How to touch-up paint, rear window
Discussion in '1st Gen. Tacomas (1995-2004)' started by ronopolis, Mar 29, 2015.
  1. Mar 29, 2015 at 6:11 PM
    ronopolis
    ronopolis [OP] Ronopolis
    Ron
    Ft. Collins, CO
    '22 DCSB TRD Sport
    The black paint around my '96 Tacoma's rear window has been flaking off. You can see it in the picture on both vertical and horizontal pieces of metal. How can I touch this up? Just tape it off, spray on some primer and then a black paint that kinda' sorta' matches? Doesn't have to be perfect. Looking for any hints so I don't do anything dumb :)
    GQ7227 likes this.
  2. Mar 29, 2015 at 6:14 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think some people use flat black vinyl trim tape. [​IMG] Go carbon fiber!
  3. Mar 29, 2015 at 6:47 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    if you want to paint on metal you need self etching primer first so it sticks.
    I think its like a powder coat finish on it and corrosion and moisture gets under it and separates from the metal so it will probably keep on peeling in different spots over time.
    if you want a once and done solution they pull out the back glass and sand it all to bare metal then repaint and reinstall, it will look new again and last forever. all depends how much work you are willing to put into it.
    if its just a truck and you don't care then do the tape solution
    GQ7227 likes this.
  4. Mar 29, 2015 at 6:48 PM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    No perfection needed? Black magic marker. Done.
  5. Mar 29, 2015 at 8:30 PM
    ronopolis
    Ron
    Ft. Collins, CO
    '22 DCSB TRD Sport
    I had never even heard of the tape solution. Seems good enough for me. Is the flat black vinyl trim tape something I get at a car part shop? Or I can order it from Amazon or someplace online?
  6. Mar 29, 2015 at 8:41 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah there was a member here a couple weeks ago that ended up using that tape on his "trim strips" under the door windows. He was satisfied. I'm gunna do the same for myself. My under window pieces are peeling off exposing the chrome(I hate chrome!) So I'll give her a try, kinda worried about the tape not addhearing super well but well see. Its better than chrome poking through here and there!
  7. Apr 25, 2015 at 3:34 PM
    ronopolis
    Ron
    Ft. Collins, CO
    '22 DCSB TRD Sport
    Just for closure (I'm the OP) thought I'd finish up this thread. For my '96 tacoma with lots of paint missing and chrome showing around the rear window (see picture in my post), I bought some black vinyl trim tape as suggested.
    And it worked great! My first time doing it, so it wasn't perfect (if you are really looking close). But from even a foot away, it looks fine, and much better than the missing paint/chrome. Plenty good for my 18 year old son who will be inheriting this 19 year old truck. I tell you, the more I hear about how much people like Gen 1's, I'm wondering if I should get a newer truck for him, and I keep my '96 ;). It will be a sad day when I hand over the keys.
    I had never even heard of the trim tape, and now it is all done and looks great. Thanks for the suggestions and help.
    Wulf and GQ7227 like this.
  8. Apr 25, 2015 at 4:24 PM
    Madjik_Man
    Colorado Front Range
    This is TW.... pics, NOW!
    GQ7227 likes this.
  9. Apr 25, 2015 at 6:42 PM
    ronopolis
    Ron
    Ft. Collins, CO
    '22 DCSB TRD Sport
    My bad. I'll post picts tomorrow when I can get some shots in natural light.
  10. Apr 26, 2015 at 11:00 AM
    ronopolis
    Ron
    Ft. Collins, CO
    '22 DCSB TRD Sport
    You can see the before picture in my original post. Here is the after picture. From 2 feet away it looks fine., From 6" away you can see subtle seams etc., but who cares. I didn't just tape the part with the chrome showing through. I did all of of the back so it would look consistent.
  11. Apr 26, 2015 at 12:21 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    I just used Testors enamel model paint. YMMV.
    GQ7227 likes this.
  12. Apr 26, 2015 at 12:51 PM
    ronopolis
    Ron
    Ft. Collins, CO
    '22 DCSB TRD Sport
    We'd have to see them side-by-side to see which is better. I'd think if you were careful with the paint, it would look better. No small overlap seams or possible tiny air bubbles. But with the tape you don't have to be careful. More or less just press it on, and use a knife to cut off the overlap.
  13. Aug 8, 2019 at 12:16 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    interesting old topic, my black window frame seems to be fading (normal stuff) and want it to look sharper if possible good as like new
    the testors sounds good, magic marker probably would wash off easily?
    the tape may be a good solution too, i don't know :facepalm:
    i like this solution below too for longevity, has anybody done this?
