How to use the 110v bed outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, May 12, 2011.
  1. Aug 29, 2012 at 8:21 AM
    #61
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    I'm sorry it just isn't the case. A motor's VA (volt amps) will be higher due to power factor, not lower.
    Not like I need wikipedia to tell me this, but maybe the source will convince you:
    A low power factor always results in a higher current. It is also the reason transformers are rated in VA rather than watts. If you power an inductive load (like a motor) your apparent current will be higher so your transformer will need to be appropriately rated. So in your example a 400W drill should draw 3.33 amps, but due to the power factor, will draw 3.7 amps. Since the 400W rating on the inverter is really a current rating not taking power factor into account, your inverter will be under sized. (Yes I know watts is a power rating, but it is a bit misleading since the current supplied is what they have to use to spec components, trip protection circuits etc.)
    Back EMF is a different phenomena that causes (fortunately) the moving current need of a motor to be less than the inrush current. This UNfortunately also often increases the size of your power supple needs due to this inrush current. So a drill that may only be 400W and can run happily on your 400W inverter, will have an inrush current causing the temporary draw to be much higher, and trip the protection circuit. The reason the draw is less when running is due to back EMF.
    Again from wiki:
    From: http://en.wikipedia.org/wiki/Counter-electromotive_force
    To summarize: A low power factor is a bad thing, causing an INCREASE in the current ratings needed in your wires, supply, etc. I understand you think you know a thing or two about electricity, but having took electrical engineering in school also taught me a thing or two ;)
  2. Aug 29, 2012 at 3:00 PM
    #62
    Redtaco12
    Redtaco12 Member
    '12 taco 4x4 dc longbed
    I used mine to power my soldering iron while I was doing a pop and lock install in the tailgate. I didn't want the connectors and extra cable in the tailgate so I just plugged into the bed and soldered right on the spot!
  3. Sep 3, 2012 at 6:23 PM
    #63
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I'm reading this trying to figure out if I'll be able to run a 115 volt puma air compressor that pulls a claimed 6.3 amps, no start up info. Thinking that I might be better off with a 12 volt unit, found a good deal on the puma 115 v though. Tires, air bags, future lockers, will the inverter supply enough power to run the 115 v compressor at full speed?
  4. Sep 4, 2012 at 6:35 AM
    #64
    anethema
    J
    Dawson Creek,BC
    Very doubtful.
    That is 724.5 watts, and no matter how you slice it, way over the rating of the inverter. You would need a bigger inverter for sure.
    tacoguy88 likes this.
  5. Sep 4, 2012 at 7:07 AM
    #65
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    Volts x amps = watts. As mentioned above me that's 115 x 6.3 = 724.5
    Way about the 400 watts rating of our inverters.
  6. Sep 5, 2012 at 2:45 PM
    #66
    Gearheadesw
    Davenport Fl
    Thank you for the replies, I have made my mind up on 12 volt for sure, way easier to wire in, thanks again.
  7. Jul 10, 2014 at 3:16 PM
    #67
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    All I need to know is this...
    Can I run my Keurig coffee maker in the morning while camping off of this thing? And do it safely?
    edit* Welp.. Keurig says 1000w on bottom. So I take it that is a NO
  8. Jul 10, 2014 at 4:38 PM
    #68
    refokus
    refokus Member
    Brad
    Glendale, AZ
    2014 Tacoma DCSB
    Well, what about my Mr Coffee?
  9. Jul 10, 2014 at 6:22 PM
    #69
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    That is what mine is. A cheap $69 Mr Coffee Keurig and it says 1000w on the bottom. I'm only guessing, but I don't think that our trucks can handle that. 400w max. idk.
  10. Jul 10, 2014 at 6:38 PM
    #70
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Just get a cheap 1200 watt inverter you can clip onto the battery terminals with the hood raised. Bear in mind that 1000w on 120v AC is only 8 amps. If you pull 1000 watts on a 12v DC circuit, you're talking 80 amps. If the coffee doesn't "jolt" you, that might. :eek:
    It might be cheaper and easier just to heat some water with a propane torch and manually pour it over the coffee grounds. Low tech solution if you really want coffee in the woods. :D
  11. Jul 11, 2014 at 5:10 AM
    #71
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    If you're camping and have a stove, just heat water. Check www.campmor.com - they have several coffee presses.
  12. Jul 11, 2014 at 3:25 PM
    #72
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    I have a Jetboil (awesome for anyone that camps) and I use a bodem french press usually.. I just wanted to try my Keurig.
    No worries. I'm not going to try an inverter and possibly break something, or myself. haha
  13. Oct 25, 2014 at 10:25 PM
    #73
    gribellia
    gribellia New Member
    Chico CA
    08 Prerunner SR5 TRD Sport Debaged
    Bilstein leveling kit
    I tried to plug in a air compressor, it didn't work. After I pressed the button my fog lights quite working anyone have an idea why that might be?
  14. Oct 25, 2014 at 10:41 PM
    #74
    Mr Ribby
    Mr Ribby Well-Known Member
    Andrew
    NW Indiana
    2013 "Baja"
    Pioneer DvD double din, pioneer 5way front door speakers, kicker 3 way rear door speaker
    Pulled to much power at once, same principle as headlights dimming when a subwoofer hits hard. An example of something suitable to use it for is a small battery tender or charger anything more than that your taking a risk of tripping it. Best of luck
  15. Nov 4, 2014 at 5:38 PM
    #75
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    I ran a computer and an xbox 360
    ____________________________________
    Didn't realize how old a thread this was
  16. Nov 6, 2014 at 12:50 PM
    #76
    prerunner 06
    prerunner 06 Well-Known Member
    David
    Springfield OH
    06 Prerunner SR5 DCSB
    Ran a small black n white TV off it to watch a US Open tennis match on a long trip once. Kids weren't too impressed.:D
    Corneeeeelius likes this.
  17. Mar 26, 2015 at 11:22 PM
    #77
    Mankster
    Mankster New Member
    06 Taco 4dr Lngbd
    Trd CAI & Magnaflo exhaust
    Crom,
    You seem to know quite a bit, I have a question maybe you can help answer. I purchased a trailer. I'm running 2 batteries with a 2000watt pure sine inverter to power the trailer off-grid. I will eventually get solar panels but want the ability to charge the batteries while towing with the tacoma...will the 110v outlet in the bed of the tacoma power a 60amp battery charger so I can charge while towing? Thanks!
  18. Mar 27, 2015 at 7:20 AM
    #78
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Without explaining why, it probably won't work, however, there in so harm in trying. So, I say run the batteries down, and try it. Let it charge for up to 20 mins or however long it can go.
    If that doesn't work, for not a lot of money you could use a split charge relay (battery isolator), like this one: Stinger SGP38 80-AMP Battery Isolator and Relay.
  19. Apr 11, 2015 at 3:38 PM
    #79
    OregonMGM
    OregonMGM New Member
    Jake
    Salem, OR
    '14 Double Cab V6 TRD Sport
    K&N Cold Air Intake, 3" Lift, Toyo Open Country AT II 285/70/R17, Fuel D538 Mavericks, Grillcraft Upper and Lower Grill, Hypertech In-Line Speedo Calibrator
    Not sure why anybody would ever call this a "waste" of a component. I can run my Traeger BBQ and a string of Christmas lights while camping no questions asked! Easily one of the best features
    Hoofer likes this.
  20. Nov 1, 2015 at 3:24 PM
    #80
    hmsailor
    hmsailor Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    large LED flat screen for tail gate party
