How to tell which brake calipers on my 2004 Tacoma????
Discussion in '1st Gen. Tacomas (1995-2004)' started by woodygg, May 20, 2011.
  1. May 20, 2011 at 8:15 AM
    woodygg
    woodygg [OP] Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    So I'm thinking about getting new rims, but was told that which rims would fit depends upon which brake calipers Toyota put on my 04 Tacoma. Apparently a lot of the 04 Tacoma's had the newer brake calipers that they put on the 05 Tacoma's - and if that's the case (they're supposedly bigger/wider), it changes which rim will fit on my truck.
    Does anyone know how to tell the difference?
    Thanks!
  2. May 20, 2011 at 9:04 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Not entirely true. There are two different calipers available on the 04 Tacomas. The standard caliper and there's a larger caliper. The larger caliper option ONLY came on 2004's and ONLY if you have the VSC option. The VSC is VERY rare.
    If you're not sure if you have VSC, crawl under the back of your truck and look for the rubber brake line that runs from the hardline on the drivers side frame to the the axle. If you have 1 rubber brake line, you have a normal Tacoma like the rest of us. If you have 2 brake lines, you have the VSC option.
  3. May 20, 2011 at 9:30 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Here's the brake line i'm talking about:
  4. May 20, 2011 at 10:26 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    those leaf springs look nice. ....tell me about them!
  5. May 20, 2011 at 10:39 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Deaver f67's. 62" long travel spring pack :cool:
