How to use the 110v bed outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, May 12, 2011.
  1. Jun 14, 2018 at 7:57 PM
    #101
    Lineback
    Lineback Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    It will power the Hitachi Magic Wand plug in vibrator, for about 30 minutes non-stop. Don't ask... just don't. ;)
    TegoTaco, Losi-5iveT, JBin402 and 2 others like this.
  2. Jun 15, 2018 at 7:34 AM
    #102
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I have run the black Harbor Freight 4" angle grinder to sharpen mower blades away from power. No problems, had the engine running. I keep a light 8 or 12 foot extension cord under the seat for more utility.
  3. Jul 2, 2018 at 11:12 AM
    #103
    Lineback
    Just got back from a two day outdoor music festival. Discovered new use for the 110v outlet, perhaps THE most important of all. Grilled cheese machine! We made hundreds of grilled cheese sandwiches, gave away some, sold a few, nothing beats fresh grilled cheese sammiches!
  4. Jul 2, 2018 at 5:31 PM
    #104
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    I can run a Harbor Freight pancake style air compressor like this one with no problem.
    TheDevilYouLove likes this.
  5. Jul 3, 2018 at 1:25 AM
    #105
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I suppose you can pull out the relay in the tray under the hood and jump the pins. Now you got power at the bed all the time
  6. Aug 12, 2018 at 8:25 AM
    #106
    PonyOnMyBoat
    PonyOnMyBoat Member
    2018 DCSB TRD OR
    I just got a ~40qt Endel fridge and 40Ah LFP battery for camping. Plan is to keep the AC battery charger plugged in to the bed outlet, while running the fridge off the battery. I've test run this in the house and it's good for a couple days after unplugging the charger from the wall. Testing in the truck, I see that I need to hit the AC reset button every time I start the truck if I want power at the bed outlet. I can see forgetting this sooner or later, and arriving in camp with the battery depleted.
    I've seen discussion of how to supply 400A full time, and even about the possibility/wisdom of supplying AC when the engine is off. What I would like to do is to always get AC when the engine is running (without having to hit the reset button) but not when the engine is off.
    Any thoughts?
  7. Aug 12, 2018 at 8:39 AM
    #107
    Muddinfun
    Muddinfun Well-Known Member
    So, let me see if I get this. You want to set it up so that the 110 outlet is powered every time you start the truck, to power a battery charger which will charge an auxiliary battery in the bed that powers the fridge? Why not just have a relay turn on with the key and let the truck alternator charge the auxiliary battery? If you have the factory tow package, there's a terminal in the 7 pin connector just for this purpose.
  8. Aug 12, 2018 at 9:04 AM
    #108
    PonyOnMyBoat
    PonyOnMyBoat Member
    2018 DCSB TRD OR
    Because LFP batteries recharge at 14.6V. You can recharge from AC or from solar with the correct charger, but not from 12V.
  9. Aug 12, 2018 at 9:36 AM
    #109
    Muddinfun
    Oh, OK. Well, the switch for the invertor is a momentary contact switch. I tried holding the switch in while starting and it comes on at 100watts. So, if you put in a continuous switch, you're only going to get 100 watts. Looks like you're SOL unless you use a time delay one shot relay. Here's the schematic, if you want to look at it.
    http://www.customtacos.com/tech.old...toyewd/06toypdf/ewd/2006/tacoma/h/em01d38.pdf
  10. Aug 12, 2018 at 9:46 AM
    #110
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    You mean that there is a manual that explains this and other stuff pertaining to my truck? Wow who knew
    Jimmyh and TomTwo like this.
  11. Aug 12, 2018 at 9:49 AM
    #111
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Thats a lie, theres nothing that tells us about the trucks. Its all trial and error.
  12. Aug 14, 2018 at 2:16 AM
    #112
    SilenceWillFall
    SilenceWillFall Member
    2015 toyota tacoma trd off road
    I took an extension cord from the bed under the truck thru the opening in the frame up to the passenger side ran it inside and cut the end off wired a power strip into the cord tucked it in under the floor mat passenger side. Works great for laptop, tablet..
  13. Aug 14, 2018 at 4:22 AM
    #113
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I hope you are being sarcastic but you could safely and more quickly do this by buying a power inverter that simply plug into the cig lighter.
    TomTwo likes this.
  14. Aug 14, 2018 at 4:38 AM
    #114
    matt(inma)
    matt(inma) Member
    Always wondered of this would be good for making frozen Margaritas !!
  15. Aug 14, 2018 at 4:40 AM
    #115
    PonyOnMyBoat
    PonyOnMyBoat Member
    2018 DCSB TRD OR
    Or tie in to the factory inverter since it's in the console.
  16. Aug 14, 2018 at 5:22 PM
    #116
    Barzini
    Barzini Well-Known Member
    Don
    2019 Tacoma Access Cab
    Is the 110V bed outlet standard only on certain models? I have a 13 SR5 with the 2.7L. It does not have an outlet.
  17. Aug 14, 2018 at 5:29 PM
    #117
    TireFire
    Olympic Peninsula
    TRD gimmick only.
    tacoguy88 and Barzini[QUOTED] like this.
  18. Aug 14, 2018 at 5:30 PM
    #118
    TireFire
    Olympic Peninsula
    Under the center console armrest
  19. Aug 15, 2018 at 3:11 PM
    #119
    PonyOnMyBoat
    PonyOnMyBoat Member
    2018 DCSB TRD OR
    Thanks. Guess my best bet is to run switched 12v to the bed and hook it to my own 100 - 150W inverter to run the charger whenever the engine is on. I wonder whether the power lead to the trailer connector can support that.
  20. Aug 15, 2018 at 3:19 PM
    #120
    TireFire
    Olympic Peninsula
    No, it can't. Has too much voltage drop.
