How to use 4wd in 01 Limited?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SlimDigg, Sep 24, 2010.
  1. Sep 24, 2010 at 7:09 PM
    SlimDigg
    SlimDigg [OP] We Back!!
    Calgary, AB
    Coming Soon....
    Hey guys,
    Got my new truck today wooo!!
    A 2001 Tacoma Double Cab Limited.
    Also found out I have no idea how to use 4wd, and there was NO MANUAL in the truck.
    My options are: 4L - N - H. There is a 4wd button on the side of the 4wd shifter. There is also a locking rear diff and ECL.
    My questiona are these:
    Can you provide the step by step procedure to engage 4wd and the rear diff?
    I understand that the rear diff locks the rear axle so the rear tires spin at the same rate.
    What do 4L (4wd lo speed i'm assuming), H, and ECL mean?
    What does ECL do?
    Thanks!
  2. Sep 24, 2010 at 7:15 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    what is it?
  3. Sep 24, 2010 at 7:22 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    How did you miss this?: "...and there was no manual in the truck."
  4. Sep 24, 2010 at 7:25 PM
    SlimDigg
    Calgary, AB
    Coming Soon....
    2001 tacoma double cab limited
    I edited the orig post, sorry bout that.
  5. Sep 24, 2010 at 7:38 PM
    David K
    I had a 2001 4WD Off Road TRD Tacoma... great truck, never broke down in 136,000 miles!
    The transfer case shifter is the lever next to the standard tranny shifter. A transfer case is what puts the drive to the front (and rear) tires... it is located right behind the transmission.
    The choices are to push the button to go into H4 (4WD high range... same gearing as you have in 2WD, normal speeds). Then to go into L4 (4WD Low Range) you move the lever into that position while STOPPED, in NEUTRAL (or clutch fully pushed in if manual tranny).
    Low range is low gears for max. power, and slow speed... Use this for steep grades, off road, deep mud, and any situation where you need the most power... Max. speed in high gear will be 30-40 mph... You would usually never go close to that in low range.
    High Range is shift on-the-fly, while moving (up to 60 mph), or still... a few feet of movement may be needed to engage or disengage the 4WD. Light goes from blinking to solid when engaged. Do not use 4WD on DRY PAVEMENT as the front and rear drive shafts are locked together, and when turning, they need to move at different rates. Use for wet, icy, snowy roads, low traction conditions, and deep sand (lowering tire air pressure may also be needed for sand).
    The RR Locker (Rear Locker) works ONLY in Low Range... light goes from blinking to solid when locked. This is for climbing or really poor traction or uneven surfaces where one tire may be off the ground... with the rear locked, the other tire will continue to work at moving you. Without the rear locker, one tire off the ground will just spin and the other will do nothing (open differential). Having 4WD will at least give you one or two tires in front pulling you. An aftermarket front locker can be added to give you true 4 wheel drive... or the newer Tacomas have A-TRAC to provide full traction.
  6. Sep 24, 2010 at 7:45 PM
    SlimDigg
    Calgary, AB
    Coming Soon....
    Ok should I be driving around in N or H? Currently there is no light on (the little green frame with 4 wheels and the front wheels are turned).
    If i'm cruising along in the winter and I hit some snow, I can just push the 4wd button the side and then I would be in 4high? Or do I shift the into H then press 4wd button?
  7. Sep 24, 2010 at 7:52 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Ok the "N" stands for neutral, you don't want that keep it in "H" for high
    this is normal driving mode & yes you can push the button on the fly (while driving) to engage from 2w to 4w.
  8. Sep 24, 2010 at 7:53 PM
    David K
    Umm... you can push the button while still/ stopped... it may not click in until you move a bit. There should be two shifters (levers)... one for normal driving and a second that looks like a joy stick or emergency brake with a button on the side of it... There should be TWO HIGH positions... H2 and H4, you are only mentioning one...? Normal driving is H2... Canadian winters will be H4 or maybe L4!!! Button unclicked is 2WD Hi and Button clicked is 4WD Hi. Lever pulled is 4WD Low... while stopped, in Neutral on your regular tranny.
  9. Sep 24, 2010 at 7:56 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Umm but I don't have a button just lever for transfer
    Whats going on old man !! :D
  10. Sep 24, 2010 at 7:59 PM
    David K
    On my 2001 TRD O/R Automatic... there was the joy stick lever next to the tranny shifter, and a button on it, thumb activated. Push button for H4 and pull lever for L4.
  11. Sep 24, 2010 at 8:03 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    To shift into 4wd all you do is press the 4wd button. The fastest you can go and shift from 2hi to 4hi is around 60mph. if you're going too fast, it'll buzz at you.
    To engage the locker you have to go to 4Lo unless you do the grey wire (search for it)
    You can go from 2Hi to 4Lo with just shifting the tcase up--it's designed to shift into 4WD whenever the tcase is shifted into low range (this can be changed tho, gaining you 2Lo)
    Shift the tcase when stopped. Engage the diff lock when moving under 5mph.
    The diff locks only when the axle shafts line up. If they arent aligned and you're just going straight the axle wont lock. If thats the case, just turn the steering wheels back and forth slightly so one tire spins faster than the other.
  12. Sep 24, 2010 at 8:05 PM
    David K
  13. Sep 24, 2010 at 8:08 PM
    pittim
    Pennsyltucky
    Boujee Prius
    There were two types of shifters. Push button and JShift.
    Pushbutton was a straight line, H up to N up to L4
    J shift is 2H, then shift the lever down and right (i think) to 4H, then up to N then up to L4.
  14. Sep 24, 2010 at 8:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    That's because you have an old ass truck. Get with the program... :D
    Starting with the '01s (I think), we got a cool little button on the lever. So we Elite guys only have to press it to get into 4Hi. :p
  15. Sep 24, 2010 at 8:42 PM
    SlimDigg
    Calgary, AB
    Coming Soon....
    OK!
    Thanks so much guys, I believe I understand the system now. Like I said, I received the truck TODAY and there was no manual. I am definitely going to purchase a manual ( I was always going to). I just wanted this question answered quicker than ordering a manual from ebay and waiting 2 weeks or a month to get it.
    Rep all around, thanks again guys, TW comes through again..stay tuned for my next noob question, whenever that comes :D
    JPTonka18 likes this.
  16. Sep 24, 2010 at 9:35 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Have u tried flipping down ur drivers side visor...You should find a little card in there that explains how to use 4WD...
  17. Sep 25, 2010 at 7:33 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I don't have the button either and glad of it,button means solenoid>means failure.
  18. Sep 25, 2010 at 8:51 AM
    David K
    I didn't know there was a change between the '01 (button for H4) and '04?
  19. Sep 26, 2010 at 4:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What method do you use on your '04 to shift into 4 wheel drive, high range?
  20. Sep 27, 2010 at 8:56 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    of course he has the button...he just doesn't know it
