batteries when needed. It works better than the piece of crap that came with the shell and I can move it if I need to.
    I've got a second one of those free lights stuck to the metal part of the bed near the tailgate.
  11. Oct 2, 2019 at 9:16 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Thanks for the ideas! I already have the brake light wired but I think I'll do the battery powered dome light. That's a great idea!
  12. Oct 2, 2019 at 11:14 AM
    HawkShot99
    Kingston, NY
    I usually need to get light in the bed in the winter(summer its light out way longer) and got tired of cold batteries not wanting to work. Originally I had a battery light attached to the roof of the cap. Other problem I had was that I have a unfinished interior. Hard to get stuff to stick to the fiberglass for extended periods of time.
