how to tighten belts???
Discussion in '1st Gen. Tacomas (1995-2004)' started by little bear, Jan 26, 2015.
  1. Jan 26, 2015 at 11:54 AM
    little bear
    little bear [OP] Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    When I start my 2000 tacoma with 3.4l it starts quietly but when its cold and I turn the wheel it makes a loud squeal that lasts for less than a second. It won't do it when its ran for awhile or while driving but just for a moment when the engine has sat a little while. I figure it has to do with my power steering belt.... can y'all tell me how to tighten that rascal???
  2. Jan 26, 2015 at 12:15 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
  3. Jan 26, 2015 at 12:27 PM
    little bear
    Barry Hobson
    Canadian, Texas
    I just had a shop replace the timing belt, water pump, and all the drive belts and also put a new a/c bearing on also.... all new drive belts came with the kit I so I am wondering if all I need to do is a simple tighten so my squeal goes away
  4. Jan 26, 2015 at 12:33 PM
    Noelie84
    Noel
    Wales, Maine
    Check the belts for proper deflection. There should be between 1/4 and 1/2 inch of movement when you push on the belt between pulleys. If there's more than that it's too loose and needs to be tightened up.
  5. Jan 26, 2015 at 2:16 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    It's only when you turn, right after turning the truck on? My truck does that, and it's got to do with my crappy reman power steering pump. Does the pump make any groaning noises when you just start the truck?
  6. Jan 26, 2015 at 3:30 PM
    little bear
    Barry Hobson
    Canadian, Texas
    the truck did groan and whine real bad but I found I had a bad bearing on my a/c so switched that out and after a timing belt kit the truck is really quiet on startup.... unless I turn the wheel a bit shortly after starting then the real quick and loud squeal
  7. Jan 26, 2015 at 3:59 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You have the 3.4L which has 3 separate accessory belts.
    You have to find out which belt is loose. Inspect all of your pulleys also and make sure they are all 'dirt' and 'oil free'
    In an open area of the belt, grab the edges with your finger & thumb. Twist the belt. You shouldn't be able to twist it past 'perpendicular'.
  8. Jan 26, 2015 at 4:21 PM
    little bear
    Barry Hobson
    Canadian, Texas
    The belt that goes around the alternator I can flip all the way over
  9. Jan 26, 2015 at 4:37 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Thanks for the link, I was just thinking I should change mine. Do you guys know if worn belts would cause a chirp at idle.
