How to Wire Chase Light to Hazards Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EYBT, Jul 16, 2025.
  1. Jul 16, 2025 at 1:22 PM
    EYBT
    EYBT [OP] Well-Known Member
    Evan
    Oahu, Hawaii
    2014 TRD 4x4
    JBA UCA, Eibach Springs, Bilstein 5100s, 2.5" AAL
    Does anybody know how to wire chase lights to hazards and not turn signals? I have been trying to look it up but with no luck. Lights are too bright to be hooked up to the turn signals but would be nice to have it in on with hazard only.
    The only option I can think of right now is running a relay to the hazard light button? Not sure.
  2. Jul 16, 2025 at 3:17 PM
    haydendoesmith
    haydendoesmith Well-Known Member
    15 DCSB TRD Sport 4X4 Auto
    The hazard switch provides a ground to the turn signal flasher. I would definitely use a relay with a diode or two, if this is the route you wanna take.
    EYBT[OP] likes this.
  3. Jul 24, 2025 at 6:00 AM
    EYBT
    Evan
    Oahu, Hawaii
    2014 TRD 4x4
    Do you know exactly how I would wire it? Could I use a relay and wire the signal wire to a wire on the hazard button?
