How to support truck while removing entire rear axle
Discussion in 'Solid Axle Suspension' started by Stout890, Oct 13, 2011.
  1. Oct 13, 2011 at 1:18 AM
    Stout890
    Stout890 [OP] Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    Iv been trying to think of way to safely support my truck when I swap my rear axle for a different one. I usually jack my truck up by the axle but it doesn't go high enough to jack from any other point.. And my jack stands are not tall enough to reach the frame especially since I have an AAL in the back
    Any ideas? Has anyone had to do this before?
  2. Oct 13, 2011 at 1:29 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I made stands for my jack stands out of 2-2x6 2-2x4 and a piece of 3/4" plywood on top. Put the 2x6 on opposite ends and the 2x4 connecting the two and the plywood on top. They have not given off any weird sounds the many times I have used them. I place the stands under the frame either in font of the front leaf spring mount or behind the rear leaf spring mount (doesn't matter). Just make sure you make the stand about 1.5" bigger then the base of your jack stand on each side.
  3. Oct 13, 2011 at 1:44 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  4. Oct 13, 2011 at 2:31 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I have several pieces of 4x6 of some sort of hardwood that I got from a pallet. They also stay in the back of my Taco in case they are needed on a trail.
  5. Oct 13, 2011 at 8:43 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    So why is this in the SAS forums? :confused:
    But, I put like 8x8s under the jack stands. . To swap the axle all you need to do is remove the tires and lower one side of the axle all the way lowest you can go in order to unbolt the leaf spring, then vice versa. I've done it a few times on both on my axles. And of course you gota support the back portion of the frame with jackstands, but they don't need to be jacked sky high
    clayota likes this.
  6. Oct 13, 2011 at 8:47 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    just put blocks under the jackstands and use the floor jack for the axle
