How to use Anytime Front Camera with Sony AX6000 Head unit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrTreehorn, Jun 4, 2023.
  1. Jun 4, 2023 at 9:26 AM
    MrTreehorn
    MrTreehorn [OP] 2016 TRD BUILD IN PROGRESS
    Dan
    SF East Bay
    2016 TRD OR 4x4 MGM
    King 2.5s F/R, Icon RXT Leafs, Camburg UCAs, Wheeler's Offroad Superbumps, AllPro Spindle Gussets, JDFab Double Sheer Steering, RCI Skids, Bay Area Metal Fab Shackles and Hangers, Bay Area Metal Fab Gas Tank skid, RRW RR7H Flow Formed, 34" Mickey Thompson Baja Boss A/Ts , AllPro Sliders, Snug top Camper shell, MESO Customs bits n bobs, Powerbrake BBK, SSO Hybrid Front Bumper, Baja Designs 20" Amber LB, Warn Evo 10s
    Hi, I recently upgraded my stock JBL system in my 2016 Tacoma and installed a Sony AX6000 head unit. I had an existing Anytime front camera installed that worked with the stock head unit with a switch to toggle between the front/rear cameras. All of my wires are still connected but the switch doesn't seem to work with the newer head unit.
    I couldn't find any posts on this before, so thought I'd make one for some help and guidance on how to get my front camera to work?
  2. Oct 11, 2023 at 5:32 AM
    Taco de Naranja
    Taco de Naranja Well-Known Member
    Benny
    NW WI
    2017 TRD Sport DCSBAT-Inferno
    Hi Dan, I recently reached out to Trail Grid Pro with a question that might help you if you’re still looking for an answer…
    Your Message:
    Kicking the tires on purchasing a SONY XAV-9500ES. I already have an Anytime Backup/Front camera installed with the OEM style switch. Would I be able to retain the switch and would the camera feed show up on the Sony unit via the switch?
    Trail Grid Response:
    To get an Anytime Camera Kit to work as intended with a Maestro Sony bundle you'll need to do the following:
    • Cut a new stripe of 18 - 22 gauge wire about 12 inches long.
    • Strip the wire back at both ends and attach a t-tap on both sides.
    • Tap one side of the new wire to the "orange" wire from the Anytime Kits override harness.
    • Tap the other side of the new wire to the "purple w/ a white stripe" wire from our Sony bundle harness.
    This will restore full functionality of your Anytime kit when paired with one of our Maestro Sony bundles.
    Pickeledpigsfeet likes this.
  3. Aug 31, 2024 at 8:16 AM
    AZgray
    AZgray Active Member
    dave
    Peoria, AZ
    2020 TRD offroad Access Cab Magnetic Grey
    CaliRaised hidden bumper light bar Matt Gecko bed light kit Kilmat sound deadening on rear wall, floor and doors Toro MR2 amplifier Toro MRx4 amplifier JL audio stealthbox (10TW3-D4 10 inch sub) Kicker CS replacements for all stock speakers Front camera with Germes Lab RFCC LoMax trifold tonneau
    Bump for those who have used this thread. Any insight is appreciated.
    I just installed an AX6000 in my ‘20 OR and lost the use of my RFCC (rear front camera controller) from Germes Labs (car solutions) that used steering wheel controls for anytime camera use and didn’t require an extra switch on my dash.
    I’ve made my peace with changing my camera controller to the Anytime Camera switch if I have to but this is unclear to me - probably because I don’t have an anytime camera switch - but if I order a switch, I would install as per the directions and then do this extra bit, right? I’ve sent two emails to trail grid pro customer service and have been completely ignored.
  4. Sep 27, 2024 at 8:06 PM
    JerryHeller
    JerryHeller New Member
    There needs to be an install video for this particular situation.
