How To: Upgrade your gauge cluster from SR to SR5+
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bob_Lee_Swagger, Dec 24, 2017.
  1. Nov 17, 2018 at 6:20 PM
    #101
    magicgus323
    magicgus323 Well-Known Member
    Gustavo
    Visalia Ca. East LA LBC
    2016 White Tacoma Sr 2.7
    TRD rims and suspension, TRD grill, stereo iPhone mirroring stormtrooper decal backflip bed cover painted bumper and mirror caps
  2. Nov 18, 2018 at 8:53 AM
    #102
    magicgus323
    Gustavo
    https://www.ebay.com/itm/TOYOTA-Ins...r-PROGRAMMING-/322926528941?fits=Model:Tacoma
  3. Nov 24, 2018 at 5:13 PM
    #103
    My Truck
    My Truck Well-Known Member
    Bay Area, CA
    2016 SR DCSB 4x4 Super White`
    Is there a difference? Do you have a picture?
  4. Aug 25, 2019 at 4:23 PM
    #104
    Smoothmove
    Smoothmove Well-Known Member
    Stan
    Dallas TX
    2020 TRD OR CEMENT
    MesoCustoms
    magicgus323 likes this.
  5. Aug 26, 2019 at 10:53 AM
    #105
    magicgus323
    Gustavo
    I just did the swap on mine go by mine programmed to right mileage but can’t get the steering controls to work
  6. Aug 26, 2019 at 2:17 PM
    #106
    Smoothmove
    Stan
    Dallas TX
    2020 TRD OR CEMENT
    MesoCustoms
    Mine plugged right in without doing the wire mod on page 1 of this thread.
  7. Aug 26, 2019 at 3:02 PM
    #107
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    I was planning on doing this swap and I have wheel controls and cluster. If someone is interested please let me know.
  8. Aug 26, 2019 at 6:32 PM
    #108
    magicgus323
    Gustavo
    How much for wheel conteols
  9. Sep 17, 2019 at 2:13 PM
    #109
    CyberJock13
    CyberJock13 Active Member
    BSly (916)
    Sacto, California
    2016 Black TRD 4x4 Sport
    275/70/18s, Fuel rims, OEM Audio+ with sub, Meso,
    I can't honestly give you enough props for this write-up..while I have the SR5 model, I never knew there was a lesser gauge cluster even out there..learn something new every day on here
    onesixonetwo likes this.
  10. Nov 8, 2019 at 2:21 AM
    #110
    Sam091990
    Sam091990 Well-Known Member
    Sam
    BLK '12 DCLB PreRunner TRD Sport V6
    Marsauto LEDs in license tag lights Marsauto LEDs in map lights Yorkim Red LEDs in High mount brake light Zevo LED in dome light (may change that, it is not too bright)
    I wanna do this but put a 3rd gen SR5 one in my 2012 Tacoma. Anyone know if it is possible?
    Sam
  11. Nov 8, 2019 at 2:39 AM
    #111
    Claudiomartinof
    I have a trd cluster and the wheel controls... I was asking around $300 for all but at this point for $150 is yours...
    09 Redneck likes this.
  12. Nov 8, 2019 at 2:40 AM
    #112
    Claudiomartinof
  13. Nov 9, 2019 at 2:33 PM
    #113
    FlashTide
    FlashTide Member
    Jay
    2014 White TRD
    3" body lift, 4" Suspension, 33" nitto exos, 2" wheel spacers
    Anyone know if this is possible to do on a 2nd gen? As in taking a 3rd gen cluster and putting it in my 2014 taco?
  14. May 13, 2020 at 5:59 PM
    #114
    David McGinnis
    David McGinnis Well-Known Member
    David
    Sierra Vista, AZ
    2021 4X4 Sport AC 3.5L MT - OME lift with Dakar leafs. 10x33 Coopers. ARB Bumper. KDMax Tune. 2017 SE AC 2.7L 2WD AT - OME lift with Dakar leafs, BA bumper, tooter manifold spacer, header, OVTuned. LED lights. Does not run like your average 2.7; this truck pulled a broken down HMMWV out of a wash. 2008 PreRunner 4.0L - 3" spring lift with Bilstein 5100s, ARB bumper, rear sway arm. Old Reliable, been around, beat up, and still runs like a beast.
    There is nothing like bringing back an old post from the dead - even a great one like this. So here goes.
    Purpose:
    The reason I am posting is several people in this thread asked (like more than a year ago) about what is different with a 2.7L cluster. Well, I found out the hard way.
    Information:
    If you stick a 6 cylinder cluster into a 4 cylinder truck, everything will work great. You will proudly go for a drive, adore the multifunction display, and will have convinced your self you are the coolest of the cool. Then, about after ten minutes or so, a Engine Low Oil Level message will appear on your new multi-function display. You will pull over, check you oil, and probably see that your oil is full. You will check it about a dozen or so more times, thinking your an idiot, and now not so cool, each time the warning appears.
    So here is the deal. The 2.7l does not have a Engine Oil Level Sensor (just oil pressure). The wiring isn't in your truck. So when the sensor is checked, it reads Open and indicates a fault.
    So that is the difference. Pin 36 on connector C9 (the back of the cluster) is for the oil level sensor. This position is not populated with a wire in the mating plug. First experiment was go ground Pin 36 to Pins 17&18. I'm still working on it. If anyone cares, I'll report back.
    David
  15. May 13, 2020 at 6:03 PM
    #115
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Good troubleshooting.
    That answers this guys problem exactly.
    https://www.tacomaworld.com/threads/low-oil-level-message-after-cluster-swap.646579/
  16. May 13, 2020 at 6:15 PM
    #116
    David McGinnis
    David
    Sierra Vista, AZ
    exactly his problem.
    I see they are looking at Pin 25, the oil pressure switch. The Oil Level sensor is on Pin 36 and that routes through IH2, which is behind the glove box. The 2.7L truck doesn't have IH2 populated.
    The 2106 service manual says the oil level sensor is On when the resistance is below 1 Ohm, and Off when the resistance is above 10K Ohm.
    The fact that grounding Pin 36 doesn't work, makes me think the power source for the transistor switch/buffer in the cluster comes from one of the other missing pins on C9. I have the common wiring diagrams for the truck, but not the schematic for the cluster itself. That would tell me the rest of the story.
  17. May 13, 2020 at 6:24 PM
    #117
    2016Tacoman
    J
    If the oil sensor is on with less than 1 ohm (gnd), wouldn't off be high (+V) instead ? How about sending 12v on pin 36 through a load resistor of say 1k for protection ? Sometimes high impedance doesn't work (drive) for high. You've done a lot more research on this so disregard if it sounds off.
  18. May 13, 2020 at 8:01 PM
    #118
    magicgus323
    Gustavo
    I did cluster swap and having a problem with engine low light but it’s good how can I source wire to sensor too fix it and my steering controls don’t work I have not cut them like op mine are different color wires I need help please am willing to pay someone to fix steering controls and engine low light thank you!
  19. May 16, 2020 at 2:53 PM
    #119
    David McGinnis
    David
    Sierra Vista, AZ
    here is the real problem. When you try to ground pin 36, and you ground pin 35 because you weren't wearing your good glasses - what you want to happen doesn't happen.
    the Oil Level Low notification goes away if you actually ground pin 36.
    So, solution for 2.7L owners with instrument cluster from a V6. Ground pin 36.
    2016Tacoman and magicgus323 like this.
  20. May 16, 2020 at 6:09 PM
    #120
    magicgus323
    Gustavo
    Can I see how you grounded it can you take some pictures
