how to?!?!?!?!? struts shocks and springs
Discussion in 'Suspension' started by br217398, Dec 10, 2008.
  1. Dec 10, 2008 at 1:41 AM
    br217398
    br217398 [OP] Crazy Person.....
    Orlando Florida
    06 Tundra Crew Cab 4WD
    Hornblasters horns,Strobe lights,Police Undercover Vehicle, Volent Ram air system, pro comp POS AAL, biltein all around, step bars.
    Ok, so after a bit of searching, I'm not sure if i should or not... Ill be attempting to put a stock TRD suspension on my base (from mytoytaco), so if im able to think a "how to" would help anyone????
  2. Dec 10, 2008 at 2:13 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Whatta ya mean by 'base'? Do you have a 4WD truck? The TRD suspension you are referring to, is it off a V6 or a 4cylinder?
    Are you referring to the front & rear suspension?
    4WD only:
    If you're talking a TRD 4cyl suspension to a non-TRD 4cyl - personally, is it worth it? Is the 'ride' quality THAT much better between the two? If you're talking TRD 6cyl suspension to your non-TRD 4cyl susp- then you might get a little bit of LIFT with it and you'd feel the ride quality difference for sure.
    As for the rear suspension - I wouldn't bother unless you're getting the TSB leaf springs and not the original ones.
    edit: Here's some writeups to look at. I don't know if they're exactly what you're looking for but it should atleast give you an idea.
    http://www.lieblweb.com/tacoma/Mechanical/CornbredLiftInstall/CornbredLift.htm
    http://www.lieblweb.com/tacoma/Mechanical/DayStarLift/Daystar.htm
  3. Dec 10, 2008 at 10:17 AM
    br217398
    Orlando Florida
  4. Dec 10, 2008 at 2:15 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    So... is it a 5 lug Tacoma then, because if it is, the 6 lug suspension definitely won't work on it.
  5. Dec 10, 2008 at 4:08 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    It won't work. The suspension on the Prerunners and 4x4s is different than that of the 5 lug, which you have.
  6. Dec 10, 2008 at 5:02 PM
    br217398
    Orlando Florida
    how so??? what is the big differance??? because lots of people say it cant, but no offense i am just needing to know why. today i put an aal and shocks from a 6 lug trd and it works just fine.... today i couldnt get my wheel off because i managed to crack the lock tool to get my lugs off.
    thank you in advance for all of the information to all of you
  7. Dec 12, 2008 at 10:31 AM
    br217398
    Orlando Florida
    bump??
  8. Dec 12, 2008 at 11:05 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I can see the shiocks/springs for the rear suspension working ok, but not sure about the front. Another guy had the TSB done on the rear suspension of his 5 lugger. I think the dealer told him the rear shocks/springs were all the same, just how they mount to axle is different. I think the front springs are different though.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/20805-rear-tsb-done-5lugger.html
    Sorry, I don't have any knowledge of the Prerunners or TRDs, as I have a base model too. I'm interested to see how it turns out though.:popcorn:
  9. Dec 12, 2008 at 6:53 PM
    br217398
    Orlando Florida
    ok... i received the parts and the coils are longer on the trd and prerunner, but the mounting positions are the same (duh).... this coming weeked ill try and put it on my base and let ya know whats up. i was stoped the other day because my wheel lock cracked and i cant get the tires off.....
