How to unlock truck without remote?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tah-koh-mah, Sep 14, 2020.
  1. Sep 14, 2020 at 2:57 PM
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    I had my local walmart cut an program a new key for me for 63$. Sounds like the tumblers may be your issue not really the key. Does it work on the passenger side door?
  2. Sep 14, 2020 at 4:41 PM
    Tah-koh-mah
    Tah-koh-mah [OP] Well-Known Member
    2012 Tacoma TRD-Off Road
    Thanks @Muddinfun your post helped me take out the lock assembly and looked at the tumblers/pins and noticed they were not aligned and so could not turn. The notches in my key were so worn that one of the pins weren't sitting in the notch correctly and so it would not turn.
    Should I get a new key? Funny thing is that the same key will start my truck just fine.
    Would walmart be able to provide me a key or would I need to go to a locksmith or the dealer?
    Muddinfun[QUOTED] likes this.
  3. Sep 14, 2020 at 4:42 PM
    Tah-koh-mah
    It was the key. It's so worn that one of the pins was barely sitting correctly and so the tumbler couldn't turn. Was that price at walmart just the key itself?
  4. Sep 14, 2020 at 5:15 PM
    Muddinfun
    Muddinfun Well-Known Member
    You shouldn't be going to Walmart for lock & key stuff. Go to an actual locksmith.
  5. Sep 14, 2020 at 5:17 PM
    Tah-koh-mah
    Yea I was thinking that too. Now to find a locksmith that actually knows how to program a tacoma key.
  6. Sep 14, 2020 at 5:19 PM
    Muddinfun
    You can get pirated Techstream for about $40 or $50, put it on a laptop, and program keys yourself, since you have 1 key that already starts the truck. Go to OBD2innovations. They have their stuff together. You can also do other cool things with techstream.
  7. Sep 14, 2020 at 5:20 PM
    GRNT4R
    NC - Triad
    TBD
    It was the key and thr programming of it. They do transponder keys and have the machine to program it. The key was 63$ and that including cutting and programming it. Lowes also does and use the same brand keys but they were 75$.
    Tah-koh-mah[OP] likes this.
  8. Sep 14, 2020 at 5:32 PM
    GRNT4R
    NC - Triad
    TBD
    This is the key and model number i bought. They have them in a locked cabinet at the keymaking station with a device that programs the transponder chip based off the key you bring in. has been working fine since buying it. Didnt know they programmed or did transponders so i think its a new feature for them
    Hillman TOY43-EK
  9. Sep 14, 2020 at 6:17 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    My key is worn down to the point I can remove it from the ignition with it running and it still opens the drivers side door. I have two blanks ready to go, I just have to get them cut.
  10. Sep 14, 2020 at 6:53 PM
    Muddinfun
    All the more reason you need to go to a locksmith. Wallmart would probably just make a copy of your worn out key, and then you would have a brand new worn out key. If I were you, I would take your registration and ID to the Toyota dealer. Tell them you would like to get the key code by VIN. Do not have them make you a key. Just get the code from them. Generally they only keep the key codes going back 10 years, but you're close, so they might have it. Doing this is assuming nobody has rekeyed your truck. Take the key code to the locksmith and have them cut a key by code. You might have them cut a cheap plain metal key 1st to make sure it works. Cheap plain metal keys are great for a hide a key, wallet key, etc.
    spitdog likes this.
  11. Sep 14, 2020 at 10:46 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    :rofl:I've never heard that before.
    spitdog likes this.
  12. Sep 14, 2020 at 10:55 PM
    djthicks
    djthicks Well-Known Member
    Orange County
    07 DCLB TRD Sport
    King's all around Long traveled Methods KO2s
    Same as mine... got a new key it opened both doors fine, Looking to get an aftermarket remote start alarm now to use as the primary and key as secondary
  13. Sep 15, 2020 at 3:03 PM
    08TacoTrD
    08 TRD Offroad
    Ha, yea, I wouldn't go to Wallyworld for this, did get 5 quarts of M1 for $22 this weekend though, waiting on the rebate now. Whenever I get enough motivation, I'll get the code and have it cut.
  14. Sep 15, 2020 at 3:07 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Future reference for anyone else who may run into this issue.
    I ran into an issue where my old truck only seemed to lock the driver's door about 50% of the time. I found out, many months later when I had to replace the broken door handle, that the arm used to actuate the lock had somehow come out of its plastic housing. I popped it in on the new handle and never had an issue since. Knowing that, I have no idea how it actually was locking.
    You have to remove the door panel to get to it though.
  15. Sep 15, 2020 at 3:16 PM
    #35
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    I'm with this! I have a couple plain metal / 'valets' keys. They will open the truck but won't start the truck (at least in the manual transmission) but its the cheaper way to start and like they said above itll be a great hide a key
