How to unlock truck without remote?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tah-koh-mah, Sep 14, 2020.
  1. Sep 14, 2020 at 8:37 AM
    Tah-koh-mah
    Tah-koh-mah [OP] Well-Known Member
    2012 Tacoma TRD-Off Road
    So I bought my 2012 Tacoma a few months ago and didn't realize I can't open the door with just the key inserted into the key slot on the door. Am I doing something wrong? Why can't I just insert it in and turn? Am I missing something? Sorry for a such a rookie question.
    I'm wondering if my remote battery dies or gets wet or whatever, I will be locked out?
  2. Sep 14, 2020 at 8:42 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I can with mine, you must have a incorrect key. Maybe previous owner gave you a key that wasn’t programmed cause he found out what it cost.
    wilcam47, SR-71A and Tac0maSteve like this.
  3. Sep 14, 2020 at 8:56 AM
    Tah-koh-mah
    I can unlock the truck with the remote and can start the truck with the key. I just can't unlock the truck by inserting the key into the door keyhole. Could it just be that the keyhole/tumblers are stuck? What other issues could it be?
    djthicks likes this.
  4. Sep 14, 2020 at 8:57 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Just use a brick bro.
    racerX969, Jojee117 and TexasWhiteIce like this.
  5. Sep 14, 2020 at 8:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You could try getting some lock lube and putting it in there. It's like a dry graphite type lube (don't use WD40 or anything like that).
    DiscoYaker likes this.
  6. Sep 14, 2020 at 9:01 AM
    spitdog
    yea, try some graphite, don’t squirt liquid stuff in there it will just collect grit. Get some dry graphite at the auto store and try that.
  7. Sep 14, 2020 at 9:07 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Do you have 2 keys? Try both. Does the key look newly made? With my older Colorado truck the Remotes worked but newly made keys wouldnt open the doors, the dealer I bought it from their “key man” did a little filing in the keys to make them work for the door.
  8. Sep 14, 2020 at 9:08 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Maybe your not sticking it in far enough
    wilcam47, Jimmyh and Kirky like this.
  9. Sep 14, 2020 at 9:19 AM
    Tah-koh-mah
    So the consensus is to use more lube and to insert it in further correct? Not just the tip? She's still new to me, I don't want to break anything going in deeper.
    We're still talking about my truck right?
  10. Sep 14, 2020 at 9:57 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Yes,but look at both keys first, to make sure they have the same cut in them.
  11. Sep 14, 2020 at 10:13 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I just opened mine with a key. Truck was locked with first with remote. Door opened and I was then able to start truck with key.
  12. Sep 14, 2020 at 10:14 AM
    ohiowa
    ohiowa Have you tried rebooting?
    Ohio
    2015 Super White TRD OR DCSB V6 6MT
    ARE Overland Shell
    You could also be in a situation where your driver door has been repaired or replaced (perhaps due to collision damage or something) and they didn't key it the same as the ignition because of cost.
    Could also be that your ignition and key have worn at the same rate and are "used to" each other, where the tumblers in the door handle may still be newer and more sensitive to worn key teeth.
  13. Sep 14, 2020 at 10:27 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Next problem :) The truck's alarm will sound and disable the ignition when you open the door with the key. If your remote battery is dead, you won't be able to turn off the alarm.
  14. Sep 14, 2020 at 10:37 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Sounds like a huge pain in the butt. The guy who designed this system is probably laughing.
  15. Sep 14, 2020 at 10:44 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Sounds like the truck was in an accident and had the door replaced, hence the lock is keyed differently
    Soylent Green2012 and wilcam47 like this.
  16. Sep 14, 2020 at 10:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Most OEM car alarm systems are designed this way. The remote fob battery lasts 8-10 years or more, and the truck came with two remotes when new. A more realistic concern for needing the door key lock is when your truck's battery dies.
    @Tah-koh-mah if lube is ineffective, take it to a shop (or the dealer that sold you the truck). They'll probably have to call in a locksmith. Another option is to replace the door lock cylinder with a new one, if you don't mind carrying two keys.
  17. Sep 14, 2020 at 10:57 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    :rimshot:
  18. Sep 14, 2020 at 11:37 AM
    coopcooper
    alberta canada
    you usually take the guts out the old door, maybe theft recovery
  19. Sep 14, 2020 at 1:11 PM
    Muddinfun
    Muddinfun Well-Known Member
    If lubing the lock doesn't solve the problem, take the lock out and take it to a locksmith and have them FIX the lock. Do not buy a new lock. Whether the lock is worn or keyed wrong, the locksmith can fix it. Removing the lock from the truck is easy. There's a plastic plug and a single bolt in the edge of the door. The bolt is held captive by plastic fingers, so you can't drop it down into the door. When you remove the lock, be gentle with the door handle. The lock keeps the door handle from coming out. If you do pull the handle out, it's easy to pop it back in.
    Jimmyh and 3JOH22A like this.
  20. Sep 14, 2020 at 1:27 PM
    HONY BADGER
    HONY BADGER Missing my memes
    BADGER
    2010 DBLB Silver Taco
    When I bought my truck I had only one key ,I went to my local hardware store and they programed a new one ,that will open the door and start truck for $90.00. GOOD LUCK
