How to use MITY VAC, to remove air on slave cyl. as per (Crusty Taco)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Freedomrider, Aug 13, 2023.
  1. Aug 13, 2023 at 3:35 PM
    Freedomrider
    Freedomrider [OP] Member
    2003 TOYOTA TACOMA, STANDARD SHIFT,EXTENDED CAB (GOLD)
    I just purchased the (Mity Vac) and was hoping for advise on how to use it, to make it a little easier to remove the air in the system. as per. (Crusty Taco)
  2. Aug 13, 2023 at 5:21 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  3. Aug 13, 2023 at 8:40 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    It's been three years since I bled the clutch, but I don't remember it being too complicated. I think you crack the bleeder valve a bit, attach the hose and make sure the little container with the bleeder valve has some fluid in it, pump until the fluid flowing towards the container no longer has any bubbles in it.
