How to tie down rods?
Discussion in 'Boating & Fishing' started by Bs 02 Taco, Feb 11, 2009.
  1. Feb 11, 2009 at 3:05 PM
    Bs 02 Taco
    Bs 02 Taco [OP] Well-Known Member
    Amelia, Ohio
    02 Tacoma 4x4 regular cab 5 speed
    Swiss cap Deckplate Stupid door chime Synthetics AFE pro dry JVC Ipod compatible head unit Vanilla air freshener :) 25%tint
    Hey fellas,
    I am needing some advice on hauling my rod/reel's in my truck.
    I hate when I just put them in the bed and they smack around
    Any ideas on how to store them, or tie them down?
    I only have a standard cab, so no putting them on the inside :)
  2. Feb 11, 2009 at 3:14 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    That's pretty sweet, where'd you get those mounts? I've got a 9' fly rod, but it breaks down, and would fit in my 5' bed. I guess the other option is to get a tube that I can mount on my roof rack.
  3. Feb 11, 2009 at 3:35 PM
    Bs 02 Taco
    Amelia, Ohio
    Wow, thats nice.
    I have a 6' bed
    My poles range from 5' 5" to 7' 6"
    They are one piece
    My truck is a 2002, if that makes a difference
    I dont have the fancy bed rails the newer trucks do
    That being said I am not afraid to screw right into the sucker :)
  4. Feb 11, 2009 at 4:20 PM
    Stu
    Stu Well-Known Member
    G'Ville, NV
    Taco TRD OR
    Not much yet, got a pretty good sound system w/ my custom sub box. Plan on adding more lights & a tool box.
    PVC pipe is your friend! Cut to length, buy a couple of caps with foam of some sort on the ends, maybe wrap them in a towel, done. I'd not mount them in. Then you just slide them in the tube, cap it & toss it in your truck. They store nice in the garage that way also. Nice way to back-pack them in too, just pop a hole in both ends, thread a rope throo & knot. Careful you don't close one end too welll! or buy 1 threaded end w/ cap, then you got 'er done.
  5. Feb 11, 2009 at 4:21 PM
    Bs 02 Taco
    Amelia, Ohio
    Thanks a lot for your help!
    I just bought a berkley holder that can be mounted anywhere.
    I have a plastic liner for my bed so I guess I will use some sort of self tapping screw
    If you have another suggestion, I am game
  6. Feb 11, 2009 at 4:24 PM
    Bs 02 Taco
    Amelia, Ohio
    Well damn!
    I might try this for security pourposes
    I have a cap, which is on most of the time, but would like something permanent
    This is a great suggestion though.
    I think a write-up is needed
  7. Feb 11, 2009 at 4:26 PM
    Bs 02 Taco
    Amelia, Ohio
    Tap-its was exactly what I was thinking!
    They dont have to be too well hung do they?
    I mean they arent going to support that much weight I wouldnt think
  8. Feb 11, 2009 at 4:29 PM
    Bs 02 Taco
    Amelia, Ohio
    Question with the PVC though
    If I wanted to carry a couple, or a few rod/reel combos, how wide of circumference pipes do they make that would be applicable for this?
  9. Feb 11, 2009 at 4:43 PM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    This is what I use for transport and then when ready....
  10. Feb 11, 2009 at 7:10 PM
    Bs 02 Taco
    Amelia, Ohio
    Holy Sh!t
    Good work man.
    Did you make that or did you buy it?
    Either way how or what is it?
  11. Feb 12, 2009 at 7:34 AM
    Stu
    G'Ville, NV
    Taco TRD OR
    Anything including what 1/2" to I'm guessing 2' or larger. If you don't find what you want at a Lowes/Home Repo store, try the job shack at any new commercial building site on a weekday. The thinwall (sched 80. I think) is what you want, unless you are worried about driving over it, then go with sched 40 or better, but they get heavy.
  12. Feb 12, 2009 at 7:58 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Here is an option, don't look at the red bar. Get quick fists, and make some brackets from alum. stock, get some rail bolts/blocks, this way won't have to drill in the bed, and you can remove at anytime.....:)
  13. Feb 13, 2009 at 2:40 PM
    Bs 02 Taco
    Amelia, Ohio
    Amen brother!
    Stupid no-rail beds!!
  14. Feb 15, 2009 at 2:25 PM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    Sure you can put em inside. When I drive my old 87 mazda standard cab i put the handle in the passenger floor and open the rear window with the tip stickin out. If your back window dont open you can stick them out the passenger side window. It dont get in your passengers way to bad.
  15. Feb 16, 2009 at 3:58 PM
    kilo
    kilo Solo Member
    San Antonio, Texas
    Thanks. I made them myself. It would have been better out of aluminum. You can buy the bazooka rod tube holder from BassPro and Cabelas. They have 2 sizes.
  16. Feb 18, 2009 at 7:32 AM
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    I mounted the aluminum rod holders to the tool box but have also mounted them to the front of the bed. When i go surf fishing I slide the tool box to the tailgate and J bolt it down. They also work great to hold an umbrella and I have a pole to hang a coleman lantern on when I stay out all night.
  17. Feb 18, 2009 at 1:39 PM
    Bs 02 Taco
    Amelia, Ohio
    MPG: That is a sick set-up!!!
    I am starting crappie tourney fishing up here next month. so I dont think i need to go that extreme ;)
    But its rediculously sweet!
    Gives me an idea for my cap
  18. Feb 18, 2009 at 6:17 PM
    mpgnc64
    Mike and Denise
    Western NC
    I go to Carolina beach in NC. I came back in Apr 08 with an ass load of deployment money and went on a little spending spree. I haul my kayaks, fishing gear and a whole lot of beer and tequila!
  19. Feb 18, 2009 at 6:22 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    Here is how to tie down a shovel (courtesy of Don USMC Bulldog on our last wheeling adventure, I think he called it the $0.25 shovel mod )::goingcrazy: :D
  20. Mar 3, 2009 at 12:53 PM
    MCRANEY
    MCRANEY WARTHOG
    CRESTVIEW FL
    03 Tacoma 4WD SR5 TRD
    3" Lift 285/75 16R Tires Aries Stainless Steel Grille Guard, KC Lights
    Are you still looking for a fishing rod holder for the bed of your truck? I have a patent pending on one i have designed and have a proto type built. if you would like to see let me know.
