How to - Subaru/Toyota(3rd Gen) Tweeter Upgrade (Holy S***)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SomethingNew71, Mar 24, 2018.
  1. Feb 23, 2019 at 1:56 PM
    #481
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Door and tweeter are wired in parallel, meaning if you wired the door to the amp, your tweets are wired to the amp too.The tweeter plug actually has 4 wire leads into it, 2 go back to the door speaker.
  2. Mar 2, 2019 at 8:44 AM
    #482
    Tacomojo
    Tacomojo Mojo Mofo
    Nashville, TN
    2019 TRD Pro, AT, White
    WOW, gotta say how impressed I am at how these upgrade tweeters have dramatically improved the sound quality from the front seats! The stockers were indeed pretty much worthless. Now it's time to move forward with the Kicker door speakers, and likely the Sound Ordnance powered sub that I retained from my '08 DCSB.
  3. Mar 3, 2019 at 10:23 AM
    #483
    hygieneboy
    hygieneboy Well-Known Member
    I know this is a subjective thing based on individual preferred volume/type of music/ settings/existing hearing loss( we all have some degree) I installed the Subaru/kicker tweeters and I am disappointed. I can't tell any improvement over stock. I have the radio adjusted high and mid all the way up and bass 3/4. If anything I have to turn up the overall volume a bit higher to hear things as clear as stock. With no amp and all other speakers stock this mod seems like it's not worth it to me.
  4. Mar 3, 2019 at 11:48 AM
    #484
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    It's because the factory speakers are not a tweeter. Now you added a different speaker being a tweeter only and your not getting the sound at certain levels that you had with the 3 inch factory speaker. I added a 2 way set of pioneer speakers with a tweeter. I must say that was what I needed, sounds great and there is a great stereo store that does real high end work and suggested this over the Subaru tweeters.
  5. Mar 3, 2019 at 5:00 PM
    #485
    Nutz45_1
    Nutz45_1 Well-Known Member
    James
    Mullens West Virginia
    2016 Tacoma sr black on black
    Hids low beams,all inter LEDs, ultra motor sport wheels 265/65/18 bfg a/t KO2s 6k rev lights led tail an brake new taillight covers
    I’ve changed mine today an it made a world of difference I’ve already changed the factory’s over to the kickers cs 6 3/4 an 6x9
    Also have to L7 12s wired to 1 ohm in back seat with a 1600kx kicker mono amp
    shakerhood likes this.
  6. Mar 5, 2019 at 7:43 AM
    #486
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    Did the upgrade a few weekends ago. WOW I can definitely hear the difference. The highs in my music are much clearer now. I can hear cymbals, vocals, fingers moving up and down the frets on a guitar, much better now. The install was breezy, and it's definitely woken up the system enough for me to put off the door speakers and subwoofer for awhile and focus elsewhere. Definitely would recommend.
  7. Mar 5, 2019 at 8:40 AM
    #487
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    Because you've adjusted the EQ wrong. Turn your high/mid/bass back down to baseline. Now adjust the volume first. Then adjust the EQ.
    And yes, it will require a higher volume number to be the the same loudness. The speakers take more power to push. I noticed it as well, but the clarity/quality is definitely better.
  8. Mar 5, 2019 at 8:44 AM
    #488
    bonifacio_629
    Walther
    Virginia
    I definitely had to mess with the EQ to find the sweet spot for waking the speakers up and not going deaf.:rimshot:
  9. Mar 5, 2019 at 2:48 PM
    #489
    deerhntrmike
    deerhntrmike Active Member
    White trd sport,double cab
    Helwig air bags,predator nuff bars, xenon led lighting
    I did the tweeter and kicker speaker upgrade myself. When I swapped mine out I changed everything on the right side first and listened th my music switching from left to right to compare. Definitely not as loud with the new speakers. After everything was done I noticed while not as loud it was much clearer. After a few weeks went by I decided I wanted more of the bass back so I installed a 5 channel amp from ********* and a 10” shallow mount infinity subwoofer. What a difference that made. I couldn’t be happier. Yeh sub is in a sealed enclosure I built and fits behind rear seat in my double cab. They also sell pre wired harnesses which are plug and play. Check out their installation videos. Pretty simple to remove factory radio to plug in connectors. About five minutes to do that part of it. They also show you how to tune the amp with a volt meter. It is now unbelievable clear with plenty of bass.
    Tommyb08 and bonifacio_629 like this.
  10. Mar 5, 2019 at 3:19 PM
    #490
    hygieneboy
    I usually listen to my music between level 6-8, I’m sure this is much lower than most people.
  11. Mar 5, 2019 at 8:33 PM
    #491
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    I did this mod today. Very happy with the sound improvement for $90. Looking to start doing the doors next week! Thanks for the write up OP! Cheers
  12. Mar 6, 2019 at 3:36 AM
    #492
    hygieneboy
    I didn’t adjust it “wrong” I adjusted it to my personal preference.
  13. Mar 6, 2019 at 5:35 AM
    #493
    Freetime
    Yes, you did. You did it in the wrong order. You need to adjust the volume first, THEN the EQ. Just do it, trust me. Also, at that low of a volume, you're not even providing enough power to push those new door speakers. I used to listen at 25-28, and the new speakers have to be at 30-35 to produce the same volume.
  14. Mar 6, 2019 at 1:31 PM
    #494
    Tommyb08
    Tommyb08 Well-Known Member
    Tom
    Jersey Shore - Ocean County
    2017 TRD Sport 4X4 DCLB Black
    I did my kicker tweeters first and was really impressed with the sound quality so I changed out the door speakers as well. For the price you can’t beat it, huge upgrade. I’m thinking about a sub next. Crutchfield is a great place to order from, they came with everything I needed.
  15. Mar 7, 2019 at 4:15 AM
    #495
    texbaz
    texbaz Well-Known Member
    "Buffalo Creek" TX
    2018 Tacoma Silver Sky Metalic 4WD DCSB TRD OR
    Any chance you can give details on the pioneer 2 way speakers you had installed
  16. Mar 7, 2019 at 4:37 AM
    #496
    elduder
    Van WA
    I think I've mentioned this before, but I feel like its worth saying just in case I havent. The Kickers are nice, especially since you dont have to do any real work to install them. That being said, for those looking for a better upgrade in the same price range, there are better options out there. Hopefully I wont catch any heat for saying this but adapters can be picked up for about $15 or made with back strap for a couple bucks. A wire adapter can be bought from places like ********* for $22, made for less by yourself, or the wires can be cut and soldered. Beyond that your welcome to try any tweeter you desire. I personally have used the Fosgate R1Ts in my truck as well as installed them in a couple other trucks. They have a larger frequency range, down to 2500hz, vs 3500 on the kickers. Personally, I also believe they sound better. They can be purchased on Amazon for around $40 too, which would make building them about $75-80, cheaper than the Kickers.
    If you're looking for a really nice tweeter though, that has an even larger dynamic range and sounds considerably better, try to Image Dynamics XS28. It's a bit more at $90ish but once you get it all together it'll cost about $20-30 more than the Kicker. The extra $ is really worth it with the IDs though.
    Just my 2 cents, to hopefully help someone out with a few more options for maybe a cheaper/better sounding option or for a slight more expensive, but much better sounding one.
  17. Mar 12, 2019 at 8:18 PM
    #497
    FortuneFavorstheBruin
    FortuneFavorstheBruin Well-Known Member
    Zack
    Austin, Texas
    2018 Tacoma Off-Road
    I did the upgrade and now I can't get the damn 10mm bolt covers to clip back into place on the passenger side grab handle.
    I can't figure out how to get them to stay into the clipped position; Tacomaworld what am I doing wrong?
  18. Mar 13, 2019 at 4:48 AM
    #498
    texbaz
    "Buffalo Creek" TX
    I looked at the Image Dynamics XS28 from what Amazon sells. Some of the problems with those are how do you mount them?
    elduder likes this.
  19. Mar 13, 2019 at 6:49 AM
    #499
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
    Question for anyone who's done this. The Crutchfield instructions show just popping the speaker cover off without removing the pillar trim. Is this possible or recommended? Is it too tight a fit to do it that way without breaking something?
  20. Mar 13, 2019 at 7:19 AM
    #500
    bmorgan1022
    bmorgan1022 Well-Known Member
    Atlanta, GA
    2018 Tacoma SR5
