How to store? (Tacoma not used for months)
Discussion in '5 Lug' started by carcharias, Oct 30, 2011.
  1. Oct 30, 2011 at 8:15 AM
    carcharias
    carcharias [OP] Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    So, I've ended up getting jobs back-to-back which have kept me out of state and away from my Tacoma for 6 months. My g-friend said she'd start the truck & my motorcycle every week, but that hasn't happened and so both have sat dormant for almost 6 weeks. :(
    1) The Tacoma's battery is dead, so I told her to just leave it. Is there anything I should be worried about while leaving it until I return Dec 18th? When I get a new battery, will it be able to start up fine or should I drive it straight to a dealer for a checkup? I'm worried about all the fluids and any gas left in the tank...
    2) Same with my motorcycle. Any advice on that? Battery is at least on a trickle charge attached to the wall, but I'm worried about any leftover gas and fluids just sitting there. Is it safe to start after 2 months of inactivity? (I'm checking out the RAT forums, as well, but thought I'd ask here, too)
    Any advice would be helpful. Thanks, guys!
  2. Oct 30, 2011 at 8:23 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
  3. Oct 30, 2011 at 8:31 AM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    it wouldn hurt to put a fuel stabalizer in your truck
  4. Oct 30, 2011 at 8:42 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Gas starts to go bad after about a month. If you didn't use fuel stabilizer, I'd remove the tank on the bike and drain it. Bike fuel systems are a little more sensitive to bad gas than cars. Especially bikes with carburetors. Bad gas will clog up the low speed idle jets in no time.
    If she gets a jump, she may be able to bring the truck battery back from the dead. She can then put in some fresh gas with some fuel stabilizer. As long as she runs the truck for a few minutes each month, it should be fine.
  5. Oct 30, 2011 at 8:45 AM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Every time I think about fuel stabilizer I get this horrendous image of my girlfriend dumping it over my truck/bike and ruining the paint. Don't I have to have a nice amount of fuel in the tank? I'm guessing most would be evaporated by now.
  6. Oct 30, 2011 at 8:47 AM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Nice! Tank removal on the bike, huh? You think the other liquids should be alright (ie sitting oil) before starting it up?
  7. Oct 30, 2011 at 8:56 AM
    CRU
    Seminole Cnty, FL
    If the oil was fresh to begin with, I'd leave it. If it is due for a change anyway, swap it out.
  8. Oct 30, 2011 at 9:00 AM
    CRU
    Seminole Cnty, FL
    It's best to top off the fuel when adding stabilizer. Plus it helps mix it. I wouldn't bother stabilizing the bike now. It's easier to just siphon out most of the bad fuel, drain it, and refill with fresh new fuel. Should take you about an hour to do.
  9. Oct 30, 2011 at 9:24 AM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    You think the tank can stand as is until Dec 18, then I can remove it, clean it, etc? Or do you think it'll be rusted too badly by then? (2011 Triumph Thruxton) Oil was good before this. I don't think my g-friend could put gas in the bike w/ out spilling it all over the tank.
    +1, btw
  10. Oct 30, 2011 at 9:58 AM
    Tacoma Mike
    Southern Maine
    Is there someone you trust to do some preventive work while your away?
    They could siphon the fuel from the bike and add stabilizer and start it up for you to get fresh fuel in the system. If not just do it when you get back.
    And as far as the truck goes. I would put a trickle charger lead on the new battery. Then when you leave you can add stabilizer and hook up the tender.
    Just put a note on the steering wheel so you don't forger it's hooked up.
    Treat every away job as if your going away for a while and you won't have a problem.
    fuel treatment, battery tender, pump up the tires. 10 min and no worries.
    Good luck. Say safe away from home......
  11. Oct 30, 2011 at 2:26 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Good advice. Can't think of anyone that knows bikes or wouldn't drill a Makita thru my windows. Sounds like neither will be dead, but I will definitely have to tend to them asap when I get back. Thank you!
  12. Oct 30, 2011 at 2:31 PM
    Tacoma Mike
    Southern Maine
    Your Welcome.... :thumbsup:
  13. Oct 30, 2011 at 2:37 PM
    ILLINOISTACOMAGUY
    ILLINOISTACOMAGUY Well-Known Member
    Darryl
    ILLINOIS
    2005 SR5 SPORT
    WeatherTech Digital floor mats front and rear. Ventvisors, Hood protector, Towing package, Bed tiedowns, Wheel to Wheel steps,
    My bike sat for a year with a trickle and only being started 1 time in that year..had to go to the shop for the carbs to be cleaned and of course any dri-rot replaced. It sat inside a trailer at my moms in AZ and it had been treated with stabilizer(sea foam) as for the truck couldn't tell ya..sorry
  14. Oct 30, 2011 at 2:39 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    use marine formula stabil...regular stabil is useless with the ethanol content in todays gas.
