How to tame my aero exhaust?? Glasspack? Resonator?
Discussion in 'Performance and Tuning' started by anthony250f, Sep 22, 2015.
  1. Sep 22, 2015 at 4:24 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    So my aero 2525 is just to much for me, sounds great but Too loud.....I was thinking about adding a 20" glasspack with 4" body right before the muffler ? Or a resonator? Any idea f this will even lower the volume much
  2. Sep 23, 2015 at 2:54 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Maybe you can try a VIBRANT ultra quiet resonator welded between the exhaust flange and your exhaust. Few had good result whit that.
  3. Sep 23, 2015 at 2:57 PM
    anthony250f
    Anthony
    San Diego, CA
    I ended up ordering a cheap muffler to throw on before my aero
  4. Sep 29, 2015 at 8:43 AM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    aero turbine ar25 will make it sound badass. thats what i had on mine. the tr25.3 resonator by them will make it even more tame and deeper.
  5. Oct 5, 2015 at 8:29 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have you installed it yet Anthony?
  6. Oct 5, 2015 at 12:10 PM
    anthony250f
    Anthony
    San Diego, CA
    Installed it last night!! Much quieter!!! I have a MASSIVE exhaust leak when the two headers meet and go into one...all the studs broke and I drilled them out after many hours and it leaks so bad...gonna just weld it all shut
  7. Oct 5, 2015 at 12:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If this then this. Forever present when modding.
    colinb17 likes this.
  8. Oct 5, 2015 at 12:39 PM
    anthony250f
    Anthony
    San Diego, CA
    Yup!! Sure sucks but for the afr gauge hooked up..seems like it isn't running lean like I thought
  9. Oct 7, 2015 at 5:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How do you mean? Were you under the impression that it was running lean?
  10. Oct 7, 2015 at 7:08 AM
    anthony250f
    Anthony
    San Diego, CA
    I thought I was hearing pinging ...but now I read that in closed loop boost afr will still be 14.7? And it won't go down until open loop ? At wor it was anywhere from 11-12.5...will get a more accurate reading after I fix the leaks
  11. Oct 7, 2015 at 9:24 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How long after you're in boost is it staying @ 14.7? It should be around 12 - 12.5 :1 (full throttle) at zero on the boost gauge. Even richer dependant on the tune. 11's when in boost.
    Get some video reference if you can, prior to fixing the leak. Aswell as after fixing the leak.
  12. Oct 7, 2015 at 9:39 AM
    anthony250f
    Anthony
    San Diego, CA
    Will try to get video...so the urd 7th is supposed to shoot fuel before it goes to open loop? From what I've read you need a O2 calibrator to do that...I've seen it go as low as 10.9 wot
  13. Oct 7, 2015 at 9:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Depends on the programming.
  14. Oct 7, 2015 at 2:57 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Do you have an A/F calibrator? If not, then the URD 7th will not change the AFR in closed loop because the ECU will try to fight to counter the additional fuel you are adding.
    Torspd likes this.
  15. Oct 7, 2015 at 3:07 PM
    anthony250f
    Anthony
    San Diego, CA
    I do not have the afr or the O2 calibrator
  16. Oct 7, 2015 at 5:15 PM
    anthony250f
    Anthony
    San Diego, CA
    I got the exhaust leak patched as best as I couldand now at wot it's right at about 11.1 afr
  17. Oct 7, 2015 at 5:55 PM
    kigmob
    James
    New Orleans
    You just have an 04 motor and not an 04 ecu right? Just checking cuz if you have the 97 ecu still then it should have a narrowband O2. Reason I'm asking is because when I ordered my 7th injector kit, the piggyback ecu came with an O2 calibrator built in. IIRC this is not the case for URD units that require an AFR calibrator (99+). You have to purchase the calibrator separately. So I'm curious as to what type of URD piggyback you have.
  18. Oct 7, 2015 at 8:07 PM
    anthony250f
    Anthony
    San Diego, CA
    O
    04 motor with 97 ecu and I still have the narrowband sensors...the guy bought the 7th kit used so idk what year it came from....I noticed when I shift it goes a little richer between shifts...
    Brand new twnsioner and belt and it still make a slight squeel...WAYYY better though and feels so much better and the exhaust is pretty quiet with zero rasp...love it
  19. Oct 8, 2015 at 6:22 AM
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    I know a lot of the guys in the GM world use a "bullet" type muffler in front of the muffler such as the dynomax. Usually helps. That or replace the muffler with a longer case.
  20. Oct 10, 2015 at 5:25 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
