How to use oem fog light harness to Caliraised switch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by d3javoo87, Jul 18, 2020.
  1. Jul 18, 2020 at 9:36 PM
    d3javoo87
    d3javoo87 [OP] Member
    Pennsylvania
    2015 Tacoma TRD
    Installing led fogs with caliraised switch using oem harness and can't seem to figure it out. Installed light bar and aux pods with included harness with caliraised switches - works fine. Searching and searching and can't seem to find an answer. I find info that the fogs are ran off of a relay that send 0v, but is there a wiring fix to make it work? Or do I just have to suck it up and install another harness?
  2. Jul 18, 2020 at 9:43 PM
    Muddinfun
    Muddinfun Well-Known Member
    The OEM switch provides a ground for the relay. Aftermarket switches supply +12v to the relay. They’re different internally and can’t be interchanged.
    gotoman1969 and TnShooter like this.
  3. Jul 18, 2020 at 9:45 PM
    d3javoo87
    Pennsylvania
    2015 Tacoma TRD
    So basically you're saying.. only option is to use oem switch, oem harness or run new harness altogether? Thanks for the quick reply.
  4. Jul 18, 2020 at 9:50 PM
    Muddinfun
    Yep, OEM switch with OEM harness. Aftermarket switch with aftermarket harness.
  5. Jul 18, 2020 at 10:06 PM
    d3javoo87
    Pennsylvania
    2015 Tacoma TRD
    Got it! Thanks!
    Muddinfun likes this.
