How to - Subaru/Toyota(3rd Gen) Tweeter Upgrade (Holy S***)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SomethingNew71, Mar 24, 2018.
  1. Apr 26, 2018 at 7:23 PM
    #121
    Linewalker
    Linewalker Well-Known Member
    Juh Broh Nee
    SE PA
    2017 White SR5 DCLB 4x4
    Kicker/Subaru tweeters arrived yesterday. Planning on installing tomorrow or sometime over the weekend. I'm not an audiophile by any means, but the stock tweeters are really muddy IMO, so i'm curious to hear the difference.
    DubfromGA likes this.
  2. Apr 26, 2018 at 7:29 PM
    #122
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    Second gen? Anyone? Are these a possibility? I don't mind cutting and splicing.
  3. Apr 27, 2018 at 6:46 AM
    #123
    harl3ygonewiild
    harl3ygonewiild Well-Known Member
    Harley
    2017 tacoma TRD off-road
    can some one confirm you have to take a pillar molding off to remove speaker caps?
  4. Apr 27, 2018 at 6:49 AM
    #124
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Anyone get a crackling sound from the kicker tweeters? It seems only when audio quality is low, or when speaking on phone over Bluetooth - there will be occasional crackle.
  5. Apr 27, 2018 at 9:07 AM
    #125
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    I believe there is a tab on the speaker cover that grabs the apilar from the inside! U might break that off if you don' remove the apillar
  6. Apr 27, 2018 at 9:10 AM
    #126
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I removed the A Pillar Covers when I swapped the tweeters out.
  7. Apr 27, 2018 at 9:29 AM
    #127
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I was nervous to pull the pillars also since my truck had like 30 miles on it when I did it. Watch the video of the taco tunes guy and do what he does. Just go slow and don't force anything. Getting back in can feel like a puzzle, but it will go, just find the right angle.
  8. Apr 27, 2018 at 10:22 AM
    #128
    harl3ygonewiild
    Harley
    i just did it in 20 min on my lunch break, took a pillar off, and my advice do the driver side first, the front bolt its tight to the windshield and passenger side was much easier
  9. Apr 27, 2018 at 10:47 AM
    #129
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    Not sure why you'd lose mids when changing out same style speakers, unless the OEM ones were built more as mid-to-high range and not true tweeters. If you're looking for mids and lows, well, a tweeter is not going to do anything to detract from that end of the spectrum. Tweeters are high end frequency response, so we shouldn't be losing midrange with changing out tweeters. The problem with only changing out one pair of a 6 speaker system, we didn't design the system in our trucks, so we don't know the frequency response and how the speakers balance.
    That being said, my tweeters are being delivered today, but I also am planning on replacing the remaining speakers in the near future (not necessarily the kickers).
    I'm spitballing here too...so let this just be here...a true way to get the best response is to spec out all the speakers and replace em all so that each pair works with the rest of the system. Add an amp that has frequency equalization?
    Mids and lows will respond in the door speakers (and a sub...which I am with you, not my style).
  10. Apr 28, 2018 at 3:41 AM
    #130
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    speakers on the way from Amazon. hard to tell from the pictures, is it necessary to remove the a pillar cover?
  11. Apr 28, 2018 at 5:58 AM
    #131
    toyotatacomaTRD
    You can try, but people have broken tabs.
  12. Apr 28, 2018 at 6:06 AM
    #132
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    Does anyone know if the magnet is actually larger and if the cone is any better material? The speaker is in a plastic case and although it looks better because of this, I am not sure if the materials are any better. If anything, the surface area actually looks smaller.
  13. Apr 28, 2018 at 6:12 AM
    #133
    toyotatacomaTRD
    I put one in each hand. They weigh more, but I agree, you can't see the magnet. I have a feeling it is bigger just because if the weight. But I couldn't say for sure.
  14. Apr 28, 2018 at 6:38 AM
    #134
    shakerhood
    Southern Ohio
    I think I spent a total of 45 minutes but that includes walking down to the garage to get and put away my tools and wipe the dash and windshield down. I found the passenger side to be a little more difficult with the automatic headlight sensor in the tweeter cover.
  15. Apr 28, 2018 at 7:23 AM
    #135
    hotrod45
    paul
    sarasota fl
    16 sr 5 access cab
    the side panel has to come off.
  16. Apr 28, 2018 at 8:02 AM
    #136
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    I’m pretty sure the pillar cover needs to come off. Pop the bolt covers, remove the bolts and wiggle free. Comes off and goes on easily. Don’t risk it by pulling and prying the speaker cover without removing the pillar cover. I’m almost certain that the pillar cover sits on top of a tab of sorts on the side of the speaker cover.
  17. Apr 28, 2018 at 8:35 AM
    #137
    Linewalker
    Juh Broh Nee
    SE PA
    I just did the install. It took me @30min taking my time with removing/reinstalling the pillars and tweeter covers. As others have said, pillar removal looks to be necessary as it is right next to a snap tab on the tweeter cover. It's easier to just remove the pillar cover. When reinstalling the cover, I will point out to make sure to tuck the Pillar covers UNDERNEATH the door weatherstripping.
    Also too, the utility panel tools are really nice when doing this job and are inexpensive. $6 at amazon.
    Definitely a big improvement, to me, in sound over the factory tweeters. Much crisper and clearer right off the bat. This is a no-brainer for $100.
    DubfromGA and cshrum like this.
  18. Apr 30, 2018 at 9:10 AM
    #138
    Col4bin
    Col4bin Well-Known Member
    Maine
    2018 TRD OR Double Cab
    great upgrade for the price...easy install and absolutely an improvement over stock.
    yes, remove the A Pillar covers. 1 bolt on drivers side, two on the passenger (due to the oh shit handle).
    Linewalker and DubfromGA like this.
  19. Apr 30, 2018 at 9:39 AM
    #139
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    Yup, OP....did this mod 6 months ago and have been loving the improvement.
    I'm gonna do the door speakers soon....
    Sweet looking Mini !!!!!!!!!!!!!!!!!!
    I'd advise doing it.
    No reason not to and you'll not break any speaker grill tabs.
    I disconnected my battery, too....not sure if I needed to or not....but I didn't want to be messing around with the airbag cover (A-pillar cover) with it possibly under power.
  20. Apr 30, 2018 at 9:51 AM
    #140
    VolFan57
    VolFan57 Well-Known Member
    TENNESSEE
    2016 TRD OR 4x4 - MGM - traded. 2018 TRD Sport BRM 6MT
    Just did this upgrade over the weekend and was truly surprised what a difference it made. I was skeptical but the end result is well worth it.
    DubfromGA, Linewalker and cshrum like this.
