How to use the 110v bed outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, May 12, 2011.
  1. Aug 16, 2018 at 9:06 AM
    #121
    Barzini
    Barzini Well-Known Member
    Don
    2019 Tacoma Access Cab
    Had anyone installed the bed outlet on a Tacoma that did not come with it from the factory? I see used bed outlets for sale on eBay for $100 to $300. I was curious how much work it was to hook up the harness, switch and anything else.
  2. Aug 30, 2018 at 12:24 PM
    #122
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yeah I've done it on my cousins truck with junkyard parts. PM me and I can sort it out for you
  3. Dec 6, 2018 at 7:42 PM
    #123
    DaTacoSpin
    DaTacoSpin Member
    ‘16 TRD Sport 4x4 Black
    None Yet ... soon though!
    Maybe I am missing something as I tried to do the math and prevent any fuses blowing or other damage but ...
    I just ran an decent size audio amplifier and mini sound board with large woofer on the 400W (truck running) option for over an hour.
    According to the backnof the Amp it said 1500 W with a 15 Amp fuse. Maybe that is what max power would be and my one speaker didn’t draw that much power. I can’t fogure it it but it worked. I was nervous but it worked.
    TireFire likes this.
  4. Dec 6, 2018 at 8:11 PM
    #124
    TireFire
    Olympic Peninsula
    Maybe that's peak and it never drew that much. You could probably switch the fuse out for a 7.5amp and you're in the range that'll never have issues
  5. Aug 3, 2019 at 11:21 AM
    #125
    Losi-5iveT
    Losi-5iveT Active Member
    Sean
    Glendale az
    2016 taco double cab 2wd
    3x2 level kit and running boards
    Does the tailgate outlet have a cut off rate or will you completely drain your battery?
  6. Apr 25, 2021 at 3:51 AM
    #126
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    An 8 amp electric chainsaw works
  7. Apr 29, 2023 at 3:46 PM
    #127
    TacoTuesday1
    SD CA
    Trying to dual charge an EcoFlow while driving
    Solar on roof
    EcoFlow is in cab so I ran extension cord from bed outlet through sliding window
    problem: 0 watts charge input detected
    never used the bed outlet before. Bought truck used had a previous owner.
    Can’t help but wonder if it’s a simple fix like a little fuse popped somewhere or something.
    temped to buy a wall outlet tester tool, or multimeter to test and confirm it’s actually not powered
    have tried button off, button on 100w, idle button on 400w
    anyone been through this?
    IF I confirm power, then that could mean the EcoFlow smart charging full in 1hr tech wants to pull too much flow
    I’d hope the inverter can handle it
    I may have to see if there’s a way to limit and control the amount
    Or if it’s just not possible
    Which would be sad because EcoFlow told me you can charge with solar and wall plug at the same time…
    Unless it’s needed or possible to throw out the stock inverter (probably crappy) and bolt in a better one
    intended use is charge from vehicle while driving engine on, and solar at the same time, to get more watts in
  8. Apr 29, 2023 at 4:13 PM
    #128
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I’d suggest buying a voltmeter and check the outlet. BUT… I have a small EcoFlow and I know it draws some amps.. the cord even gets pretty hot while charging. Could be that yours is pulling too many amps for the inverter. You could also just plug something small in to test the outlet, like a small lamp/radio/etc
  9. Apr 29, 2023 at 4:29 PM
    #129
    TacoTuesday1
    SD CA
    it’s a River 2 Pro
    yep you’re right. Extension cord works. Phone charger works.
    EcoFlow cable worked in a wall.
    so I’m assuming no popped fuse or relay.
    EvoFlow just doesn’t charge from it
    Which makes me wonder if 400W AnyTime Mod would even work, or be for nothing (when they come back in stock)
    I’m gonna try to open this unit in their app and see if that has any options to control charging and make it work
  10. Apr 29, 2023 at 5:52 PM
    #130
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    The 110 volts on the bed won't charge the ecoflow because it is modified sinewave . Ecoflow is finicky and only charge on pure sine wave ac current as what I've seen on some YouTube videos.
    Watch this. He suggested a way around it . https://youtu.be/OHL9gbwNV-k
  11. May 6, 2023 at 5:41 PM
    #131
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    He has since released an updated video with a much better 'mod' to fast charging. :thumbsup:
    https://youtu.be/s_-9vj-hF1M
    Taco4C and bulalo[QUOTED] like this.
  12. May 6, 2023 at 5:53 PM
    #132
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The DC -> AC -> DC conversion for charging a battery makes me a little sad.
  13. May 6, 2023 at 8:12 PM
    #133
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Were you able to do this ? Pls post pics / how to . Tnx . I would gladly pay someone to do this but I can't find anyone here in socal
  14. May 6, 2023 at 8:22 PM
    #134
    Area51Runner
    Haven't done it yet but I already have cable runs in place from when I put in an aux fuse/power box in the bed. When I do finally get around to doing this will definitely add pics/notes.
    bulalo[QUOTED] likes this.
  15. May 6, 2023 at 8:35 PM
    #135
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Tnx. Looking forward.
  16. May 6, 2023 at 8:44 PM
    #136
    vtdog
    vtdog Well-Known Member
    NH
    The only thing I have ever done with the outlet is to power my 110v air compressor on trails when granite shards jumped up to attack the tires. It worked fire for that
  17. Oct 17, 2024 at 12:01 PM
    #137
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Ever found a electric blanket that would work?
  18. Dec 17, 2024 at 7:43 AM
    #138
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    No blanket?
