How to test limited slip (mechanical) on my 2006 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dirtnsmores, Jun 29, 2021.
  1. Jun 29, 2021 at 3:02 PM
    dirtnsmores
    dirtnsmores [OP] A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I want to test the limited slip on my truck. I know it's mechanical (2005-2008). I have 138k miles and always change the diff oil ontime. Trying to figure out if it's still working good or if i should look at upgrading my traction to a Truetrac limited slip or a real selectable locker.
    It's a prerunner so I want to gain traction however I can. Plan to do some mountain camping this summer. I know it's worked in the past but I haven't been on any difficult trails in the past year.
    I have tools and a few tall floor jacks to test in my driveway if possible. Thanks!
  2. Jun 29, 2021 at 3:05 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I could be mistaken but my understanding is that if it is mechanical it should always work unless something broke in which you would likely have other issues. Maybe someone else can correct me to know for sure.
  3. Jun 29, 2021 at 3:06 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    i've read on this website that it's a clutch pack style limited slip and they do indeed wear out with miles. the true trac from detroit, which I kind of want to get, does not wear out since it's a different style.
  4. Jun 29, 2021 at 3:41 PM
    RedWings44
    Michigan
    Makes sense. I guess best way would be to try and jack up one side until it is off the ground and try moving. You don't want to go too far off the ground though because if it is working properly you will roll the truck off the jack.
    boston23 likes this.
  5. Jun 29, 2021 at 3:55 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    I thought that's how a locker works, but a limited slip needs the wheels to be moving. But I will try that and see what happens
  6. Jun 29, 2021 at 3:59 PM
    RedWings44
    Michigan
    It's the same idea. The limited slip engages when it detects slip. One is just physically locked and the other is engaged in a different manner.
  7. Jun 29, 2021 at 4:00 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    Ok cool
  8. Jun 29, 2021 at 4:06 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The clutch pack limited slip in the equipped 05-08 Tacoma's has a new from the factory difference of rotational force of 150ftlbs. That is to say it takes 150ftlbs of difference between the two tires rotationally for them to spin at a different rate.
    Test should be pretty simply. Jack the ass end of the the truck up properly (chock front wheels on both sides ) and leave the truck in gear or in park without the parking brake on. If the clutchs pack are worn it would be easy to spin one tire and have the other spin the opposite way (diff will be held from rotating via park / in gear)
    dirtnsmores[OP] likes this.
  9. Jun 29, 2021 at 4:23 PM
    ellocodetroit
    ellocodetroit Well-Known Member
    Louie
    Alhambra, So Cal
    2008 PreRunner DCLB Eaton Truetrac 4.11
    Bilstein 6112/5160, Icon RXT Stage 3, Cooper ST Maxx, MF-1050 OBA. 348,000 Miles. Coupe battery tie down, Homertaco Grille, Weathertech Floorliners, Front shocks @1.94", ARE camper shell, TRD skid plate.
    I suggest going with the truetrac, but I'm biased. Eventually the clutch pack is going to wear out anyway. I think the clutch pack LSD on my truck wore at around 180k-200k. I never did the test, but I was losing traction going up hills and I noticed more wheel spin.
    The only time the truetrac failed to get me over an obstacle was going up on Diablo Drop-off in Anza Borrego. It was deeply rutted and sandy. Two older 4x4 jeeps behind me struggled too and had to get winched up. Vehicles with lockers got up fine. With the truetrac I was able to go over Mengel pass in Death Valley and Laurel Lakes near Mammoth. I'm happy with it.
    If you get the truetrac, I recommend getting your rear brakes resurfaced(turned), new shoes/linings, and adjusted.
  10. Jun 29, 2021 at 5:48 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    Wow super easy test. Will give it a go in the next few days
    nd4spdbh[QUOTED] likes this.
  11. Jun 29, 2021 at 5:49 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    I've heard that same thing from many people on this forum and a few others. And the price is pretty good compared to a locker. Laurel Lakes and mengal are both places I want to try with a group. Thanks for the tip about the brakes too
  12. Jun 29, 2021 at 6:20 PM
    Big2Customs
    Big2Customs Well-Known Member
    2007 Tacoma TRD Sport. Indigo Ink
    Bilstein 5100 front Bilstein 5100 rear
    Another way to test the lsd is to just hold the brakes, and stomp on the gas. Light em up!
    Rip a burnout, lay a strip!
    If you have 2 skid marks, your lsd works. If you have 1 strip, you have an open diff.
  13. Jun 29, 2021 at 9:07 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    Hell yeah! :burnrubber:
  14. Jun 29, 2021 at 9:11 PM
    TacoTuesday1
    SD CA
    ARB Air Locker
    Regear
  15. Jun 30, 2021 at 9:31 AM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    It's a thought. A very expensive thought for my prerunner
  16. Jun 30, 2021 at 12:37 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    My 2006 limited slip (mechanical clutch pack) was tired and would start digging a hole with one tire and no (or low) push from the other on challenging loose uphill surfaces.
    I replaced it with a TruTrac and couldn’t be happier. It works great, is seamless and constantly available. My opinion is much more beneficial in the real world.
  17. Aug 10, 2021 at 9:07 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    Wow another vote for truetrac. Seems to be a great option for prerunners. Thanks for the information it's number one on my list.
  18. Aug 16, 2021 at 6:07 AM
    deuce189
    deuce189 Well-Known Member
    Kev
    Charleston, SC
    2019 Cement SR5 Prerunner *SOLD*
    Hunting for a 4g
    Is this the same as the 3rd gens Auto LSD? I forget the 2nd Gen Non off roads have the same thing with traction control off. I was looking into a truetrac, thats why i hopped on this thread. Will the Auto LSD need to be disabled if you install the truetrac, like when you turn traction control off? I'm only considering it because i figured it was a good option rather than air locker/e locker when i replace my rear gearing.
  19. Aug 17, 2021 at 2:36 PM
    ellocodetroit
    Louie
    Alhambra, So Cal
    The auto LSD uses braking to simulate an LSD differential, so I would think the auto LSD would help the truetrac find traction in some situations by slowing the wheel spin. For example, and I'm probably not explaining this well, when one rear tire is in the air the truetrac will act like an open diff, but when you apply your brakes to slow the wheel spin on the tire in the air it will "lock up" and send power to the wheel on the ground. FYI...If your ABS systems dislikes the action going on in the rear differential, the ABS light will come on and in my case the ABS light disables traction control, VSC, auto LSD(if equipped). I don't have auto LSD on my truck(2008), but I'm sure others with the auto LSD and truetrac can chime in and offer their experiences.
    This is best video on youtube explaining the various differentials and how they work minus the auto lsd.
  20. Aug 17, 2021 at 2:53 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Jack it up (both wheels from the diff) turn one rear wheel if it is an open diff the other side will turn the opposite direction. If it's limited slip they will turn the same way.
