How to tell if a '05-'08 has traction control?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tbaker, Jul 18, 2010.
  1. Jul 18, 2010 at 10:55 AM
    tbaker
    tbaker [OP] New Member
    I am looking for a Tacoma and have decided I want traction control with as much wet weather as we have here in Oregon, especially since I will not have much in the rear most of the time.
    Some folks on autotrader list a truck as having TC, but some don't, but it may not be something that people know about - if it is not a Toyota dealership then they may not know if it has it or not. I have searched ut haven't found anything here in the forums.
    So my question is...can you tell if it has TC by looking at the buttons to the left of the steering wheel? Or is there some other way to tell so I don't accidently rule out a truck that may hav it but may not have it in the description, or so I can double check those that may incorrectly list it?
    Thanks in advance.
  2. Jul 18, 2010 at 10:58 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Do you looking for electronic VSC or you looking for Limited slip.
    Those years may have Limited slip on the back but there is no button only a sticker on the rear diff.
  3. Jul 18, 2010 at 11:05 AM
    tbaker
    Looking for TC / VSC, so in the event the rear slides in the wet it cuts power and/or applies brakes to bring it back around, which is, fromt what I have read here VSC - but I am new to researching Tacomas and only starting reading about them a week ago.
    Sounds like a VSC button would be the ironclad proof.
  4. Jul 18, 2010 at 11:26 AM
    JKD
    JKD Well-Known Member
    Your description is correct. Also remember that VSC became standard in Tacoma in 2009, so if you found an 09 you would be sure to have it.
    After about a year of driving my 09, I think the VSC is a must-have. It works very, very well.
  5. Jul 18, 2010 at 11:31 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The VSC and all that electronic traction control stuff was an OPTION in those years. I'm not even sure they were available to certain markets.
    You'll be lucky to find them, as they seem pretty rare in those years.
