How to Swap Your Plastic Clutch Pedal for a Metal One from an FJ Cruiser
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BLtheP, Oct 14, 2023.
  1. Nov 7, 2024 at 6:14 PM
    #41
    BLtheP
    BLtheP [OP] Constantly Tinkering Member
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    My truck was only at 35K when I did the swap and only about 2 years old at the time. Reused the return spring and all has been well.
    Nothing needed to weld. I saw some other dude needed welding on his but he was using an aftermarket master cylinder and some other stuff. Stick to stock parts and you’ll be good to go. Just throw a spring in the cart, it’ll be cake to swap it out during the process. So get the parts I listed plus the spring.
    super g[QUOTED] likes this.
  2. Nov 16, 2024 at 8:58 AM
    #42
    super g
    super g Well-Known Member
    garrett
    north carolina
    09 trd off road with high hopes
    Afe stage 2 cai pro dry s, magna flow exhaust
    @Grossomotto ... do you still have the hook up on these parts plus a new release spring( the top one)? and how much to ship to 31316?
  3. May 4, 2025 at 6:04 PM
    #43
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    I feel like the side to side wobble contributes to earlier mast clutch failure ... I replace my mast clutch cylinder and pedal about 6-7 years ago and it's reoccurring... probably will just do this mod ...any idea on cost
  4. May 17, 2025 at 12:21 PM
    #44
    killerkeener
    2011 trd 4x4 manual
    None yet
    #23 you can loosen the nut with 14mm and spin it 180° to face forward ..much easier
    Foushee likes this.
  5. May 20, 2025 at 6:29 PM
    #45
    killerkeener
    2011 trd 4x4 manual
    None yet
    I got about the same results on a 2nd gen. OR
    Urd throw out bearing
    Stock clutch
    Fj pedal change +slave cylinder
    All parts from the list ...no issues
