How to wire multiple LED bars?
Discussion in 'Lighting' started by AkArin, Dec 24, 2014.
  1. Dec 24, 2014 at 2:01 AM
    AkArin
    AkArin [OP] Well-Known Member
    08 TRD Off-Road
    x
  2. Dec 25, 2014 at 11:24 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    you will pull too many amps through the wiring harness using it for 2 bars. it not designed for that. you would have to make a custom harness. get the harness for the 2nd bar. you can wire the trigger wire to the same switch though.
  3. Dec 26, 2014 at 2:22 PM
    AkRyan
    AkRyan Active Member
    Anchorage, AK
    '05 Tacoma TRD Offroad
    Well seeing how you can hook up a 50 inch light bar to a single wiring harness, you can hook up a single row 10 inch + a double row 30 inch without exceeding amps. Light bars don't draw very much amperage, hence you could hook up plenty more to one harness.
  4. Dec 26, 2014 at 3:54 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Yup I've got a 20" and two 8" bars wired together. Which is about 17 amps total. Then my 42" is wired separately which is about 22amps. So I could probly get away wiring them all together but I was safe about it. What are the amp ratings for yours combined? And the wire gauge?
    Should be just fine regardless. The only thing that might matter, is if rigid uses different gauge wiring and relay for their smaller bars versus their bigger bars. Which I doubt they do. Their harnesses are pretty nice anyways. Probly all the same wiring harnesses.
  5. Dec 26, 2014 at 5:18 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    here is where i kindly disagree... to a point. i do agree quality LED's are low amperage.
    a harness rated for a 50" bar is more than likely overkill for 10" bar. however a harness for a 10" bar would not be ideal for a 50" bar and could be a fire risk.
    no two light bars are the same when mixing sizes or manufactures when it comes to operating amperages and the harness.
    rigid E10 bar - 5amps
    rigid E30 bar - 12amps
    rigid E40 bar - 12amps
    rigid E50 bar - 20 amps
    the harness for a 50" would have the headroom to accomdate the 10 & 30" bars on it. not the other way around
    *unless they use the 50" harness for all bars*
    There a lot more that plays into this that i can't cover right now.
  6. Dec 26, 2014 at 6:03 PM
    NightProwler
    Harlan
    Maricopa, Az
    Yeah that's what I was trying to say. Even then, If his 30 and 10 is 17 amps, that should be plenty. And I'm betting they all come with 30 or 40 amp relays anyways. So it's gonna come down to wire gauge. But, to be safe, you could wire in a separate fuse when tapping into the other harness, and that'll eliminate any hazards. If it pops, then you'll know to wire in a separate harness. But let's wait on word from him on the wire gauge then go from there.
  7. Jan 1, 2015 at 9:26 AM
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
    Subd
