How to weld on a 2" Receiver onto a trailer tongue?
Discussion in 'Towing' started by Mods2Travel, Sep 1, 2022.
  1. Sep 1, 2022 at 11:59 AM
    Mods2Travel
    Mods2Travel [OP] Well-Known Member
    Daniel
    Fort Worth, TX
    2015 DCLB 4x4 SR5
    Level 8 MK6, 16x8, 6x5.5, +0 Offset Rims 285/75/16 (33") BFG KO2 tires 4.56 Gears from ECGS DIY bed/drawer slideout Bed Mounted Deep Cycle Battery/Fuse Box/Inverter/Isolator Yellow Wire Mod Rear Diff Breather Mod DIY Roof Rack Leer 180 Shell Bilstein 6112, Circlip #4 Bilstein B8 5160 Remote Reservoir Firestone Ride Rite 2407 Rear Suspension Airbags DayStar Cradles Camper Shell Radiator Fans for sleeping in warmer climates
    I'm looking at this Lock and Roll hitch, that has an extended trailer side connection.
    https://locknroll.com/shop-now/trailer-side/kayak/
    It is designed to go inside of a 2" receiver hitch.
    I'm getting ready to build an offroad trailer, and I like the idea of being able to keep that longer design tucked inside the trailer tongue most of the time, and being able to slide it out and re-bolt it if I need a longer tongue. (for adding bikes or firewood, etc onto the front of the trailer for non-extreme trips) I would like to just tack some 1/16" shims on the outside of this receiver (2.5"x2.5" outside dimensions), slip it into a 3x3x3/16 tubing and fill in the groove between the receiver collar and the end of the square tubing. However, the seam weld on the 3x3 square tubing will probably interfere, so I may have to just cut that out and plug weld between the 3x3 and the receiver.
    I just can't figure out what the "normal" way to add a receiver onto a trailer tongue is.
