How tough are alignments on our trucks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Caleb13, Jan 12, 2020.
  1. Jan 12, 2020 at 3:09 PM
    Caleb13
    Caleb13 [OP] Active Member
    Grey metallic SR 2.7 Tacoma manual trans
    Just got wheel alignment done been a little parinoid about knocking it off will decent potholes knock it off or does it take a lot just wondering how tough are alignments.
  2. Jan 12, 2020 at 3:11 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Ford tough
    coma toy, Taco_Coma, philth and 2 others like this.
  3. Jan 12, 2020 at 3:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Buy a paint pen and draw a line on each adjuster. Then you’ll know if you knock it out. And if you do, easy to move back.
    Kev250R and Caleb13[QUOTED][OP] like this.
  4. Jan 12, 2020 at 3:11 PM
    kapn
    kapn Well-Known Member
    Annapolis, MD
    2016 TRDORLB Blue
    Potholes will not. There are some pretty serious parts holding everything together.
    However, all those parts are wearing, more so when it’s driven on less than ideal roads. Worn parts cause the alignment to be out and that wears tires funny. That’s why you should avoid potholes.
    Caleb13[OP] likes this.
  5. Jan 12, 2020 at 3:12 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Better than any car, as everything is more heavy duty
    71tattooguy and Caleb13[OP] like this.
  6. Jan 12, 2020 at 3:13 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The less things you hit, the longer it'll last. Parking stops and potholes are worth avoiding.
  7. Jan 12, 2020 at 9:26 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Curbs too, the hood is so long can't tell how far forward to go before I need to turn the wheel when leaving home depot.
  8. Jan 12, 2020 at 11:44 PM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    It's quite possible for any considerable jolt to knock the steering out of alignment. An alignment can last more than a year or even just a few minutes. There are so many possible variables one can never know how long it may be before the next alignment is needed. For the most part these trucks are fairly rugged so an alignment should last awhile but if you hit a curb while leaving the tire shop .... You might possibly need another alignment.
    wilcam47 likes this.
  9. Jan 13, 2020 at 12:50 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Second gen. 136,000 miles one alignment... when they changed my frame. I don't offroad but I do use it as a truck. Towing 4000+# and max payload occasionally. Drove straight with even wear before and after frame swap. I assume 3rd gens are built to the same exacting standards as the 2nd gens. So relax and drive it like you stole it!
    :mudding::mudding::mudding:
    :burnrubber::burnrubber::burnrubber:
  10. Jan 13, 2020 at 5:53 AM
    ryan760
    ryan760 Well-Known Member
    The truck is built for some pretty serious off roading which obviously involves lots of pounding on the suspension. It's pretty robust. Much stronger than a passenger car which uses chopsticks for linkages...
  11. Jan 13, 2020 at 7:15 AM
    BillsSR5
    bill
    2014 SR5
    it all depends on how well the roads you drive on are maintained,
  12. Jan 13, 2020 at 7:35 AM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I hit stuff very hard every day. Haven't had an alignment done in quite a while.
    Only thing I've changed in the alignment stuff is total chaos cam tabs because the tin foil tabs that come with the truck are junk.
  13. Nov 13, 2021 at 10:15 AM
    jswihart
    jswihart Well-Known Member
    Southern Indiana
    Cement 2019 Off-Road Premium DCSB
    On 285s 1.5 inch 5100s, can confirm a pothole will knock it off. Was going 15-20 around a sharp corner, pothole was filled with water and now steering wherl is off 90 deg from before.
  14. Jan 20, 2022 at 1:51 AM
    robssol
    Rob
    S. Wisconsin
    You bent/broke something! Get it checked... Quick!:bananadead:
  15. Jan 20, 2022 at 3:21 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Do you think adjusters actually, turn if hitting a bump hard ?
  16. Jan 20, 2022 at 3:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yes, I’ve done it before.
  17. Jan 20, 2022 at 4:57 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    Are you serious with this ?? Or are you kidding ?? Adjustments do not move when hitting a bump or pot holes as long as the adjusters are TIGHT TIGHT KEY WORD LOL, which they BETTER be. Alignments go out when hitting a large bump or large pot holes at a higher speeds. This will shift suspension points and OR bend parts as well. I have been doing alignments for many many years. Just asking is all.
    Mr-Paul likes this.
  18. Jan 20, 2022 at 4:58 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I am serious. Driving on the road they shouldn't move but they absolutely can while offroad. I've done it so many times that I put a tack weld on my adjusters so they won't move.
    Kev250R, 71tattooguy and TnShooter like this.
  19. Jan 20, 2022 at 5:01 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I also replied to the comment from earlier today before realizing what the thread was about since it's old and I was still waking up. I've never knocked my alignment out on paved roads and it would be difficult to do so. The paint pen is still a valid suggestion though if knocking the alignment out is ever a concern.
    Offroad is a different animal.
    71tattooguy likes this.
  20. Jan 20, 2022 at 5:08 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    NOT to beat this to death, but if the eccentric BOLTS are tight and I mean tight, I have never seen one move. just my opinion. I have seen eccentric bolts that are very tight but the area's around this bolt is filled with rust preventing it to really lock down snug.
