How vital is it to air down?
Discussion in 'Off-Roading & Trails' started by Kenny650, Jul 13, 2009.
  1. Jul 13, 2009 at 11:43 PM
    Kenny650
    Kenny650 [OP] Well-Known Member
    In the sand?
  2. Jul 13, 2009 at 11:46 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    try it out and see for yourself. 5 or 10 lbs down would be ok. I usually start at 5 and go from there
  3. Jul 13, 2009 at 11:50 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    If I were 2wd, I'd probably do it religiously, but seeing as I've never owned a 2WD truck, I've never done it and never had a traction issue in 4wd
  4. Jul 14, 2009 at 12:16 AM
    Kenny650
    I didn't air down and once I hit that loose sand I knew I was screwed and I was.
  5. Jul 14, 2009 at 12:19 AM
    brian
    Elizabeth City, NC
    I'm guessing you're a Prerunner then?
  6. Jul 14, 2009 at 12:19 AM
    Kenny650
  7. Jul 14, 2009 at 12:20 AM
    Kenny650
    I will never buy another 4x2 in my life!
  8. Jul 14, 2009 at 12:21 AM
    brian
    Elizabeth City, NC
    Thats why I've never bought one in the first place :)
  9. Jul 14, 2009 at 12:23 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
  10. Jul 14, 2009 at 12:37 AM
    Kenny650
    Did you air down?
  11. Jul 14, 2009 at 12:42 AM
    Burgman
    Stephen
    Ric VA
    no air down
  12. Jul 14, 2009 at 12:52 AM
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
    4X4 or 4X2 it's always good to air down...you will get better traction and a more smoother ride on the trails. Now unless you like bone Jarring, teeth rattling rides then don't air down at all.
    But if you want a smooth ride out on the trials, or be able to climb over rocks, and have better traction in the sand...it's rule number 1.
  13. Jul 14, 2009 at 6:05 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    I got a 4x4 and the first time I went to the dunes, I didn't air down, as soon I left the pavement, started losing traction but the truck moved on, then hit a soft patch and sunk in. I tried rocking the truck forward and reverse but only sank deeper, before the diffs touched the sand I remembered to air down and viola, a couple of forward and reverse and I was running again in seconds.
    I just dropped from 30psi to 20psi and made a whole lot of difference.
    Now every time I go off the pavement I air down to 20psi no matter the conditions.
    Also I got a MV30 for $35.00 at pepboys and air up after the trails.
    For me now is SOP to air down whenever I go off road
  14. Jul 14, 2009 at 6:20 AM
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    any off road condition shouldbe aired down.. this should havebeen a poll, do you air down or do you get stuck. u may not gewt stuck by not airing down, but then again even a broken clock is right twice a day.
  15. Jul 14, 2009 at 11:39 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I don't air down until I have to. :p
    I run normal on-road pressure whereever I go, but if I get in a sticky situation, I'll air down then. It's sorta a backup when you get stuck without airing down, you have an "evacuation" plan, which is to air down. When you already air down, there is no plan. You're completely stuck then.
  16. Jul 14, 2009 at 11:52 AM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    Yup yup, I've seen 2x4's aired down tackle trails in Moab that Jeeps couldn't do aired up (silly jeepsters). This is probably one of the best "free" features you can to do assist you in traction and off road, now you just gotta get a compressor to air up for the highway ride back home so maybe it's not so free after all...
    Rob
  17. Jul 14, 2009 at 11:53 AM
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    I always air down to usually 15psi
    no way i would run 30-40 off road (I don't mean dirt roads though)
  18. Jul 14, 2009 at 12:06 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    2x4 here. I air the rear down to 16-18 PSI and leave the front at 32.
    It makes all the difference in the world.
  19. Jul 14, 2009 at 12:26 PM
    jonny
    jonny Betty White Edition Heep ZJ
    why didn't you air down the front tires?
    (i am completely acting like a sarcastic noob :))
  20. Jul 14, 2009 at 12:33 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    I'm wondering the same thing, the effects are only half felt if the fronts are full, plus it make the approach much harder without the "give" of the front tires "biting", but we each have our own ways, I'm curious as to this method too.
    Rob
