How to wire S2 sport flush mounted reverse lights to come on when in reverse?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CLVol1255, Jan 21, 2024.
  1. Jan 21, 2024 at 6:40 PM
    CLVol1255
    CLVol1255 [OP] Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    I’ve got some Baja designs S2 sport flush mounted in new bumper which came with harness that has an inline 30 amp fuse 40 amp relay and a switch on it. I’m not really wanting to run it through a switch I’d rather it just come on whenever I put the truck in reverse instead. Do I need to just cut the switch part of the harness and tap into the reverse light at the tail?
  2. Jan 22, 2024 at 5:52 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    That's exactly what I did with mine. Works perfectly too.
  3. Jan 22, 2024 at 6:04 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    I believe you want @daveeasa 's plug and play harness. No cutting required.
    https://fbchs.square.site/product/t...rue&sa=false&sbp=false&q=false&category_id=12
  4. Jan 22, 2024 at 8:32 AM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    So did you completely snip off the switch or did you snip off the switch connector and use the blue wire of the switch connector to tap into reverse wire?
  5. Jan 22, 2024 at 8:35 AM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
  6. Jan 22, 2024 at 8:50 AM
    fathomblue
    Richard
    Eastern Kansas
    It's a different harness but I can't say for sure that they can be used together. My guess is that it would work by using them in series but you would have to ask Dave to be sure. Maybe send him a PM?
  7. Jan 22, 2024 at 8:52 AM
    545 Well-Known Member
    2015 Access Cab
    I would suggest a three way switch; auto, off and on. Auto coming on when in reverse
    There will be times when you want them on when outside of truck, and times when you don’t want them coming on
    I know I’ve cursed the truck in front of me before when there reverse spots come on every time they reverse when doing a trail ride- in daylight
  8. Jan 22, 2024 at 8:53 AM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Ok thanks! I sent him a PM
  9. Jan 22, 2024 at 8:54 AM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Can you explain how this would be accomplished? Thanks
  10. Jan 22, 2024 at 9:01 AM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
  11. Jan 22, 2024 at 9:03 AM
    fathomblue
    Richard
    Eastern Kansas
    Just for the heck of it I took a look at Dave's website and turns out that if you opt for the more expensive DIR harness it already comes with the ability to trigger auxillary reverse lights. I'm guessing you don't have that one.
  12. Jan 22, 2024 at 9:34 AM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    I do not unfortunately. Should’ve bought it for future proofing when I purchased my DIR kit
  13. Jan 22, 2024 at 3:47 PM
    shaggy135
    I'm trying to remember, ha. I think I snipped the connector off. I know I just tapped into the reverse wire at the trailer plug though. I haven't ever had a need for a switch.
    CLVol1255[QUOTED][OP] likes this.
  14. Jan 22, 2024 at 3:54 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Thanks for all the help fellas I got it wired and working as it should
  15. Feb 3, 2024 at 1:15 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Hey guys, sorry to come to the party so late, but I got my rough country flush mount 2 inch LEDs in, and I’m going to install them in my rear bumper as you guys described above and that was my question, it came with this nice wiring harness, it came with the switch. It came with the relay And I don’t believe I need any of that. I just wanna tap my wires into my trailer harness. I’m wondering if that was OK
    https://www.extremeterrain.com/roug...h-mount-led-cube-lights-spot-beam-pair-6.html
  16. Feb 4, 2024 at 5:44 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    do you remember what color wires in your trailer wiring harness was the reverse light
  17. Feb 4, 2024 at 9:11 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i highly recommend using and tapping into a 'sacrificial harness' like the curt 56584
    https://www.amazon.com/CURT-56584-Custom-Wiring-Harness/dp/B007EA6WQU.
    that would be the blue wire within that harness for power, with the white wire for ground.
    this is done in the high likelihood event that you either sell the truck, or screw something up, the trucks wiring remains intact and can be returned to OE condition.
  18. Feb 4, 2024 at 9:25 AM
    shaggy135
  19. Feb 4, 2024 at 3:30 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Just ordered the harness, thanks for the thought on that. Already installed lights in bumper. Hard part done, waiting on wiring now
    soundman98 likes this.
