How to siphon gas tanks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, Feb 21, 2022.
  1. Feb 21, 2022 at 9:41 AM
    vijay
    vijay [OP] Well-Known Member
    What is a easy way to siphon a tacoma gas tank? I know someone posted instructions on using the relay (shorting it or something) but no video or pictures ;(
    In case you are wondering: My truck hardly gets used and it now has fuel that filled up ~a year ago. I did add fuel stabilizer and it was topped off. I do not plan on using it atleast until Nov of this year, so I need the old fuel removed and refreshed.
  2. Feb 21, 2022 at 9:47 AM
    Bishop84
    Bishop84 Well-Known Member
    Basically you need to command the fuel pump on, with a scan tool or by passing the fuel pump relay.
    Easiest way to by pass the fuel pump relay is remove it and jump the two large pins with a wire.
    Next you need to disconnect the feed line to the engine, its near the oil fill cap, its 2 fuel hoses joined by a black plastic holder, you remove the forward one.
    Stick a long hose from the hard line to a jerry can, by pass relay, turn key on.
    No pictures, this isn't very common to do.
  3. Feb 21, 2022 at 9:50 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
  4. Feb 21, 2022 at 9:52 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you can find a place to disconnect the fuel line and hook a hose to it you can jump power to the Black/Red wire at the fuel pump resistor to run the pump.
    It is located right in front of the battery.
    vijay[OP] likes this.
  5. Feb 21, 2022 at 9:53 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I was wondering if there was a way to change the gas in your Tacoma.
  6. Feb 21, 2022 at 3:13 PM
    vijay
    It looks like the relay for taco has 5 leads like this. So, which of these should I connect via a wire?
  7. Feb 21, 2022 at 3:15 PM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    I always liked the Georgia credit card....6 feet of garden hose.
    SocalTaco15 likes this.
  8. Feb 21, 2022 at 3:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Neither, do as @Dm93 said in the above post.
    Jump it at the resistor wiring. It will be easier and you don’t risk messing up the terminals in the fuse box.
  9. Feb 21, 2022 at 3:22 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Isn't there a drain plug on the tank? Most vehicles have them.
  10. Feb 21, 2022 at 3:28 PM
    TnShooter
    Deogee
    STOCK
    Not unless you make one. :eek:
    You have to jump the fuel pump, or remove the tank.
    Jumping the pump wire seems a like a lot less work:thumbsup:
    tcjacado likes this.
  11. Feb 21, 2022 at 3:30 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    You are joking right? Yes to the radiator, engine, transmission but not the fuel tank.
  12. Feb 21, 2022 at 3:33 PM
    stevesnj
    My Land Cruiser has one. Not joking.
    boston23 likes this.
  13. Feb 21, 2022 at 3:34 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No they don't, I've never seen a drain plug on an automotive fuel tank.
    Some tractors and 18 wheelers do but not cars and trucks.
    69 Jim likes this.
  14. Feb 21, 2022 at 3:40 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I think the easiest way would be to pick a weekend and drive it.
    :cookiemonster:
  15. Feb 21, 2022 at 3:40 PM
    stevesnj
    Just searching around, BMW, Mazda, Mitsubishi have fuel tank plugs on some models.
  16. Feb 21, 2022 at 3:45 PM
    Bishop84
    I've seen drain plugs on tanks 100%
    That said, tacoma does not.
    MGMDesertTaco, tcjacado and stevesnj like this.
  17. Feb 21, 2022 at 3:46 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I've yet to see one exept a few 60s and 70s vehicles with metal tanks.
  18. Feb 21, 2022 at 3:47 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Exactly. Go on a long picnic or something. Plus leaving the truck for that long without driving? That's a recipe for problems.
  19. Feb 21, 2022 at 3:48 PM
    stevesnj
    Mine is a 96. Just wonder if they just stopped them or just certain Toyotas had them.
  20. Feb 21, 2022 at 3:51 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd imagine the biggest reason to not have one is to make it non trivial to steal fuel.
