How to use the 110v bed outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, May 12, 2011.
  1. Jun 24, 2011 at 6:07 AM
    #41
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    I wish this were the case. Only the good / safe appliances will have the UL mark. Too many cheap companies / unsafe appliances (and other devices) out there.
  2. Jun 24, 2011 at 6:40 AM
    #42
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Best use I've found for it is running my trickle charger on the deep cycle for long hauls with my boat if I'm going to be fishing back to back with the trolling motor.
    Governor likes this.
  3. Jun 24, 2011 at 9:39 AM
    #43
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Just to let you know, Power does not equal volts times amps when dealing with AC, only DC.
    Something with a motor for example, will draw a lot more current while running than its wattage would have you believe. The more inductive or capacitive the load, the more current it will draw compared to the work it can get done. So you may find that a 400W rated appliance still won't run.
    To counter act this it does seem the inverter will handle a bit more than 400W since people ARE running some pretty high power factor devices on it, plus over 400W devices.
    Either way the unit for this kind of thing in AC is VA (Volt Amps).
  4. Jun 24, 2011 at 10:26 AM
    #44
    puckstopper55
    Long Island
    Any legit device gives you its ratings based on Normal Load. A blender will give you a 450 W rating, which is based on its power draw while blending. Of course if you put cement in the blender, it will load down the motor more, but that is not a "normal load". Look for the UL mark, and use the appliance as intended. It will not draw more then 110% of its rating.
  5. Jun 24, 2011 at 10:38 AM
    #45
    anethema
    J
    Dawson Creek,BC
    You're not pickin up what I'm saying.
    A 450W blender will draw 450 real watts under load. But because a blender is an inductive load, it will draw more current than 450W/120V (3 amps). In reality a blender will draw something like 3.5 amps since the current is so far out of phase with the voltage. It will then return that current to the wall, BUT you still need cables and power supplies spec'd for the 3.5 amps, not the 3.0 amps it advertises.
    Here is some reading on the subject:
    http://en.wikipedia.org/wiki/Power_factor
    What it really means to you is while inverters claim they are spec'd to a certain power, they are actually spec'd to a certain current limit. While a very inductive load might claim it is 400W, you may need a 450W inverter to run it, that's all.
  6. Jun 24, 2011 at 11:01 AM
    #46
    puckstopper55
    Long Island
    You are right .. and wrong. A majority usually end up with a 0.9X PF, so the difference is usually very minute. BTW, I have years of data to back that up
  7. Jun 24, 2011 at 12:36 PM
    #47
    anethema
    J
    Dawson Creek,BC
    I know it depends on the load. Some loads which are heavily inductive could get quite a bit higher than that.
    Even on 0.9 power factor, you need a 450 watt inverter (444W actually) to run a 400W device.
    Some are lower than 0.9 as well.
    Wasn't meant to be a big debate though all I'm saying is if you are already near the limit and your device wont run anyways, this could be the cause.
    I imagine inrush current on a motor type load near the limit would also be a big problem that trips the breaker.
    I personally kind of want to see if I can fit a full circuit inverter somehow in the area to replace the stocker.
    Run some fat battery cables to it. Add a couple plugins in the cab, and change the wiring for the plugin in the box (too thin for full circuit).
    Be a fun project anyways.
  8. Jun 24, 2011 at 1:08 PM
    #48
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    ^ This. And pretty dumb marketing, if you ask me.
    What I don't understand is why they put the outlet in the bed and not inside the cab. Seems like 95% of people would use it to plug in a laptop or to charge batteries for electronic items inside the cab. Nobody wants to power a laptop or charge batteries in the bed of their truck.
    If you are gonna put an outlet in the bed, it should at least be run off an inverter that is able to handily power most power tools, which would be used on your tailgate. IMO, if you can't even run a circular saw off the plug, why bother having it in the bed?
    I think you meant 3.3A, not 33A :)
  9. Jun 24, 2011 at 2:06 PM
    #49
    anethema
    J
    Dawson Creek,BC
    No it's 33A.
    400W/12vDC=33A
  10. Jun 24, 2011 at 2:15 PM
    #50
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    I needed to charge my phone once and didn't have a car charger..
    I put extention cord from bed through rear center window and into cab where I could plug my phone in...
    Personally, I love the out let.. I've found lots of uses
    It powers my compressor and shop vac fine and work lights fine
  11. Jun 24, 2011 at 2:46 PM
    #51
    BenWA
    Boston burbs
    Oh I completely misread what you wrote -- I thought you were saying the inverter was able to produce 33A (at 115V AC). Reading comprehension problems, my bad. :eek:
  12. Jul 8, 2011 at 10:50 AM
    #52
    Ez2typethis
    Ez2typethis Well-Known Member
    California
    2017 Sport
    Suspension -LSK Uniball Uper Control Arms -LSK Uniball Lower Control Arms -Camburg Performance Spindles -ECGS Needle Bearing Installed -Archive Garage Hammer Hangers -Archive Garage 3.6” Shackles -Archive Garage Hanger Cross Tube -Icon 2.5 CDC Extended Travel Coilovers -Icon 14" 700 pound coils -Icon 2.5 CDC RXT Shocks -Icon 2.0 Hydraulic Bump Stops *Bolt On Bump Stop Mount -Wheelers Front Super Bumps Armor -At The Helm Front Bumper -At The Helm Rear Bumper -At The Helm Rear Swing Out -RCI Sliders -RCI Engine Skid Plate -RCI Transfer Case Skid Plate -RCI Transmission Skid Plate -RCI Fuel Tank Skid Plate -Prinsu Designs Top Rack -Prinsu Designs Cab Rack Lights -Black Head Light Mod -OEM TRD Pro Tail Lights -MESO LED Turn Signals -Morimoto HID Headlight Kit -Caliraised LED 40” Slimline -Caliraised LED 20” Slimline -Caliraised LED Amber Pods -Caliraised LED Wide Ditch Lights -Caliraised LED Flush Mount Pods -LED High Beams -LED Dome Lights -LED Back-Up Lights -LED License Plate Lights Miscellaneous -OVtuned2.0 -4.88 gears -ARB twin comp -ARB rear locker -Leer 100XQ Camper Shell -Smitty Built X20 Winch -Warn Fairlead -Warn Sidewinder -Roto Pax 4.5 Gallon Gasoline -Roto Pax 2 Gallon Water -Roto Pax 2 Gallon Gasoline -Weathertech Floor Liners -Double limo tinted -50% tinted windshield -Leather Seats - Installed At Dealer Wheels and Tires -Matte Black Stealth Custom Series Ray 10's (X5) -BFG KO2 285x70r17 // Load Range C (X5)
    400w/110vac = 3.6 amps...
    400w/12vdc = 33.3 amps...
    workes the same for AC as it does DC... maybe i'm confused on what your saying...
  13. Jul 8, 2011 at 10:55 AM
    #53
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    i ran a box fan all weekend while camping in the ozarks, also used an air pump for matresses at the same time as the fan was running. it meets expectations, didnt expect it to replace electricity to my home
  14. Jul 8, 2011 at 11:12 AM
    #54
    Ez2typethis
    California
    2017 Sport
    Sweet, thats what i wanted to run with mine... Glad it works!
    NmapFE likes this.
  15. Jul 8, 2011 at 1:14 PM
    #55
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I've never used the outlet in the bed, but I always use the ones that I put in the cab that run off the stock inverter. When I was in the academy and I needed a break from everyone, I would plug my old school SNES into the power outlet and then plug the RCA outs into my AVIC-D3 and then play Super Mario or StarFox for hours. I would get odd looks, especially since I cranked the sound and was parked in the underground parking.
    Corneeeeelius and dziner like this.
  16. Jan 9, 2012 at 12:54 PM
    #56
    AllBLKTaco
    AllBLKTaco Well-Known Member
    Denver
    07 TRD double cab
    I've ever only used it for what it was originally designed, a blender to mix cold margaritas with while camping. It worked flawlessly. Thank you Toyota!
    RtacomaN and dziner like this.
  17. Jan 9, 2012 at 4:53 PM
    #57
    anethema
    J
    Dawson Creek,BC
    It doesn't work the same unfortunately.
    A drill that is rated for 400W say at 120V for example. Using simple ohms law you would guess the drill draws 3.33 amps. But since it is a motor the power factor might be 0.9 or something (Pulling numbers out of my ass). This would mean the actual current is 3.7 amps. This would mean your inverter would need to be rated for 444 "Watts" to run the drill. That power would be returned to the inverted but the extra current DOES flow and must be accounted for.
    So if you find something that is 400W but is motor based so probably has a crappy power factor, you may not be as safe as you thought, that is all.
    Since it appears the actual thing trips somewhat higher than 400W, it obviously would not be an issue in this case, but is something to take into account.
  18. Jan 9, 2012 at 9:40 PM
    #58
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    I'm glad Toyota added the bed-mounted 110v power outlet. I use mine to recharge the 18v batteries for my Dewalt cordless power tools (drills, saws, grinders, worklights, etc).
    With two chargers plugged in (using a plug adapter), I can run my tools all day without interruption (alternating between three batteries, one in whichever tool I'm using and two charging).
    So far, the truck has not failed to start afterwards. However, since the truck is brand new (two weeks), cannot really say how the truck's battery might react to all this over the long run.
  19. Aug 28, 2012 at 8:19 PM
    #59
    CVTejas
    CVTejas CVTejas
    Charles
    Fort Worth, TX
    2010 Taco 4x4 TRD Sport
    Farad Cold Air Intake, BFG All Terrains, ARE Z-Series Deluxe Fiberglass Top w/ Keyless Entry and LED interior lighting,Road Armor front bumper w PIAA 510 driving lights, Edlebrock adjustable shocks w factory coils, road Armor front bumper. Kenwood DDX8901HD
    Did anyone ever swap out the taco inverter for something like the 1000 watt harbor freight model?
  20. Aug 28, 2012 at 8:34 PM
    #60
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    A motor produces it's own resistance...known as EMF or CEMF (Google it). I'm going to use your example...
    A 400W drill running with 120v should draw 3.33 like you stated but due to EMF or CEMF (The .9 you are talking about), this 3.33 is SMALLER...not bigger. if you multiply by anything less than 1 (power factor of .9 as you stated), your answer will be smaller than what you started with. Not trying to be a dick but you were starting to confuse me....and I know a thing or two about electricity.
    So a MOTOR, which produces it's own resistance, the amp draw can't be determined with using Ohm's law. Unless of course you have the Power Factor. Normally you can just look at the rating plate though and it'll tell you what the RLA or Run Load Amps of the device is. Hope this helps if some were backwards.
    Edit... The 3.33 x .9 (PF)= 2.99 amps
