how to wire bed lamps:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jefferson, Jan 3, 2009.
  1. Feb 8, 2010 at 11:23 AM
    #121
    Packguy2
    Packguy2 Well-Known Member
    Holly Springs, NC
    06 Prerunner DC LB Sport
    I plan to run to the battery, but how did you route that wire? Does it go along the frame and you zip it to the frame?
  2. Feb 8, 2010 at 11:34 AM
    #122
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    That's what I did. I put a switch in the cab and came up through the grommit under the driver floormat. Then went thrugh the grommit in the firewall. You could just run it up under the engine to the battery but be sure to zip tie and secure it to something. A wire loom the whole length is probably best.
  3. Feb 8, 2010 at 11:37 AM
    #123
    jefferson
    jefferson [OP] needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    I agree. However, I ran along and through the frame a few times and ziptied along the way. I didnt detail that because as you do it it becomes obvious. Just keep to the frame, on the inside, and high so you dont snag it offroading and you'll be okay. I did it once, never redid it, and have been okay for 2 years roughly.
  4. Feb 8, 2010 at 11:39 AM
    #124
    Packguy2
    Holly Springs, NC
    Awesome, thanks!
  5. Feb 8, 2010 at 6:25 PM
    #125
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    My dad and I found a hot wire in the driver side brake light and hooked it up there. Have to turn the lights on then flip the switch in the bed to have them come on
  6. Feb 8, 2010 at 6:26 PM
    #126
    jefferson
    Sex Panther
    05 PreRunner SR5
    If it works for ya..!
  7. Mar 1, 2010 at 6:11 AM
    #127
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    FYI, I just picked some of these lights up at the local Harbor Freight. On Saturday, they were 14.99. Sunday morning, 9.99 on sale. I got two boxes :)
    Oh, this is in the Lantana/West Palm Beach, Florida location.
  8. Mar 1, 2010 at 6:23 AM
    #128
    Ccwahoo
    Ccwahoo "Get comfortable being uncomfortable" Goggins
    Central Virginia
    '10 TRD Sport 4x4
    Very nice. Def. a great idea. Thanks for the guide
  9. Mar 1, 2010 at 11:45 AM
    #129
    jefferson
    Sex Panther
    05 PreRunner SR5
    welcome
  10. Apr 18, 2010 at 3:19 PM
    #130
    2gtacoma
    2gtacoma Well-Known Member
    Daniel
    H-town
    05 -PreRunner sr5
    URD Maf Cal, Airaid intake, Gibson exhaust, Urd short shifter,Trd shift knob, 2.25 lift,Satoshi grill, Trex eyelids
    how many amp relay is sufficient for the lights.
  11. Apr 18, 2010 at 4:36 PM
    #131
    jefferson
    Sex Panther
    05 PreRunner SR5
    not really sure that is english BUT with the harbor freight kit, the relay is integrated with the switch. If you're going to do your own wiring, one relay is fine
  12. Apr 18, 2010 at 7:43 PM
    #132
    2gtacoma
    Daniel
    H-town
    05 -PreRunner sr5
    well i bought this light kit from harbor freight but all it has is a 15amp fuse and a (on-off) switch i want to put a relay in there but all o'reilly's had was a 12v 40amp relay i just wanted to make sure i dont catch my truck on fire.
  13. Apr 18, 2010 at 8:09 PM
    #133
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Wire the fuse between the battery and the relay. If the lights draw more than 15amps the fuse will blow before the relay or the rest of the wiring. I put all my fuses within 6" or so of the positive terminal. Shortest possible distance for the electricity to flow and get stopped before frying anything else.
  14. Apr 18, 2010 at 9:03 PM
    #134
    jefferson
    Sex Panther
    05 PreRunner SR5
    agreed. this is the best/easiest way
  15. Apr 19, 2010 at 9:08 AM
    #135
    Tracy
    Tracy The Silver blurr...
    TRACY
    SoCAL. IE, SGV, LA. :D
    '08 TRD Sport Edition PreRunner
    Chrome tube steps. Because a lady needs a help up when wearing a dress. :)
    iBF! i want bedlamps...summer is coming around the corner, which means...Camping! :D
  16. Apr 19, 2010 at 9:13 AM
    #136
    jefferson
    Sex Panther
    05 PreRunner SR5
    awesomeness! lets make it happen!!
  17. Apr 19, 2010 at 9:07 PM
    #137
    2gtacoma
    Daniel
    H-town
    05 -PreRunner sr5
    just got done with the lights about an hour ago or so they look sweet:cheers::cheers:
  18. Apr 19, 2010 at 10:03 PM
    #138
    jefferson
    Sex Panther
    05 PreRunner SR5
    coool man post some pics!
  19. May 6, 2010 at 7:06 AM
    #139
    calaniz0312
    calaniz0312 Well-Known Member
    Carlos
    Mission, TX
    05 PreRunner SR5
    Pop a Lock tail gate lock, Dee Zee Heavy Duty bed mat, Viper alarm system, Blacked out headlights, Blacked out tailights.
    Awesome mod!
  20. May 12, 2010 at 11:06 AM
    #140
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
