How to Stop Automatic Transmission Downshifting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gcopmt, Sep 12, 2018.
  1. Sep 12, 2018 at 3:25 PM
    Gcopmt
    Gcopmt [OP] New Member
    2018 Tacoma TRD Off Road
    Is there any way to keep the transmission from downshifting in S Mode, or otherwise? I live and drive in the mountains and the huge jumps in downshifting over passes is a pain. Is there any way to be able to lock the tranny in a gear so you can step on it on the uphill without a lurching downshift? This is an especially big problem when towing our drift boat.
  2. Sep 12, 2018 at 3:34 PM
    InsuredToyota
    InsuredToyota Well-Known Member
    Southern California
    2018 TRD OR 4x4 DCSB
    Truxedo Truxport Tonneau cover OEM bed mat.
    Try ECT. Or a manual tranny!
    fdbyrne, BassAckwards and dakotasyota like this.
  3. Sep 12, 2018 at 3:38 PM
    Gcopmt
    Thanks. I wanted a manual but its not available in 6' bed.
    InsuredToyota likes this.
  4. Sep 12, 2018 at 3:59 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    You can shift the automatic transmission up or down (+or-) manually in S mode to keep it in a gear and prevent it from upshifting thus allowing you to keep the engine in its power band and preventing it from downshifting when not desired.
    There is a video done by Toyota on YouTube demonstrating steering wheel mounted paddle shifting of an automatic transmission in a Camry.
    It also shows and states that the automatic transmissions with floor shifter can be shifted the same as a vehicle with the paddle shifters.
    The Tacoma transmission is a manumatic.
    And yes I know it’s not fully described in the owners manual so people will disagree.
    The Toyota video shows that they can be utilized in that manner.
    It works well. Try it out.
    If you start out in 1st gear in S-mode, you can hold each gear as long as you desire while shifting upward, just like a manual transmission, only without the clutch.
    And additionally, you can downshift manually as desired as you slow down, and finally come to a stop in 1st gear.
    I’ve driven a lot of manual transmissions over the years.
    Yes it’s not a manual, but it works well shifting manually.
  5. Sep 12, 2018 at 4:03 PM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Its not a manumatic. Not at all. You are only setting the max gear you want it to be in. If you set it to S5 it can still be in first gear. Yes you can simulate shifting, especially if you constantly move it + at high revs and - at low revs, but dont mislead people.
    bruv, daddy_o and InsuredToyota like this.
  6. Sep 12, 2018 at 4:06 PM
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    Gas pedal - don't baby it. 3.5 does well in high RPM situations.
  7. Sep 12, 2018 at 5:26 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    If the truck thinks it's going to stall, it will shift no matter what. Unless it's a manual
  8. Sep 12, 2018 at 5:34 PM
    Syncros
    Syncros Well-Known Member
    Not possible, is why I own a manual. I sacrificed cab room for bed length.
  9. Sep 12, 2018 at 5:41 PM
    Phaze2Yogi
    Phaze2Yogi Well-Known Member
    Daniel
    Los Angeles, CA
    Inferno 2017 Tacoma TRD Off-Road
    Speed Booster by Digipower. I set it on the "Track Mode" and I'm now able to drive at 65-70 at the highest gear without it gear hunting.
    Im on 33's, stock gearing and a lot of weight.
  10. Sep 12, 2018 at 5:43 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Leave it in s4 in the hills.
  11. Sep 12, 2018 at 6:11 PM
    Anchovy
    TRD Ferguson
    Or you could get OVTune and not have to worry about anything else
  12. Sep 12, 2018 at 6:25 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    TRD sport has access cab 6' bed manual, and SR 4X4 did 2016/2017.
    If you are talking double cab long bed then yes no manuals. Which is a bummer.
  13. Sep 12, 2018 at 6:26 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Or you could just use the features the truck came with (S4) and save $800.
    phsycle, TacoCon and StayinStock like this.
  14. Sep 12, 2018 at 6:47 PM
    Anchovy
    TRD Ferguson
    You've never had the pleasure of having OVTune, you not only are able to cruise through hills in 5 or 6th gear, but you also gain more torque and power in the mid range rpms and a lot of people report getting better fuel economy
  15. Sep 12, 2018 at 6:55 PM
    Lt. Dangle
    Ohio
    You're right, I haven't used the tune. I haven't felt the need. What I do know is a lot of people with the tune from OV that have also recieved the new TSB from Toyota reported that they probably wouldn't have bought the tune if the truck had come with the new TSB from the get go. I'll try that first and save myself some money.
    I'm a big fan of the tune from Matt so don't get me wrong, but I tow frequently with my truck and none of the advantages you have listed have ever been a concern for me. In regular driving my truck goes through hills in 5th and 6th gear now... I mean mostly 5th, but...
  16. Sep 12, 2018 at 7:09 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Access Cab Sport yes.
  17. Sep 13, 2018 at 2:03 AM
    Anchovy
    TRD Ferguson
    The extra torque would help with towing
  18. Sep 13, 2018 at 4:42 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    Have you applied the most recent ECU update which addresses Trans Shift points, throttle mapping, etc?
    If not you should, I tow up mountains every month. This update changed my truck dramatically. Let me find the thread.... this is no BS, it really improves the drivability of the truck across the board.
    Here it is.
    https://www.tacomaworld.com/threads...tion-tsb-0062-18.559435/page-84#post-18684875
  19. Sep 13, 2018 at 4:50 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    Thread title could use a question mark. I thought the OP had a new fix idea.
    Stocklocker likes this.
  20. Sep 13, 2018 at 4:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    ^^^ This.
