How to wire heated seats?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paul123, Aug 28, 2016.
  1. Aug 28, 2016 at 10:26 AM
    Paul123
    Paul123 [OP] Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    I just bought clazzios with heated seats and I'm not much of a wiring guru. I was thinking I'd just get power from the 12v accessory plug/ cigarette lighter using a crimp splicer. Then I'd run the ground to a good ground somewhere in the cab. Sound good enough or should I do it a different way?
  2. Aug 28, 2016 at 12:53 PM
    BYBO
    BYBO Well-Known Member
    Byron
    Indiana
    I run a 14 gauge wire directly from the battery to the seat frame.
    And that's why I don't have seat heaters.
    MSU Taco and Paul123[OP] like this.
  3. Aug 28, 2016 at 12:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahaha took me a second.
    OP, how much power do these draw?
  4. Aug 28, 2016 at 5:09 PM
    Paul123
    Paul
    Reno
    The website says "DC 12V 25 +/-3 watts x2"
  5. Aug 28, 2016 at 5:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    So let's say maximum it's 28 watts each, which is total 56 watts.
    watts/volts=amps
    56 watts/12v=~5 amps
    That's a low enough draw that you can run both seats off of a single add a circuit! That's nice and easy. Have you used one before?
    Sandman614 likes this.
  6. Aug 28, 2016 at 5:13 PM
    MSU Taco
    MSU Taco More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
    That's simultaneously the cheapest and most expensive ways to go about it haha
  7. Aug 28, 2016 at 5:13 PM
    Paul123
    Paul
    Reno
    I've used the add a fuse type in my jeep/crawler. The type you replace an existing fuse with a new one that has a wire connected to it.
  8. Aug 28, 2016 at 5:15 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep! That's exactly what I'm talking about. Tap into the ACC fuse under the coin holder and use a 7.5 amp fuse and you should be golden. Then your seats will only get power while the key is turned.
  9. Aug 28, 2016 at 5:16 PM
    Paul123
    Paul
    Reno
    Perfect that's what I'll do! Thanks for your help :thumbsup:
  10. Aug 28, 2016 at 5:17 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No problem! And for the ground you're correct about just finding a solid, random point. There's plenty under the center console you can utilize.
    ghardy and Paul123[QUOTED][OP] like this.
  11. Aug 28, 2016 at 5:28 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    There is an empty slot in the fuse panel under the steering wheel that is perfect for this. I can't remember which one off the top of my head, I'll try to see where I tapped in tomorrow.
  12. Aug 28, 2016 at 8:16 PM
    Paul123
    Paul
    Reno
    That would be awesome!
  13. Sep 4, 2016 at 4:05 PM
    Paul123
    Paul
    Reno
    Okay so the kit has two red wires, one black wire and one yellow wire. It says yellow is for illumination, one red to 12v power, the other red to switched power, and black to ground. Do I have to connect the yellow and two red wires to different positive sources?
  14. Sep 4, 2016 at 8:21 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Hey I'm sorry I haven't had a chance to take any pics of how I did it (2 month old). When I did mine it had the same wiring, I soldered the 12v constant and switched together and connected to one fuse tap, did this for each seat. Then I connected each seat to a fuse under the dash with a fuse tap. For illumination I connected both seats to one fuse tap and connected to I believe the tail lights fuse under the dash. Hope this helps.
    Paul123[OP] likes this.
  15. Sep 4, 2016 at 9:05 PM
    Paul123
    Paul
    Reno
    Awesome thats exactly what i needed to know! Thanks!
