How to tighten strut nut
Discussion in '3rd Gen. Tacomas (2016-2023)' started by papicodone, Feb 20, 2023.
  1. Feb 20, 2023 at 5:55 PM
    papicodone
    papicodone [OP] New Member
    Darnell
    Tacoma TRD OR
    I highly doubt this is supposed to look like this but I tried tightening the strut nut but keeps spinning I tried vice grips, crescent but no help it’s pretty seized. Is there another way I could tighten it? I really hope I don’t have to drop the shock. Thank you
  2. Feb 20, 2023 at 5:58 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…it’s loose for sure..who put the struts on it?
  3. Feb 20, 2023 at 5:59 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    What brand of shock is it?
    The nut might be bottomed out, as tight as it can go. Sometimes the problem is incorrect assembly of the coilover, missing a washer or spacer.
  4. Feb 20, 2023 at 5:59 PM
    Bishop84
    Bishop84 Well-Known Member
    Let the weight out a bit until it contacts and drags on the washer.
  5. Feb 20, 2023 at 5:59 PM
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
    Grip the shock with a vice grip and tight the bolt. Get the Milwaukee vise grip from HD for $15.
  6. Feb 20, 2023 at 6:02 PM
    papicodone
    Darnell
    Tacoma TRD OR
    It’s the oem TRD Pro shocks
  7. Feb 20, 2023 at 6:05 PM
    Superdave1.0
    SoCal
    You bought them used?
  8. Feb 20, 2023 at 6:09 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    That looks like a stover locknut? Those have very high rundown torque. If you can still loosen and remove the nut, replace it with a plain nut and lock washer from the hardware store.
    Swedish pipe wrench can grip a stripped shaft better than other wrenches. Example: https://www.amazon.com/MAXPOWER-inch-Swedish-Wrench-S-shape/dp/B0B2RQ63BV/
    Were you doing the in-vehicle spring compressor method? When done outside on a bench compressor, you would have been able to run the nut down with an impact, avoiding this problem. Anyway, water under the bridge now.
  9. Feb 20, 2023 at 6:10 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Threads look buggered but it should tighten down.
    Traditionally you are supposed to put a small box wrench on the top of the post while tightening down the nut. But that looks buggered also. Vise grip the top, tighten nut.
    HondaGM likes this.
  10. Feb 20, 2023 at 6:39 PM
    Superdave1.0
    SoCal
    If the threads are crossthreaded I wouldn't trust the shock to be safe. Those threads and that nut are what keeps the coilover from coming apart. I assume they are.
    As stated try a different nut. Also inspect the threads when you get that nut off.
    faawrenchbndr and HondaGM like this.
  11. Feb 20, 2023 at 6:42 PM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Yikes
    HondaGM and hiPSI like this.
  12. Feb 20, 2023 at 7:36 PM
    papicodone
    Darnell
    Tacoma TRD OR
    Thank you all for the help. Vice grips weren’t grabbing and little room to work with so I end up having to drop the shock and tighten while off the truck.
    Crikeymike, 908tacoma and HondaGM like this.
