How to use the 110v bed outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, May 12, 2011.
  1. Apr 23, 2016 at 2:26 PM
    #81
    SketchyTaco
    SketchyTaco Member
    2007 Tacoma V6 DC Prerunner TRD Sport
    I have had my taco for about 2yrs now. I just recently started actually putting this outlet to good use. I do construction now and use it to charge my power tool batteries while driving to another location. I have used this to run electric saws on my tailgate. Recently it became very handy while in the middle of a field with now other source of power. My dump trailer battery ran out fully loaded and half in the air. Electric battery charger ran off truck bed and came through just as I needed it too. The above comment about multiplying voltage and amps to get wattage is accurate. You may be under 400w to charge/run an item but when you power it on it will trip if that wattage is not below 300w. Converting to 1000w all time is a great idea if anyone has any advice on how to go about that and what the consequences could be on truck and/or truck battery in that case.
  2. Apr 25, 2016 at 10:29 AM
    #82
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    I ran across a neighbor who was running a Harbor Freight 1/3 HP compressor with his truck. Name plate amps are 2.6 and max pressure is 100 psi. He has "twinned" a second 5 gallon tank to it so that his supply is a bit more than just the "hot dog" tank that came with it. Seems to work fine at the 100 psi regulator setting but probably needs a bit more tank to use as an "air-up" supply.
  3. Apr 25, 2016 at 12:33 PM
    #83
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    You can't really use it for anything that makes heat at all. I use it to run a standard box fan in the summer when I go camping or if it's a buggy night. Also works with a drop light.
    Governor likes this.
  4. Oct 26, 2016 at 9:05 AM
    #84
    baileybrandon
    baileybrandon 2016 DCSB OR - MGM -
    Bailey
    Tennessee
    2016 Tacoma TRD Off Road Double Cab
    Anyone ever tried an air mattress? Going camping this weekend and this would be really useful!
  5. Oct 26, 2016 at 4:01 PM
    #85
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I have and it works. I think it's the cheapy Coleman pump that I have.
    baileybrandon[QUOTED] likes this.
  6. Jan 20, 2017 at 8:57 PM
    #86
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    I don't think its useless. I think there are plenty of people who use battery powered tools as part of their profession and the outlet is great for running a battery charger while driving to job sites. Me, I use it to keep my deep cycles charged while driving between shows. Its great.
  7. Jan 20, 2017 at 8:59 PM
    #87
    Muldoon
    Robert
    Northeast Ohio
    I realize this is way too late but for anyone else wondering, I suppose it depends on how much power the pump draws but I've also done it successfully
  8. Feb 1, 2017 at 12:23 PM
    #88
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Wanting to power my drone's battery using the bed outlet. I've powered a few things with it but anyone know offhand if it should charge fine without messing up the battery. Battery says Max 100w. Here's the other specs
    Capacity 5350 mAh
    Voltage 15.2 V
    Battery Type LiPo 4S
    Energy 81.3 Wh
    Net Weight 462 g
    Operating Temperature Range 14° to 104°F (-10° to 40°C)
    Max Charging Power 100 W
  9. Feb 1, 2017 at 3:27 PM
    #89
    gregzz
    gregzz Well-Known Member
    greg
    las vegas nv
    2011 tacoma crew cab 4x4 v6 4.0
    Wheels/ tires, tint, level kit. Rock crawler rails. 3- 6" procomp lights with light bar on front bumper. Magnaflow # 12256 stainless muffler. Billet shorty antenna.
    I've used my electric skillet and blender on mine many times on camping trips. Works great.
    spitdog likes this.
  10. Sep 20, 2017 at 7:02 AM
    #90
    YankeeBastard91
    YankeeBastard91 New Member
    05 4.0 6spd 4x4 access cab
    Leer cap
    Would it make more sense to invest in a decent set of 18v battery powered tools (I'm a milwaukee guy myself, but thats a discussion for another forum) and just run a bank of chargers off the outlet? they only draw 90w/ea. Its obviously not intended for prolonged heavy duty use anyway. The 18v batteries would basically allow you to do some fancy accounting with your power, since you're charging your battery bank while you're measuring/marking, etc. Thats how I intend to set up my mobile toolkit, at least.
  11. Sep 20, 2017 at 4:46 PM
    #91
    gregzz
    greg
    las vegas nv
    Works to make good margaritas at the river. That's all I know. Ha ha ha.
    Tacos4ever15 and highriserkaiser like this.
  12. Sep 20, 2017 at 5:29 PM
    #92
    IndyZen
    IndyZen Well-Known Member
    Marc
    Central Indiana
    2017 Inferno TRD Off Road DCSB 4X4 Manual Tranny
    I have had my 2017 Taco since July and have used the outlet several times... primarily to run my Fender Mustang amplifier to my acoustic and electric guitars to entertain the imagined masses with my power chording. :rockband:
  13. Sep 21, 2017 at 4:29 PM
    #93
    gregzz
    greg
    las vegas nv
    Party on!!! Lol
    IndyZen[QUOTED] likes this.
  14. Sep 21, 2017 at 4:29 PM
    #94
    gregzz
    greg
    las vegas nv
    :cheers:
    IndyZen likes this.
  15. Dec 8, 2017 at 7:47 PM
    #95
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    added two 120V outlets? howd you tap that into the battery? write up?
  16. May 3, 2018 at 10:16 AM
    #96
    doyledoonz
    doyledoonz Active Member
    Kyle
    Ogden, Utah
    2017 Tacoma TRDOR DCSB
    How long does it run your Traeger for? Any issues to be aware of?
  17. Jun 12, 2018 at 3:18 PM
    #97
    Corneeeeelius
    Corneeeeelius AMERICA!
    Cory
    MIssion Viejo, CA
    2017 TRD Sport 4x4 DCLB W/Tech
    What a fun truck!
    My hero! :yes:
    Maticuno[QUOTED] likes this.
  18. Jun 14, 2018 at 5:45 AM
    #98
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    A long time ago, someone in this thread mentioned not being able to use the rear outlet for anything heating-related.
    On the contrary - grab yourself one or two cheap heating pads from Walgreens/CVS/whatever. I usually sleep in the bed of the truck, and getting into an ice-cold sleeping bag sucks. So warm it up with heating pads before you sack out.
    What I don't like is having to need the key in the "on" position to get power back there. Is there a hack for this that someone already figured out?
  19. Jun 14, 2018 at 9:11 AM
    #99
    Muddinfun
    Muddinfun Well-Known Member
    When both indicators are lit, you have 400 watts available. When you put it in drive or reverse, the 400 indicator goes out and you only have 100 watts available. Apparently they don't want you to be able to operate power tools while driving.
    tacoguy88 likes this.
  20. Jun 14, 2018 at 11:56 AM
    #100
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
    one horsepower is 746 watts. 1/3 horsepower is 249 watts, well below the limit of the inverter, as verified by the nameplate amps
