How to rotate tires?
Discussion in 'Wheels & Tires' started by Hublocker, Sep 19, 2016.
  1. Sep 19, 2016 at 11:29 AM
    Hublocker
    Hublocker [OP] Well-Known Member
    I have a set of BFG KO2 tires with about 10,000 km on them that I've had off for the summer and want to rotate them from the positions they were in when I put them back on.
    My mechanic who I trust says he just swaps the front tires with the rear on the same side.
    I always thought the correct way was to move the rear tires forward and take the front tires crossways to the rear.
    What do you do?
  2. Sep 19, 2016 at 11:29 AM
    Croth51
    Croth51 Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Always do an X pattern
  3. Sep 19, 2016 at 11:30 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Front to back and back to front.
    Added - I align once a year (or as needed if I hit a hole/bump hard) and have never had a set of tires wear prematurely.
  4. Sep 19, 2016 at 11:31 AM
    twhalm
    twhalm Well-Known Member
    Denver, CO
    2015 TRD/OR Manual, OME , Dual battery
    Well that settles it then. Good luck with the rotation.
    vicali and bluedevils9 like this.
  5. Sep 19, 2016 at 11:32 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Just to confuse you more, I put rears on the front then front to rear but switch sides. This way each tire gets a shot at every corner, for what that's worth, my OCD felt that was the best. Definitely the best. Definitely.
    Edit: Just re-read your post now that my coffee has kicked in and we're doing it the same way :cheers:
    airmax233 and Jester243 like this.
  6. Sep 19, 2016 at 11:33 AM
    ColoradoPacific
    ColoradoPacific Custom Title
    Centennial State
    Silver TuRD
    ***COMPLETED MODS*** SUSPENSION -Total Chaos UCAs -King 2.0" RR Coilovers w/650# springs -OME Dakar leaf pack -King 2.0" RR shocks -Archive Garage Shackle Flip -Front Range Off Road U-Bolt Flip Kit DRIVETRAIN -URD Short Shifter ARMOR -Pelfreybilt Front Bumper, Steel -Pelfreybilt Full Skid Set, Aluminum -Adventure Off Road High Clearance Rear Bumper -Front Range Off Road E-Locker Skid LIGHTING -Rigid Dually Fog Lights -Rigid 40" SR-2 -Rigid SRQ Backup Lights -AntiDark Underhood LED Strip ACCESSORIES -Safari snorkel -SLEE dual battery tray w/ 2x Interstate MT7-75DT -BajaRack -Custom Bed Rack (Adventure Off Road) -Rubber bed mat (Toyota) -Fender flare delete -Center console 120V outlet -Center Console Vault (TruckVault) -CB Radio -Ham Radio -YETI Bottle Opener -WaterPort shower system -MaxTrax -Hi Lift ***FUTURE MODS*** Re-gear to 4.56 Nitto Ridge Grappler 35s Magnusson Supercharger VIAIR onboard air system 20 gal aux fuel tank
    I've gone 40K miles without rotating without ever having an issue. As long as your alignment is okay, I'm honestly not convinced that it matters. Rotate them however you want! Or be a bad owner like me, and just don't do it LOL!!
    airmax233 likes this.
  7. Sep 19, 2016 at 11:46 AM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I never did on my Porsche or BMW. They never had any issues. I'm rotating now because it's free.
  8. Sep 19, 2016 at 3:19 PM
    Stakoner
    Stakoner Well-Known Member
    Santa Cruz ca
    2013 Dcab 4x4
    Alot
    Front to rear and rear to front no crossing.
  9. Sep 19, 2016 at 4:27 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Manual says front to back, back to front, no cross of tires.
    But ya'll know more than Toyota.
    JNG, Beauxdon and BigMike like this.
  10. Sep 19, 2016 at 4:28 PM
    Stakoner
    Santa Cruz ca
    2013 Dcab 4x4
    Alot
    Exactly!
  11. Sep 19, 2016 at 4:31 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    rear to front, front's to opposite rear position is the most common method
  12. Sep 19, 2016 at 5:27 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    LF to LR, LR to RF, RF to RR, RR to Spare, Spare to LF. 5 tire rotation for the win.
    TA-5650, Bluegrass Taco, Sna and 2 others like this.
  13. Sep 19, 2016 at 5:33 PM
    Bishop84
    Bishop84 Well-Known Member
    This is how I do it at work with customers Tacos and Tundras
    P metrics, front to rear, no cross rotate.
    LT tires, front diagonal to rear, rear to front.
    M/T or feathered LT tires, diagonal front and rear.
    I just did a reverse rotate on a taco with Derek Cepeks M/T and did it ever freaking howl on the test drive, its hard to explain to customers that its a good thing to reverse rotate, as the first 2 days after are loud as hell.
    The biggest thing is to just rotate often, especially BFG's they wear like crazy if left in the same spot.
    Sprouty115 and Dave41079 like this.
  14. Feb 4, 2018 at 12:23 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Necro-bump:
    My cars usually had directional tires, so I always rotated front to back, and back to front. I did the same with my Terra Grapplers on my truck and never had an issue. I did the same for the first 30k on my S/T Maxx tires, then tried the back to front, and front crossing to back. The tires got loud after that.
  15. Feb 4, 2018 at 12:32 PM
    replica9000
    2019 T4R ORP
    I need to have my alignment checked, as my front tires have a slight \ / stance.
  16. Jun 6, 2019 at 3:02 PM
    Dex__43
    Dex__43 Well-Known Member
    Sam
    KCMO
    09 DCSB TRD OR 4x4 Swap
    4x4 Conversion 2.5 inch lifts with 33's Sliders Skids Front Runner racks Satoshi grill Patches and Stickers BAMF hybrid front HC tube rear Light bar 2 Hella's behind the grill Pioneer media player and subs Sleeping platform with lower storage for the bed
    I move the rear tires straight forward and the front tires crossed to the back
  17. Jun 29, 2019 at 7:48 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    First a Porsche or bmw is not a truck. Secondly most of them run different width wheels front and back so they can’t be rotated any way. My truck I just go front to back no issues.
  18. Jul 1, 2019 at 1:21 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    This.
    Just did mine this morning
  19. Apr 30, 2021 at 1:00 PM
    Ajlawson2
    Ajlawson2 Member
    Aj
    2012 MT AC LB
    Thanks for this thread!
  20. Apr 30, 2021 at 1:00 PM
    Ajlawson2
    Ajlawson2 Member
    Aj
    2012 MT AC LB
    And thanks for the written directions!
