how to rotate top strut /ready lift kit
Discussion in 'Suspension' started by jlcnj, Sep 5, 2009.
  1. Sep 5, 2009 at 5:08 AM
    jlcnj
    jlcnj [OP] Member
    08 4x2 sr5
    Hi
    I'm installing ready lift kit 5510 on my 5lug , how do I rotate the
    the strut 120 degrees so it reinstalls correctly ?
  2. Sep 5, 2009 at 5:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'm under the assumption you have a similar coilover design as the 6 lugs....
    So, with that in mind, I'm going to say - you have to compress the coil enough so you can rotate the top plate.
  3. Sep 5, 2009 at 5:29 AM
    jlcnj
    jlcnj [OP] Member
    08 4x2 sr5
    Thanks ,how do I do that?
  4. Sep 5, 2009 at 6:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You can use a long (6" or longer) 3/8" socket extension, and by inserting it into the lower shock bolt hole, you can rotate the shock to the propper orientation.
  5. Sep 5, 2009 at 6:05 AM
    Janster
    Jandy
    Lancaster, PA
  6. Sep 5, 2009 at 6:20 AM
    jlcnj
    jlcnj [OP] Member
    08 4x2 sr5
    Thank you janster,Will the bottom of the shock just twist if I try and turn it ? mine seems to not want to twist the 120 degrees I need to turn it.
    By the way ,I'm a cabinet maker by trade so pardon my lack of knowledge
    on this stuff . Do I need coil spring clamps to releive pressure before this
    thing will twist?
  7. Sep 5, 2009 at 6:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It will twist. See my post above.
  8. Sep 5, 2009 at 6:45 AM
    jlcnj
    jlcnj [OP] Member
    08 4x2 sr5
    Chris,
    Hate to sound like a whimp but I tried your Idea and the bottom
    of the shock will not budge. should I spray some lube at some points?
    Will I break the shock by trying to force it to twist ?
  9. Sep 5, 2009 at 6:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmm.....Dont force anything. Do it the way Janster mentioned.
  10. Sep 5, 2009 at 8:59 AM
    jlcnj
    jlcnj [OP] Member
    08 4x2 sr5
    Thank you all , Finally got it to twist using a longer bar and a little lube down at the bottom of the coil spring , I did not have coil compressor tool,
    which would have made life much easier. I sure wish "Ready lift kit"
    instructions and there video would have reviewed this step , they skiped
    right over it completly!
  11. Sep 5, 2009 at 9:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear! :)
  12. Aug 13, 2016 at 7:21 PM
    dgrover
    dgrover Member
    Doug
    Virginia
    White 2006 2.7 Gen 2
    Blacked out badges, toolbox, tint
    You would think that Ready Lift would have included that into the video. That is definitely a step that would have helped a lot to see in the video.
  13. Aug 13, 2016 at 7:27 PM
    sogafarm
    sogafarm Well-Known Member
    GA
    2012 tacoma reg cab spruce mica
    K&N, 31" goodyear wranglers, fat bobs lift, mud accents
    I had the same prob with the fat bobs lift on mine. Read on TW to mount the upper strut loosely tighten nuts, then use some sort of long bar to insert on the lower eyelet to use for leverage to twist to the right position. Worked for me. I think the lube idea would have been helpful.
