How to stop Seatbelt beeping
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hopewell78, Feb 1, 2021.
  1. Feb 1, 2021 at 5:26 PM
    Hopewell78
    Hopewell78 [OP] New Member
    Is there anyway to bypass the beeping when seatbelts are not buckled up?
    Junkhead likes this.
  2. Feb 1, 2021 at 5:28 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I did it through techstream. You need a taxtrix cable though. Im sure someone in your area with a cable will lend you one for a case of beer. It only takes like 2 minutes to change it.
    Techstream is free at @tonered 's signature.
    aarongue, Malvolio, Sungod and 2 others like this.
  3. Feb 1, 2021 at 5:28 PM
    Kev301
    Kev301 Well-Known Member
    Kevin
    2020 Trd Off-road DCSB
    Yes I did mines through techstream also
  4. Feb 1, 2021 at 5:36 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I changed to 5 turn signals blinks instead of 3 too, its a bit safer IMO.
    Malvolio, kgilly and shakerhood like this.
  5. Feb 1, 2021 at 5:41 PM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    Your dealer can disable the chime too. If they refuse just open a case with corporate and provide the info to the service manager. Theyll disable it for you then
    Malvolio and Junkhead like this.
  6. Feb 1, 2021 at 5:42 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Oh yeah, thats another option.
    But....:D
  7. Feb 1, 2021 at 5:43 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I know right, who manages to turn land in 3 blinks lol. I went with 5 too
    Junkhead[QUOTED] and shakerhood like this.
  8. Feb 1, 2021 at 5:44 PM
    baldbeardedtaco
    FL
    If it wasn’t supposed to be changed (option available) then it wouldn’t be in the manual right
  9. Feb 1, 2021 at 5:45 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I went with 5 too, 3 blinks was not enough.
    tonered and Junkhead[QUOTED] like this.
  10. Feb 1, 2021 at 6:04 PM
    baldbeardedtaco
    FL
    So my thinking is it should notify your intent to turn prior, during cross and “mostly” in the destination lane. I mean 3 can work if you jerk the wheel hard right lmao amiright
  11. Feb 1, 2021 at 6:04 PM
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    Can be changed with the carissa OBDII bluetooth plug in. You can get it on Amazon for like $20. That's what I did.
  12. Feb 1, 2021 at 6:05 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Put it on :anonymous:
    But seriously echo the same shit techstream
  13. Feb 1, 2021 at 6:13 PM
    baldbeardedtaco
    FL
    Back to the manual you could also technically go to the dealer and say you need a belt extension for a passenger… for free per the Toyota manual and now you have a free hanging belt clip and a beep
    Scissors/knife
  14. Feb 1, 2021 at 6:24 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    grogie likes this.
  15. Feb 1, 2021 at 6:29 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    This is what I did because the start up chime was driving me nuts. There's no way to disable the start up chime. Apparently according to my dealer turning off the seat belt chime only stops it when you driving which I found out.
  16. Feb 1, 2021 at 6:40 PM
    baldbeardedtaco
    FL
    I can’t remember, it’s been over 2 yrs now.
    The only beep I hear now is when I’m backing up with the door open- I like this to be gone but no setting
  17. Feb 1, 2021 at 6:49 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Second this option.
  18. Feb 1, 2021 at 6:52 PM
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Dealer did mine, no charge.
  19. Feb 1, 2021 at 7:11 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    My dad used to never wear a belt so to stop the beeping he went to a junk yard and got just a clip to leave plugged in. No beeps and still functional if need be.
    Intrepid likes this.
  20. Feb 1, 2021 at 8:33 PM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    OP: you very much do not want to use a dummy buckle. Might have been fine in older vehicle that did not have a sophisticated SRS.
    If you use a dummy buckle, the lifesaving devices in your vehicle will act differently.
    Intrepid and Junkhead like this.
