how to stop lock/unlock beeping
Discussion in '1st Gen. Tacomas (1995-2004)' started by shampoop, Aug 2, 2010.
  1. Aug 2, 2010 at 9:27 PM
    shampoop
    shampoop [OP] Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    searching found nothing for 1st gens
    i have an 03 with the basic 3 button remote (lock and unlock on front, panic on back) and i was wondering how to get rid of the beeping. it's obnoxious.
  2. Aug 3, 2010 at 7:12 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I don't like it either prefer the horn or a cherp.
  3. Aug 3, 2010 at 9:20 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    i think if you hold lock and unlock down for like 5 seconds at the same time it disables it
  4. Aug 4, 2010 at 9:06 AM
    FightFire48
    FightFire48 Taco Monster
    Will
    Spokane, WA
    04 Taco dbl cab
    3" Toytec lift AEM BruteForce CAI Gibson exhaust 2 - Rockford Fosgate 8's
    [Actually there is a plug that you can disconnect from the pizeo (i believe that is what is called) and you lose the noise only. So your lights still flash and your doors still lock. I did this mainly because when i go hunting don't really want that sound. It is located on the driver side under the hood next to the battery. It looks like a filter of some sort. Hope this helps
    Here is a picture thanks to Expeditions West
  5. Aug 4, 2010 at 11:00 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    yup, just take the buzzer out.
  6. Aug 4, 2010 at 5:00 PM
    scriber007
    scriber007 Well-Known Member
    i unpluged the piezo too. But do you know how to silence the horn when locking and unlocking.
  7. Aug 4, 2010 at 6:31 PM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Don't have a horn beep on my 04, rather have that then the piezo.
  8. Aug 4, 2010 at 7:09 PM
    shampoop
    southwest WA
    sweet! thank you! :) i tried holding both buttons for 5 seconds and it didn't work. my 03 doesn't honk either. just beep and flash. i like the flash to confirm you actually locked/unlocked successfully.
  9. Aug 4, 2010 at 7:39 PM
    747 function > form
    1st Gen.
    I have been trying to figure this one out for years (literally)...I know I've posted at least once, without reply. Disconnected the piezo and voilà, problem solved...you're the man, Will! +1
  10. Aug 9, 2010 at 8:59 AM
    FightFire48
    Will
    Spokane, WA
    04 Taco dbl cab
    Not a problem guys and yeah i dont have my horn hooked up to it. Sometimes i forget that i locked it or unlocked it due to the fact that i can't hear it anymore lol! But when i'm hunting no more worries ever of that terrible beep!
  11. Oct 28, 2010 at 6:37 AM
    Mrksouth
    Mrksouth Member
    Florida
    07 PreRunner
    My 07 uses the horns. I tried to unplug one and then the other. There must be one relay that kicks of the horns.
  12. Oct 28, 2010 at 10:42 AM
    BurritoJimmyFan
    BurritoJimmyFan Well-Known Member
    Frisco, TX
    04 Ext Cab TRD
    Gray Wire Mod, DRL Mod, Deckplate Mod
    have an 04, and it uses the horn. If anyone knows how to disable it, please post instructions. I can't stand it.
  13. Oct 29, 2010 at 4:04 AM
    Mrksouth
    Mrksouth Member
    Florida
    07 PreRunner
    Well I just found the fix. I have a small module under that dash. It has a LED and switch called the valet switch.
    1. Turn the ignition on and then off
    2. Within 10 seconds of turning the key off, press and release the valet switch 3 times.
    3.
    a. If before proceeding with step 1, the chirps were on, then you will hear 2 chirps to indicate that the chirps have been turned off.
    b. If before proceeding with step 1, the chirps were off, then you will hear 1 chirp to indicate that the chirps have been turned on.
    c. If the unit emits 2 chirps, regardless of your action based on the above instructions, the chirps have been eliminated in the units feature selections.
  14. Oct 29, 2010 at 6:24 AM
    markveneris
    markveneris Well-Known Member
    mark
    germany
    I have also been looking about how to turn off that infernal beeping. I unplugged the wire (I had seen it before but did not think that was the source) thank you. I will try the other way later. I am just so happy that i dont beep anymore.
  15. Oct 30, 2010 at 11:34 AM
    BurritoJimmyFan
    Frisco, TX
    04 Ext Cab TRD
    Thank you so much. I followed this and it went from: horn+chirp+lights, to chirp+lights. I'll leave it there for now. The horn was so annoying!
