How to turn off you seatbelt reminder sound
Discussion in 'Technical Chat' started by mytacoma08, Apr 10, 2012.
  1. Apr 10, 2012 at 11:39 AM
    mytacoma08
    mytacoma08 [OP] Member
    Brandon
    Austin, Texas
    O8 Tacoma Prerunner TRD Sport 6ft bed
    Re: 2008 Tacoma Seat Belt warning buzzer
    It worked perfectly on my 2008 Double Cab
    Short version:
    1) Turn the Truck 'ON', but do not start the engine. Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the truck. As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
    Long Version from repair manual:
    This setting is only valid for the buzzer which sounds at the 5 km/h (3 mph) or more.
    SEAT BELT BUZZER ON/OFF SETTING (Procedure "A")
    The seat belt buzzer ON/OFF setting, which is a setting of the buzzer function of the combination meter, can disable the driver and front passenger side seat belt buzzers.
    "b-oFF" indicates that the buzzer is OFF.
    "b-on"indicates that the buzzer is ON.
    The seat belt buzzer ON/OFF setting will be finished (the odometer will display "ODO") if the ODO/TRIP switch is not operated for 10 seconds or more.
    In this case, perform step 11 to check that the buzzer ON/OFF setting is complete.
    If it is not complete, start from step 1 again.
    (1) Driver and front passenger side seat belt buzzers
    1. Turn the ignition switch on (IG).
    2. Press the ODO/TRIP switch until the odometer displays "ODO".
    3. Ignition switch off.
    4. Turn the ignition switch on (IG).
    5. Press the ODO/TRIP switch immediately (within 6 seconds) and hold it down for 10 seconds or more.
    6. Continue holding down the ODO/TRIP switch and fasten the driver side seat belt.
    7. Check that the odometer displays either "b-on" or "b-oFF".
    8. Press the ODO/TRIP switch to change the display to "b-oFF".
    9. Ignition switch off.
    10.Turn the ignition switch on (IG).
    11.Check that no buzzer sounds.
    (2) Front passenger side seat belt buzzer
    5. Sit in the front passenger seat. Press the ODO/TRIP switch immediately (within 6
    6. Sit in the front passenger seat. Continue holding down the ODO/TRIP switch and
    fasten the front passenger side seat belt.
    8. Press the ODO/TRIP switch to change thedisplay to "b-oFF".
  2. Apr 10, 2012 at 11:42 AM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    i do believe this is already in the sticky,did this awhile back so much better not hearing that noise...good looking out though
  3. Apr 10, 2012 at 12:02 PM
    mytacoma08
    Brandon
    Austin, Texas
    I figured it was already done but I did this not to long ago and I just wanted to pass the word.
    It all started over my buddy with a silverado complaining about how annoying my Tacoma is with its seatbelt noise. He said that silverados are work trucks and they dont have a seatblet noise because GM takes into consideration that you have to get in and out of the truck. lol I was like wow.
  4. Jul 9, 2012 at 12:25 PM
    mtwiford
    mtwiford Member
    Virginia
    2012 TRD Sport Upgrade
    has anyone tried this on a 2012? It did not work for me, did it 5 times. The odo never changes to b on
  5. Jul 9, 2012 at 12:25 PM
    mtwiford
    mtwiford Member
    Virginia
  6. Jul 9, 2012 at 12:30 PM
    XIGUNHAWKIX
    XIGUNHAWKIX Just a desert dude.
    Luke
    Taos, NM
    SR5 4WD Base Project Truck
    Entune touchscreen display, JBL system, blacked out, Icon 2.5 Remote Resis, TC UCA's, 50" LED LightBar. Pelfreybilt bumper.
    Didn't work for my 12 either man, had to get the guys at the dealership to disable it with a computer. Only took a few minutes though and free :D
  7. Jul 9, 2012 at 12:32 PM
    Aw9d
    Aw9d That one guy
    Az
    This will not work on the 2011's with the white faced gauges, or 2012's. You will have to take it into the dealer and get them to do it. I've been trying to get it shut off but my dealership won't do it for liability reasons.
    You can also take off the speaker that's attached to the gauge cluster.
  8. Jul 9, 2012 at 1:54 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    I haven't searched yet but does anyone know off the top of there head how to disable the horn hocking when arming the factory alarm?
  9. Jul 10, 2012 at 7:25 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    2012 mgm dcsb 4x4 and 2008 swb x-runner
    go back to the dealer and tell them to remove their dealer installed alarm. its going to give you issues down the road and that will disable the horn honking issue
  10. Jul 11, 2012 at 8:28 AM
    mytacoma08
    Brandon
    Austin, Texas
    To turn off your honk noise go to your trucks manual and look up alarm system. It will tell you how to turn it off. You will end up pushing in your alarm light a few times and that disables it. I have turned on my honk and turned it off many times.
    And I wouldn't go to the dealer and disable the whole alarm unless you go get an new alarm system. (after market) My alarm system doesn't mess up any of my stuff.
  11. Jul 11, 2012 at 8:59 AM
    zeekevin
    San Diego
    Have you taken a look at the shitty install they do with the dealer installed alarms? Just look under your driver side kick panel
    The alarm unit is normally made by karr, which the dealer has a 3rd party do the installed which is a hack job because they are paid by the car when they install it. And every car on the dealer lot has to have one per their dealer insurance policy. So at the point of sale of the car/truck whatever the dealer will try and charge the customer a stupid amount of money for a piece of shit $20 alarm. Talking to some dealers here in the socal area when shopping for my truck they tried to force on the alarm package for 1k, 800, 500,300,200, 100...
    A nice aftermarket alarm is nice, but a good alarm is only good if the installer knows what the hell they are doing.
  12. Jul 11, 2012 at 9:02 PM
    mytacoma08
    Brandon
    Austin, Texas
    Dang I didn't know that. Wow they made some good profit off that!! I guess the only thing that will keep the truck from being stolen is the chip I the key. Won't start whithout it???
    And thanks for that information I really wasn't aware of that.
  13. Jul 16, 2012 at 8:53 PM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    To get the seat belt buzzer off I heard a great tip.
    BUCKLE UP and it shuts off.
    That is all
  14. Nov 16, 2012 at 5:58 PM
    rokedawg
    rokedawg Active Member
    NY
    09 dbl cab trd off-road 6sp mt
    I just want to say "thank you". It worked on my 09.
  15. Nov 17, 2012 at 11:32 AM
    mytacoma08
    Brandon
    Austin, Texas
    Your welcome!
  16. Dec 2, 2012 at 5:12 PM
    fj40taz
    fj40taz Well-Known Member
    Carl
    Williamstown, NJ
    10 Toyota Tacoma
    Flowmaster Exhaust
    i did this on my 2010 and worked great..
    thanks
