How to safely haul 12’ lumber?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JamesR, Aug 12, 2024.
  1. Aug 12, 2024 at 3:22 PM
    #41
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Since no one has mentioned it, there is also the option of strapping them to the roof. In any case, unless you are doing this on a regular basis or driving across the country, I suggest you invest in nothing more than straps/rope and a red flag.
    The best solution is a trailer, but not a good investment if you are only doing this once (albeit you can probably rent one relatively cheaply).
    Barsoom likes this.
  2. Aug 12, 2024 at 4:14 PM
    #42
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    i mentioned it, sorta :)
    if using the roof as a bearing surface, use blankets and be sure you don't dent the tinfoil they use these days. strap it mostly to keep it from shifting side to side. with very long wood, i have tied down the leading edge to the front bumper, not very forcefully to not dent anything, to keep the wood from rising to catch air.
    i agree, if infrequent, for 12 foot, all you need is straps/rope and red flag (and a brain).
    everything else is toys. though, nothing wrong with toys. i am tempted to get HF extender just because it is cool and cheap and i might actually use it someday. imagine the pantie drops!
  3. Aug 12, 2024 at 4:21 PM
    #43
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Yup. I drove about a half hour and was extra cautious.
  4. Aug 12, 2024 at 4:22 PM
    #44
    JamesR
    JamesR [OP] Well-Known Member
    James
    Northeast PA
    2022 Tacoma Sport DCLB, Barcelona Red
    Its my sisters beach house and they have zero tools there, and no good place to do any sort of work. Also 90 miles from home. So I don't want to have to go back and forth for the build. Plus..... with no tools, I'd probably forget to bring something important if I had to lug my stuff down there. I'm more comfortable and efficient in my own work area when it come to stuff like that. I bought the hitch mount bed extender today. I can always use it for kayaks and paddle boards also now.
    Picked up ratchet straps, red flag and some extra D-Rings also. Tomorrow morning, I pick up the wood from the lumber yard.
    Barsoom and Schlappesepple like this.
  5. Aug 12, 2024 at 5:09 PM
    #45
    BillyE
    BillyE Well-Known Member
    I’ve done this with a short bed. More than once.
  6. Aug 12, 2024 at 5:59 PM
    #46
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Flags? I use them reddish shop towels.
    At HD they used to provide red plastic flags but I haven't seen them in a while. Maybe, gotta ask for them now.
    JamesR[OP] and Barsoom like this.
  7. Aug 13, 2024 at 5:39 AM
    #47
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Back in the day, when roof gutter's were used, canoe racks used to haul most anything, one could lift that high. I've used a single section of a aluminum ladder on the bottom as a base supporting longer loads. B.T.W. I have heard... if, you had a 1985 Chevy Citation hatchback, slide the front seats all the way forward, remove the headrest's, lay the back seat down, one could haul 4x8' O.S.B. with the hatch tied and driver scrunched down peeking over the dashboard...
    atc250r and Barsoom like this.
  8. Aug 13, 2024 at 5:52 AM
    #48
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    You got this! This was pretty sketchy but I got it 10 miles home, the next time I used one of the trailer hitch bed extenders and it was much better.
  9. Aug 13, 2024 at 6:06 AM
    #49
    JamesR
    James
    Northeast PA
    Well that was easy!
  10. Aug 13, 2024 at 6:17 AM
    #50
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Well done OP! You won't regret buying that bed extender. You only need it when you need it! It really does make hauling long load so much safer in these short beds! :)
    Barsoom likes this.
  11. Aug 13, 2024 at 6:24 AM
    #51
    JamesR
    James
    Northeast PA
    Made it home and nothing fell out along the way. :cheers:
  12. Aug 13, 2024 at 6:32 AM
    #52
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Those extenders are worth every penny. And easier to store than a trailer.
    shakerhood likes this.
  13. Aug 13, 2024 at 11:37 AM
    #53
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    You might want to do some additional fastening before the "long trip".
    Suggest besides the strap over the top of the lumber...
    Get some bungee cord and wrap around the lumber and the and extender as well as at the d ring attachment.
    Your load could still slide backwards with the way you have it tied down.
  14. Aug 13, 2024 at 12:03 PM
    #54
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Agreed. Boards flapping separately instead of bound as a single-mass is not good. And using some method (nails in the boards and ropes wrapped around those nails?) to prevent movement is good.
  15. Aug 13, 2024 at 12:07 PM
    #55
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Y'all, the tie-down in the truck is cinched around the wood, and the ends of the boards are wrapped in shipping plastic. Wrapping a bungee cord around there isn't going to add crap.
    Based on what we've seen in this thread alone, OP has secured this load better than 75% of what's on the road. It's fine.
    And again, the finished raised bed will be easier to tie down, and generally more secure as a big box vs. the bundle.
    Barsoom likes this.
  16. Aug 13, 2024 at 12:16 PM
    #56
    JamesR
    James
    Northeast PA
    Good eye! Yes, the bundles were shrink wrapped together and I did the “wrap around” on the ratchet strap in the back of the bed. I yanked pretty hard on the bundle. It did not budge. The trip was just 6 miles from yard to my house also. But, yes.. additionally fastening can never hurt.
    Barsoom and atc250r like this.
  17. Aug 13, 2024 at 4:24 PM
    #57
    AustinNative
    AustinNative Swollen Member
    ATX
    2017 MGM TRD Sport DCSB
    Maxtrac spindles OME 885s Bilstein 5100s all around (adjustable front/extended length rears) Maxtrac rear blocks Headstrong Taco lean spacer OME CBD SS brake lines InsaneFab CMC 18x12 Fuel Hostage 35x12.50 Maxxis AT 1.25" Spidertrax spacers in the rear Llumar Ceramic Tint (5% Rears & Back / 18% Fronts / 50% Windshield) Toyota Tri-Fold bed cover and OEM bed mat Triple Black Clazzio seat covers WeatherTech laser fit or whatever the fuck they call em Probably other stuff...
    DCSB here. This is my go-to method, done it countless times. Add a strap around the boards to the hooks behind the folded down rear seats to stop the side to side shimmy.
    atc250r[QUOTED] likes this.
  18. Aug 14, 2024 at 1:49 AM
    #58
    Vmax540
    Chuck
    Clarion PA.
    Unless one does jack rabbit starts, loads tend to shift forward.
    Schlappesepple likes this.
  19. Aug 14, 2024 at 4:17 AM
    #59
    MDA57
    MDA57 Well-Known Member
    Mark
    Durham,NC
    2022 TRD OFFROAD Army Green /1997 4Runner
    NONE yet
    If you own a extension ladder stop ladder down to bed near cab extend it to 10 foot rest on closed tailgate 8-2x4 is much weight
    load them on ladder and strap to bed strap down spots mark with red flag and drive safely
    FunknNasty likes this.
  20. Aug 14, 2024 at 11:04 AM
    #60
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Did you do any wheelies when taking off from a stop. LOL
