How to tell if a tweeter is blown?
Discussion in 'Audio & Video' started by ilovetacos, Aug 5, 2009.
  1. Aug 5, 2009 at 10:15 PM
    ilovetacos
    ilovetacos [OP] Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I am getting some harshness out of my right tweeter when I have the volume up pretty high. The harshness is only coming thru that tweeter and no other speakers. I have done some research and have read that usually when a tweeter is blown they will not produce sound. It sounds fine at low to medium volumes. I have adjusted my gain down and also switched the "polarity" of the connection because I read this works sometimes. I am pretty lost to what it can be.
    Thanks in advance!
  2. Aug 6, 2009 at 3:06 PM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    Well I had harshness too and was able to lower a few things in the eq to correct it as well as changing my crossover setting for my front seperates.
    I dropped the crossover to -3db for my tweets, it has a range of -3, 0, +3
    And for my highs in the eq, I went from 12.5khz to 10.0khz and also dropped the level by 2 points.
    Try adjusting your eq and crossovers a little at a time and use the same reference song too.
    Another thing to check is your gains to make sure your deck or amp isn't clipping.
    I had a lot of help from others tuning my system and am no way an expert, I'm just sharing what my experience has been so maybe it can help you...
    Good luck!
    Rob
  3. Aug 6, 2009 at 3:47 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Swap the tweeter you think is fine with the one you think is bad. If the noise is the same after the swap you know the tweet is fine and something else up the chain is bad.
    Keep swapping until you isolate the problem.
  4. Aug 6, 2009 at 3:59 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Screw me! I didn't read the "ONLY RIGHT TWEETER" part, sorry my information is not specific to your issue...
    Rob
  5. Aug 6, 2009 at 4:27 PM
    KAPendley
    KAPendley Best Hack I Know
    Andy
    Hickory, NC
    96 2WD V6 Extended Cab
    Shaved, Lowered,Airbrushed (some)
    Tweeters can be blown, just like a speaker, and sound harsh. If its only the one speaker, more than likely its bad.
    OR, if you are running it active, it could be a bad channel in the amp, or the crossover is shot. I would try swapping the crossovers if you are not running it active on an amplifier.
  6. Aug 6, 2009 at 4:28 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Sounds like a winner to me.
  7. Aug 6, 2009 at 7:30 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Thanks everyone for the help...I am going to try johnecon2001 idea. I played with it a little at work today. Unplugged the drivers with only the tweets connected so I could pinpoint the sound. Definetlely only the right tweeter.
    If it is a bad tweeter will it be covered under warranty? I have only had these installed 2 months and have been using the crossovers.
    Thanks again!
  8. Aug 6, 2009 at 7:48 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    As long as you bought it from a reputable source and have a receipt they should definitely be covered under warranty!
    Rob
  9. Aug 6, 2009 at 8:31 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Tacotunes :( There an authorized Image Dynamics dealer but getting ahold of him will probably be impossible.
  10. Aug 6, 2009 at 8:33 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Oh no, that sucks, I seriously don't know how they stay in business with all the bad reviews I've read about them... Best of luck my friend!
    Rob
  11. Aug 6, 2009 at 8:35 PM
    KAPendley
    Andy
    Hickory, NC
    I was an ID dealer. If I can help out in anyway, let me know. Although Im not a dealer anymore, I am good friends with Sean and Jim there. I at least can talk to Sean in your favor and see what he can do for ya.
  12. Aug 6, 2009 at 8:37 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Thanks man! There is an authorized dealer in my town. Would I be able to exchange my tweeter with him?
  13. Aug 6, 2009 at 10:17 PM
    ItalynStylion
    Steven
    DFW, Tx.
    They are really good about honoring their product warranties. I got a dead on arrival IDMAX and talked with the guys at ID for a while and they just sent out a new one. Great guys.
  14. Aug 7, 2009 at 7:15 AM
    KAPendley
    Andy
    Hickory, NC
    It wouldnt hurt to try, as long as you bought it from an authorized dealer, I would imagine it would not be an issue. If it were my shop, I would take care of you in hopes that next time you made a purchase it would be through me. If he doesnt, then he is not very good at customer service.:D
  15. Aug 7, 2009 at 7:55 AM
    Colinwoods84
    Colinwoods84 Well-Known Member
    Virginia Beach
    2008 Sport Double Black
    if you got a multi meter go to the good tweeter and do a resistance check on the GOOD tweeter. Remember the Ohms and compare to the BAD. If the bad has less resistance than you can assume its bad but would have to be a bit of a jump. its highly unlikely that you would see a complete open especially since your getting some noise out of the bad tweeter. Compare ohms. Thats how I came to figure I had a bad tweeter.
  16. Aug 8, 2009 at 7:13 AM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    EDIT:
    Upon further investigation I found it is not the tweeter. I am thinking a bad crossover. This morning I took a little more time to make sure it was the tweeter and found that when I hooked up the "good" tweeter to the "bad" crossover I could hear the cracking noise and vise versa when I connected the "bad" tweeter to the "good" crossover there was no crackling.
    So....Is it a bad crossover? Could it be wiring?
  17. Aug 8, 2009 at 9:11 PM
    KAPendley
    Andy
    Hickory, NC
    Sounds like the crossover. Not uncommon..........normally NOT common for ID though. LOL. But shit happens.
