How to - Subaru/Toyota(3rd Gen) Tweeter Upgrade (Holy S***)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SomethingNew71, Mar 24, 2018.
  1. May 6, 2018 at 9:06 AM
    #161
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    It's amplified and has a sub. Door speakers and tweeters are the same though
  2. May 6, 2018 at 9:10 AM
    #162
    APynckel
    APynckel Well-Known Member
    2018 MGM Tacoma TRD OffRoad 4x4 DCSB
    Bakflip MX4 Tonneau Cover XenonDepot ExtremeHID w/ Phillips bulbs
    Wonder if I can grab the 6x9's and 6.5" door speakers (Alpine S) from my old Eclipse GSX and swap them in there....?
  3. May 6, 2018 at 9:11 AM
    #163
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    6x9s in the front and 6 1/2s in back door. You will just need adapters to mount them in the doors.
  4. May 6, 2018 at 9:12 AM
    #164
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    NO, the Tweeters will not work with JBL
  5. May 6, 2018 at 9:12 AM
    #165
    APynckel
    What tweeters will work then? Are there any good aftermarket solutions?
  6. May 6, 2018 at 9:15 AM
    #166
    shakerhood
    Southern Ohio
    I have no idea brother, I am sure there is something out there that will work.
  7. May 6, 2018 at 9:17 AM
    #167
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
  8. May 9, 2018 at 8:13 PM
    #168
    Mnmlod
    Mnmlod Newb
    Yosemite
    2018 TRD Pro
    I thought that I saw in ********* or crutchfield that there was a way to separate the tweeters from the front doors.
  9. May 16, 2018 at 4:54 PM
    #169
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    OK I just did this, took me about 3 hours but knowing what I know now I could do it in under 1. The front door gave me the most trouble because the Metra adapter didn't line up with the kicker speakers well. Also, I had those white clips on the sail panel fall into the door panel, anyone know where I can get those? Lol. All in all, good upgrade and the sound is great now! Well worth it IMO.
  10. May 16, 2018 at 5:02 PM
    #170
    shakerhood
    Southern Ohio
    I had one of those white sail panel clips fall into the door, had to take the panel back off and stick my arm in the door to find it.
  11. May 16, 2018 at 5:17 PM
    #171
    bv8ma
    Bill
    MA
    2017 TRD OR
    I had all 3 on the drivers side front fall in in one shot! I got one out with needle nose pliers, the others can stay lol I just ordered some on Amazon.
    Edit: btw, for those that don't want to learn the hard way, pinch the clips to pull them out of the door panel then snap them back on you sail panel before putting it back on.
    Edit 2: So after a few hours of driving I have to say this made a huge difference, highly recommend doing it. Everything is so much clearer and as a result I find myself listening with the volume mostly under 20 instead of close to 30 before swapping speakers.
    shakerhood[QUOTED] likes this.
  12. May 26, 2018 at 11:33 AM
    #172
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I've seen several videos on the tweeter install with the Subaru's and it all seems pretty simple., But none of the videos I can find detail how to take the right side (Passenger side 2018) apart. I see there are two bolts that hold the panel where the grab handle is but there is also a button of sorts on the top of the right side speaker cover which is not on the left side. Is there a bolt under there or will the cover just pry off as the left side one does? I don't want to go forcing things and end up breaking something.
  13. May 26, 2018 at 11:35 AM
    #173
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    It's the exact same as driver's side with the exception there is 2 bolts.
  14. May 26, 2018 at 12:21 PM
    #174
    crizq0
    crizq0 Well-Known Member
    Bay Area, CA
    2018 Tacoma TRD OR
    TBD
    Did this mod a few weeks ago and was pretty disappointed. Fast forward 2 weeks, music sounds amazing now. I don't know if there is some sort of break in period but the clarity has definitely improved.
  15. May 26, 2018 at 1:05 PM
    #175
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    Okay, thanks. So that button on top of the right side speaker cover doesn't come into play with prying it off?
  16. May 26, 2018 at 1:38 PM
    #176
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    I did not have the auto dimming lights so that “button” was just a plastic plug for me. No impact when removing the speaker cover. Not sure if you have the auto lights or not.
  17. May 26, 2018 at 2:24 PM
    #177
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    I do have auto dimming lights but I don't think that button has anything to do with it. It's just a plastic button.
    This is what I am talking about.
  18. May 26, 2018 at 5:21 PM
    #178
    rsimi72
    PNW
    Looks similar to mine. Maybe I’m wrong about that being the light sensor. If it’s just the snap in filler plug you’re good to go. It’ll come right up with the speaker cover. Remember to pull the A-pillar cover first. Then carefully pry the cover up starting at the edge nearest the passenger seat. Work back toward the windshield.
  19. Jun 1, 2018 at 3:33 PM
    #179
    GulfCoastMike
    GulfCoastMike Co-pilot Angel
    Pascagoula, MS
    2017 MGM AC SR5 3.5L A/T
    Completed the tweeter upgrade yesterday. The job was so simple with the most difficult part being unplugging the connectors from the stock tweeters.
    I felt the difference was significant. I hadn’t really noticed the stock tweeters adding anything to the music. The new ones made themselves apparent immediately.
    While changing the passenger side, I decided to let the radio play while I did the swap. When I unplugged the tweeter, the door speaker went silent. That means the tweeters and the 6x9’s are wired in series.
    This means if either blows (goes open), the other will not operate. Disappointing design!
    Experience has taught me that speaker break-in is real. The sound should only improve over time.
    Completely pleased!
    Next up, a pair of JL Audio C2 690tx for the doors. Great sound and I found them on Amazon for $131.
    0uTkAsT and Linewalker like this.
  20. Jun 1, 2018 at 3:57 PM
    #180
    shakerhood
    Southern Ohio
    That is the light sensor for the automatic headlights, its no big deal during the tweeter swap.
