how to wire bed lamps:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jefferson, Jan 3, 2009.
  1. Mar 7, 2009 at 7:32 PM
    #61
    jefferson
    jefferson [OP] needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    i almost did that, and i know it would work.. but i will be using mine mostly when coming back from surfing and the tail gate would be up. Also, i decided against it because i want total control over when it would be on and off. If i was loading anything into the truck with tailgate up, id want to be able to switch it on or off.
  2. Mar 7, 2009 at 7:47 PM
    #62
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yeah.....That may be the route I end up going.
  3. Mar 8, 2009 at 5:59 AM
    #63
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    That's why I love my wireless remote! :thumbsup: I can turn them on inside the cab to check on cargo or my dog, turn them on as I approach the truck, turn them off from inside the house after unloading, etc.
    So, seriously, a $20 wireless controller from Autozone would be great for a lot of people it seems.
    Sure, it's nice to have the light come on when you drop the tailgate, but then you need to drill a hole, run the wires, etc for a pin switch when you could just push a button on a remote as you step out. Then push another button after you've unloaded and click the lock button on the toyota remote. No extra wiring, no need to install switches at both ends of the truck, on/off whenever you need within 50ft of the truck or more.... Seems like a win-win situation to me. :D
  4. Mar 8, 2009 at 11:22 AM
    #64
    jefferson
    Sex Panther
    05 PreRunner SR5
    Do you keep it on your key ring or is it attached to the truck?
  5. Mar 8, 2009 at 12:19 PM
    #65
    piercedtiger
    Jon
    Southern Tier, NY
    One on each key so my wife can use them when she takes the spare key. Although with the controller box for my LED's there's also a physical switch in the center console if I need it, but I never use it.
    The lights I have under the truck it's nice to be able to turn them on before I get to the so I can see where the mud, water, or dog crap are before trying to step into the truck. :D
  6. Mar 8, 2009 at 12:33 PM
    #66
    mycoma
    mycoma Active Member
    Can u take a picture of the remotes on the keyring, the guy at my Autozone was clueless.
  7. Mar 8, 2009 at 1:06 PM
    #67
    piercedtiger
    Jon
    Southern Tier, NY
    I'm not using one from Autozone. I used one on my car for neons years ago so I know about them and how they work, but now I'm using what came with the lights I put on the truck.
    It was a box with 1 remote for about $20 in the switch/electrical section.
    Here's something similar. Looks like Auotzone discontinued the model I had.
    http://www.autobarn.net/plsw29.html
    A little bit more, but you can control 4 things with it so if you add more lights or whatever.
    Another one:
    http://www.oznium.com/remote-switch
  8. Mar 8, 2009 at 6:37 PM
    #68
    coach
    coach Member
    west virginia
    4 cyl
    wheels,tint,bugsheild,3" suspension lift
    I loved this idea so much i took it on step further making the lights able to pivot to the rear to shine light out the back.[/ATTACH][/ATTACH][/ATTACH]
    Cr47524 likes this.
  9. Mar 8, 2009 at 7:29 PM
    #69
    jefferson
    Sex Panther
    05 PreRunner SR5
    AH thats damn rad!
  10. Apr 29, 2009 at 5:19 AM
    #70
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    None!
    I finally got around to installing my bed lights.
    Switch I got from a local auto parts store and it fits pretty damn good.
  11. May 1, 2009 at 8:59 PM
    #71
    jefferson
    Sex Panther
    05 PreRunner SR5
    Looks good! and you used the same lights i did! One bummer about those lights - the mounting hardware gets kinda rusty around the screws..
    BUT enjoy. Its very useful
  12. May 6, 2009 at 1:14 AM
    #72
    norcal48
    norcal48 Member
    Indigo Ink Prerunner SR5 TRD Off Road
    i've been wanting to do a mod like this..i going to have to check into this...its seems easy im also novice to electrical...but im preety sure i can figure it out and get help...i like your sr5 cali stickers by the way..were can i get something like that?
  13. May 6, 2009 at 4:34 AM
    #73
    Burns
    17 DCSB Off-Road
    None!
    Yes the lights were cheap and that what made me get em, thanks for the heads up on the rust issue. :thumbsup:
  14. May 6, 2009 at 5:46 AM
    #74
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Good stuff here guys. Been schemin on what to do with that wasted space & may just have to go with some version of this.
  15. May 6, 2009 at 11:24 AM
    #75
    jefferson
    Sex Panther
    05 PreRunner SR5
    yah, someone used the lights out of a big rig and sunk them into the bed sides. I know thats not using the pockets, but it was a really cool idea. Others used more of a square style light that looked more stock, which i think looks cleaner than the elchepo's i found. BUT this is just a guide to move you through the process.
    I like mine and they work awesomely
  16. May 8, 2009 at 8:08 PM
    #76
    msaniac
    msaniac Well-Known Member
    Clemson, SC
    '09 DC 4x4 TRD Sport Longbed
    LED Bed Lights, Prodigy P3 Brake Controller, K&N Air Filter, Viper 5901 Alarm, Kenwood 9140 Headunit (Sirius/GPS/Backup Camera)
    what is the nut size for the ground bolt located behind the little cubbies?
  17. May 9, 2009 at 12:38 AM
    #77
    jefferson
    Sex Panther
    05 PreRunner SR5
    I went to ace hardware and, with the cubbies removed, tried a bunch till it worked. I found a 10mm bolt that threaded correctly.. but i couldn't tell you the width of the bolt.. sorry. But any hardware store should allow you to try a few till you find one that works. it took a total of 10 mins to locate one and buy up 3 (in case one dissapears!)
  18. May 13, 2009 at 8:11 PM
    #78
    Tracy
    Tracy The Silver blurr...
    TRACY
    SoCAL. IE, SGV, LA. :D
    '08 TRD Sport Edition PreRunner
    Chrome tube steps. Because a lady needs a help up when wearing a dress. :)
    Hey JEFF, that's pretty awesome! I wondered why we didn't have any bed lights and/or if we can install them also. I got into an accident in my truck (not my fault while i was driving straight and some kid came out of a parking lot and hit me, if you didn't hear at the meet) anywho, well my rental car was an 2009 Nissan Frontier and there was a button in the inside of the cab that I can press for the bed light to come on.
    I'll keep this in mind...
  19. May 13, 2009 at 8:19 PM
    #79
    jefferson
    Sex Panther
    05 PreRunner SR5
    Thanks! Its pretty simple really, lemme know if you want help with it.. it should have been a stock option just like the frontier! BUT we can make that happen.
  20. May 22, 2009 at 12:59 PM
    #80
    pistolpete
    pistolpete Active Member
    Califon,NJ
    2004 Tundra Double Cab
    Well folks I finally got around to performing my version of the modification AND writing up a detailed procedure...It was finished last month and made two fishing voyages to the Catskills and was a BIG hit!
    I've attached a detailed procedure along with some final pics of it in action. I like the way it turned out and that I have full control over the on/off, infinite angle adjustment of the LED light pods due to the mounting procedure I used and they are up and out of the way of any bed items. It also has "nightvision" for those times I am night fishing or running "covert" operations and wish NOT to loose my "night sight".
    So without further adieu here it is...
    "Pistol Pete's Bed light mod with Recon Bed light kit"
    hope you enjoy it and it sparks some interesting ideas of your own! I've seen some good ones in this thread
